Snap-confine has elevated permissions and is not confined but should be
Hi.
This is the message that appears when i first execute the lxc command. What is the problem?
Thank you
No idea, that’s a snapd issue, possibly related to apparmor.
What distribution are you running and with what kernel?
You may want to report this at https://forum.snapcraft.io
Thank you @stgraber.
I found the answer on the snapcraft forum.
I solved it by starting apparmor.
