3.0 - hardware (/dev/random) based RNG daemon failing in unprivilged container
Host Ubuntu 18.04 / Guest Archlinux Current
Assuming the host is not sharing its entropy with the unpriviliged guest container I tried haveged in the guest with this result however.
haveged.service: Failed to set up network namespacing: Permission denied
haveged.service: Failed at step NETWORK spawning /usr/bin/haveged: Permission denied
Tried with a Unbuntu guest and though there is no error output the deamon just stays dead.
is there perhaps a workaround to provision an entropy daemon in in unprivilged containers?
apparently haveged isn’t meant to work in unprivileged containers Centos 7.5 container operation not permitted?
thank you for the pointer.
Any hardware (/dev/random) based RNG will fail in an unprivileged LXC environment thus.
Would be good to have a paravirtual random number generator available but suppose that would need a kernel driver or a resource sharing wrapper around /dev/random with tenants limited to a certain share of allocation of data
