Hi
I had problems upgrading an ubuntu 18.04 to 20.04, and decided to start from scratch.
I’ve installed lxd from snap and restored the dir /var/snap/lxd or just /var/snap/lxd/common/lxd/database. I’ve tried jumping versions to refresh links ( snap refresh lxd --edge && snap refresh lxd --stable ).
But the closest I get to starting lxd is this:
# lxd --group lxd --debug
INFO[02-05|17:21:01] Initializing global database
INFO[02-05|17:21:01] Connecting to global database
DBUG[02-05|17:21:01] Dqlite: attempt 1: server 1: connected
INFO[02-05|17:21:01] Connected to global database
DBUG[02-05|17:21:01] Database error: failed to fetch current nodes versions: no such column: pending
EROR[02-05|17:21:01] Failed to start the daemon err="Failed to initialize global database: failed to ensure schema: failed to fetch current nodes versions: no such column: pending"
INFO[02-05|17:21:01] Starting shutdown sequence signal=interrupt
So I assume I have a corrupt database? Any way to repair it?
Full start-log:
root@nas02:/var/snap# lxd --group lxd --debug
INFO[02-05|17:28:33] LXD is starting version=4.0.8 mode=normal path=/var/snap/lxd/common/lxd
INFO[02-05|17:28:33] Kernel uid/gid map:
INFO[02-05|17:28:33] - u 0 0 4294967295
INFO[02-05|17:28:33] - g 0 0 4294967295
INFO[02-05|17:28:33] Configured LXD uid/gid map:
INFO[02-05|17:28:33] - u 0 1000000 1000000000
INFO[02-05|17:28:33] - g 0 1000000 1000000000
INFO[02-05|17:28:33] Kernel features:
INFO[02-05|17:28:33] - closing multiple file descriptors efficiently: no
INFO[02-05|17:28:33] - netnsid-based network retrieval: yes
INFO[02-05|17:28:33] - pidfds: yes
INFO[02-05|17:28:33] - core scheduling: no
INFO[02-05|17:28:33] - uevent injection: yes
INFO[02-05|17:28:33] - seccomp listener: yes
INFO[02-05|17:28:33] - seccomp listener continue syscalls: yes
INFO[02-05|17:28:33] - seccomp listener add file descriptors: no
INFO[02-05|17:28:33] - attach to namespaces via pidfds: no
INFO[02-05|17:28:33] - safe native terminal allocation : yes
INFO[02-05|17:28:33] - unprivileged file capabilities: yes
INFO[02-05|17:28:33] - cgroup layout: hybrid
WARN[02-05|17:28:33] - Couldn't find the CGroup blkio.weight, disk priority will be ignored
WARN[02-05|17:28:33] - Couldn't find the CGroup memory swap accounting, swap limits will be ignored
INFO[02-05|17:28:33] - shiftfs support: yes
INFO[02-05|17:28:33] Initializing local database
DBUG[02-05|17:28:33] Refreshing local trusted certificate cache
INFO[02-05|17:28:33] Set client certificate to server certificate fingerprint=1f751b72d27d5d3cb032fa7eefd7c2e37387382a287bcb5889722bf61e68b0e5
DBUG[02-05|17:28:33] Initializing database gateway
INFO[02-05|17:28:33] Starting database node id=1 address=1 role=voter
INFO[02-05|17:28:33] Starting /dev/lxd handler:
INFO[02-05|17:28:33] - binding devlxd socket socket=/var/snap/lxd/common/lxd/devlxd/sock
INFO[02-05|17:28:33] REST API daemon:
INFO[02-05|17:28:33] - binding Unix socket socket=/var/snap/lxd/common/lxd/unix.socket
INFO[02-05|17:28:33] Initializing global database
INFO[02-05|17:28:33] Connecting to global database
DBUG[02-05|17:28:33] Dqlite: attempt 1: server 1: connected
INFO[02-05|17:28:33] Connected to global database
DBUG[02-05|17:28:33] Database error: failed to fetch current nodes versions: no such column: pending
EROR[02-05|17:28:33] Failed to start the daemon err="Failed to initialize global database: failed to ensure schema: failed to fetch current nodes versions: no such column: pending"
INFO[02-05|17:28:33] Starting shutdown sequence signal=interrupt
DBUG[02-05|17:28:33] Cancel ongoing or future gRPC connection attempts
INFO[02-05|17:28:33] Stop database gateway
INFO[02-05|17:28:33] Stopping REST API handler:
INFO[02-05|17:28:33] - closing socket socket=/var/snap/lxd/common/lxd/unix.socket
INFO[02-05|17:28:33] Stopping /dev/lxd handler:
INFO[02-05|17:28:33] - closing socket socket=/var/snap/lxd/common/lxd/devlxd/sock
INFO[02-05|17:28:33] Not unmounting temporary filesystems (instances are still running)
INFO[02-05|17:28:33] Daemon stopped
Error: Failed to initialize global database: failed to ensure schema: failed to fetch current nodes versions: no such column: pending
