Hi - I’m trying to add a new member to an existing “cluster” (only a single machine at the moment) that’s using ceph storage. I’m getting stuck with:
Error: Failed to join cluster: Failed to initialize member: Failed to initialize storage pools and networks: Failed to update storage pool "[existing ceph pool name]": Config key "source" is cluster member specific
Is it not possible to add a member to a cluster with a ceph storage pool if it’s already got containers in it? The whole point is that they can be shared between hosts. Is there some magic I need to use with the init yaml? Init interview is here -
# incus admin init
Would you like to use clustering? (yes/no) [default=no]: yes
What IP address or DNS name should be used to reach this server? [default=ip.addre.ss]: new.server.name
Are you joining an existing cluster? (yes/no) [default=no]: yes
Please provide join token: <join token from existing server>
All existing data is lost when joining a cluster, continue? (yes/no) [default=no] yes
Choose "source" property for storage pool "shared_ceph": existing-ceph-pool
Choose "lvm.thinpool_name" property for storage pool "local": local_incus
Choose "lvm.vg_name" property for storage pool "local": local_incus
Choose "source" property for storage pool "local": /dev/md1
Would you like a YAML "init" preseed to be printed? (yes/no) [default=no]: yes
Yaml config is here
config: {}
networks: []
storage_pools: []
profiles: []
projects: []
cluster:
server_name: new.server.name
enabled: true
member_config:
- entity: storage-pool
key: source
value: existing-ceph-pool
description: '"source" property for storage pool "existing-ceph-pool"'
key: lvm.thinpool_name
value: local_incus
description: '"lvm.thinpool_name" property for storage pool "local"'
key: lvm.vg_name
value: local_incus
description: '"lvm.vg_name" property for storage pool "local"'
key: source
value: /dev/md1
description: '"source" property for storage pool "local"'
cluster_address: existing.server.name:8443
cluster_certificate: |
-----BEGIN CERTIFICATE-----
<cert>
-----END CERTIFICATE-----
server_address: new.server.name:8443
cluster_token: ""
cluster_certificate_path: ""
Thanks!
