According to previous posts the issue is resolved but for me it still doesn’t work flawlessly.
I use LXC 3.13 and created a LVM pool and a container using that pool and thin provisioned LV created in the launch process by LXD.The initial max size is 10GB by default, which is fine for many cases.
I used LVM tools to expand the logical volume and the XFS filesystem as advised in previous posts as LXD provides no tools to to expand a LV. The container does recognise it immediately and inside the container everything seems OK.
[root@host-default ~]# df -h
/dev/lxdvg/containers_host–default 50G 457M 50G 1% /
none 492K 0 492K 0% /dev
none 10M 0 10M 0% /sys/fs/cgroup
devtmpfs 3.9G 0 3.9G 0% /dev/tty
tmpfs 100K 0 100K 0% /dev/lxd
tmpfs 100K 0 100K 0% /dev/.lxd-mounts
tmpfs 3.9G 0 3.9G 0% /dev/shm
tmpfs 3.9G 8.1M 3.9G 1% /run
Nevertheless, a 'lxc file push …* of a 15 GB backup file into the container fails: “… no space left on device …” after about 6 GB. And all LXD meta data still report the initial size of 10 GB:
[root@hosting ~]# lxc storage volume show lvmpool container/host-default
block.filesystem: xfs
block.mount_options: discard
description: “”
type: container
- /1.0/containers/host-default
The LXC tools I’m aware to to set various configuration options refuse to modify e.g. the “size:” value
But I can copy the directly into the container
cp /root/jms-transfer.tar /var/lib/lxd/storage-pools/lvmpool/containers/host-default/rootfs/
I could change the ownership:
chown 1000000.1000000 jms*
and use / unpack the tar, use the files without issues so far and the container filesystem noticed the change perfectly:
/dev/lxdvg/containers_host–default 50G 30G 21G 59% /
But I don’t think that workaround is an appropriate way for everyday work.
So my questions are:
Is it a bug or is it just cosmetical, because the storage meta data do not affect the daily operation in any way?
How can I adjust the meta data?
Or is it safe to use the container with wrong meta data in production (nothing fancy, just standard web and mail service)?
