Until LXD 3.1 makes to stable channel for 3.0, is there any short tutorial on setting up mult-host networking with fan.
Tried installing 3.0 cluster on 3 nodes, the problem I am facing is, all the bridges have same IPV4 and IPV6 address. So I can’t set layer 3 routs using ip route command. VXlan also throws error.
Is there any way in 3.0 that all 3 nodes can have different IP address range working using local DHCP/DNS on the node and form a cluster.
I have worked with LXD 2.11 and Tinc VPN to setup multi-host network across different clouds. But since my setup is in a VPC I do not want to incur the overhead of tinc VPN encryption.
