I would like to apply just the yaml portion concerning “devices” to a container (yml extract from ‘lxc config device show xxxxx’).
would that be possible with lxd commands?
Exemple:
file:
path: home/rustical/emaraud/file
source: /usr/local/share/rustical/emaraud/file
files:
path: home/rustical/emaraud/files
source: /usr/local/share/rustical/emaraud/files
You can create a new empty profile, and add just those devices into that profile. The idea is that you can assign profiles to containers, therefore, you assign the existing profile(s) and on top of that this new profile.
$ lxc profile show myfragmet
Error: Fetch profile: No such object
$ lxc profile create myfragment
Profile myfragment created
$ lxc profile show myfragment
config: {}
devices: {}
used_by: []
Add the devices by changing
devices: {}
with
file:
files:
