Assigning public IP to LXD container - not working
Hi all, I am trying to assign a public IP to one of my containers (all the others do not need static public IP with direct access to Internet as they are behind a proxy).
Am using Ubuntu 18.04. Here is my config and the command used to assign IP to the container.
On the host I have configured the second IP as it follows:
#HOST 01-netcfg.yaml
network:
  version: 2
  renderer: networkd
  ethernets:
      match:
        macaddress: 0a:00:00:00:00:00
      addresses:
        - 9x.xx.xxx.162/32
        - 17x.xxx.xxx.186/24
      #gateway6: fe80::1
      routes:
        - to: 0.0.0.0/0
          via: 9x.xxx.xxx.xxx
          #on-link: true
          metric: 100
        - to: 0.0.0.0/0
          via: 17x.xxx.xxx.1
          metric: 100
      nameservers:
        search: [ invalid ]
        addresses:
          - xx.xxx.xxx.252
          - xx.xxx.xxx.251
$ ip a
  2: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UP group default qlen 1000
      link/ether 00:50:56:3d:2a:a2 brd ff:ff:ff:ff:ff:ff
      inet 9x.xxx.xxx.162/32 scope global eth0
      inet 17x.xxx.xxx.186/24 brd 17x.xxx.xxx.255 scope global eth0
      inet6 fe80::250:56ff:fe3d:2aa2/64 scope link
  3: lxdbr0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000
      link/ether 06:59:c8:fe:92:0f brd ff:ff:ff:ff:ff:ff
      inet 10.88.30.1/24 scope global lxdbr0
      inet6 fd42:c065:1583:bbbf::1/64 scope global
      inet6 fe80::e0fb:3ff:fe3c:2f38/64 scope link
  5: veth92c4df1c@if4: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue master lxdbr0 state UP group default qlen 1000
      link/ether 1e:4d:e9:66:e2:19 brd ff:ff:ff:ff:ff:ff link-netnsid 0
  7: veth2399e2e3@if6: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue master lxdbr0 state UP group default qlen 1000
      link/ether 06:59:c8:fe:92:0f brd ff:ff:ff:ff:ff:ff link-netnsid 1
  9: veth311523ae@if8: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue master lxdbr0 state UP group default qlen 1000
      link/ether aa:95:58:ca:cc:46 brd ff:ff:ff:ff:ff:ff link-netnsid 2
  13: vethf380a8d0@if12: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue master lxdbr0 state UP group default qlen 1000
      link/ether 1a:d4:f3:04:0f:28 brd ff:ff:ff:ff:ff:ff link-netnsid 4
I used the following command to assign public IP to mycont:
 lxc config device add mycont eth0 nic nictype=ipvlan parent=eth0 ipv4.address=17x.xxx.xxx.186
Within the container (mycont) I have this:
$ ip a
    inet6 ::1/128 scope host
14: eth0@if2: <BROADCAST,MULTICAST,NOARP,UP,LOWER_UP> mtu 1500 qdisc noqueue state UNKNOWN group default qlen 1000
    inet 17x.xxx.xxx.186/32 brd 255.255.255.255 scope global eth0
    inet6 fe80::50:5600:13d:2aa2/64 scope link
However, since the configuration, “mycont” can’t access internet.
One more thing, mycont is not receiving IP from lxdbr0 as the other containers.
Will appreciate any help to fix this.
Thanks
Just to clarify what I am trying to do.
I have a series of containers all sharing lxdbr0 and accessible through proxy. Actually they are all working with no issu. However, one application I am installing require the container to have a public IP. I therefore acquired a second public IP that I want to assign to that single container.
  • I tried with Netplan, adding the second IP and then assigning that second IP to lxdbr0 an latter to the container - it fails.
    Will appreciate any hints on how to proceed.
    Thanks
