Good morning,
Is it possible to create a Storage Pool that when launching a container, it creates a volume for that container under that pool? Like how the default profile/root device works. Mainly looking for a sanity check, as both source and path are required, so I do not think it is possible.
For instance, the default profile has the following under devices and creates volume named as the container
pool: default
However, when trying to emulate this for my prod_data
data:
path: /prod
pool: prod_data
However when saving it, it gives the error
Config parsing error: Device validation failed for "configs": Disk entry is missing the required "source" or "path" property
But when adding the source field, every container is able to share that data from all containers.
