I understand there are several posts on backing up LXD; however, I must admit, I am confused how certain backup techniques work. Some background, I came from VM Workstation and qemu/kvm where all I backed up were the individual vm folders so that if my drive failed, I just reinstalled OS and software and import the vm folders.
Regardless, I am uncertain on my part on what is actually necessary to backup of LXD.
Looking through the documentation of Backing up a LXD Server . It mentions for a full backup:
Full backup
A full backup would include the entirety of/var/lib/lxd
or/var/snap/lxd/common/lxd
for snap users.You will also need to appropriately backup any external storage that you made LXD use, this can be LVM volume groups, ZFS zpools or any other resource which isn’t directly self-contained to LXD.
Restoring involves stopping LXD on the target server, wiping the lxd directory, restoring the backup and any external dependency it requires.
Then start LXD again and check that everything works fine.
If I were to use say ZFS partition (as opposed to loop-based) as a backend, for example, am I correct to say it is NOT enough to backup that folder and on a new computer rsync the folder (/var/snap/lxd/common/lxd
), install LXD, and LXD should work just fine? I imagine this is true even if ZFS LXD partition is on a separate drive? If I understand correctly, backing up documented folder is not possible for zfs backend because of namespaces (one has to mount)?
Would copying of LXD snap folder only work with Dir backend if I understand @stgraber correctly in Backing up a LXD server - #4 by stgraber ?
For those that have more experience, would it be preferable then to use Dir backend and backup snap folder (assuming that is all that is necessary to backup)?
Or should I figure out a way to export individually all my containers as tarballs and also include I think
- lxd init --dump (for new install)
- lxd profiles
I think in my case that should be all things I need to backup or am I missing something major?
Side Questions:
When using lxc exports, that pauses / shut down container to do export tarball backup? Does that differ between Dir and zfs backend?
Does the speed of exporting differ between dir and zfs backends?
What does lxc export tarball actually include? Would it include previous snapshots of the container? Are they completely self contained ( not using ‘optimized’ flag as that would require the new server to use the same backend)?
