Good morning,
I have been running a LXC Server for home services for a year now, built my automation with ansible. I finally bought some more hardware and hard drives and decided to redo everything.
I was using raw.mount.options as seen below for the BTRFS Subvolumes. but utilizing them now after pushing to the new install I get the error below the profile config.
config: {}
description: Log Data Mount
log_data:
path: /logs
raw.mount.options: rw,noatime,compress=zstd:3,discard=async,space_cache=v2,autodefrag,user_subvol_rm_allowed,subvol=@lxd-common/@log
shift: "true"
source: /dev/disk/by-uuid/74e22187-7c00-4897-acbd-04c4b5eb8b55
- /1.0/instances/test
Error
Error: Failed to start device "log_data": Unable to mount "/proc/self/fd/30" at "/var/lib/lxd/devices/test/disk.log_data.logs" with filesystem "btrfs": invalid argument
