Hello
I have a lxd from snap (rev. 13300) , containers can not start after reboot server.
lxc info --show-log m-vw
lxc 20200208164829.378 TRACE commands - commands.c:lxc_cmd:303 - Connection refused - Command “get_state” failed to connect command socket
For storage used btrfs on /dev/sde2.
After few experiments i found a working scheme :
mount /dev/sde2 /var/snap/lxd/common/lxd/storage-pools/btrfs-prod
mount /var/snap/lxd/common/lxd/storage-pools/btrfs-prod/containers /var/snap/lxd/common/lxd/containers/ -o bind
after this, containers starts normaly , but i cant do export.
lxc export m-vw ./m-vw_06_02_2020.tgz Error: Create backup: Backup create: Failed to run: rsync -a -HA --sparse --devices --delete --checksum --numeric-ids --xattrs --bwlimit 0 -vi /var/snap/lxd/common/lxd/storage-pools/btrfs-prod/containers/m-vw/ /var/snap/lxd/common/lxd/backups/lxd_backup_862616164/container: rsync: change_dir "/var/snap/lxd/common/lxd/storage-pools/btrfs-prod/containers/m-vw" failed: No such file or directory (2) rsync error: some files/attrs were not transferred (see previous errors) (code 23) at main.c(1183) [sender=3.1.1]
lxc query /1.0/storage-pools?recursion=1
{ "config": { "source": "/dev/sde2" }, "description": "", "driver": "btrfs", "locations": [ "node1", "node2", "node3" ], "name": "btrfs-prod", "status": "Pending", "used_by": [ "/1.0/containers/m-vw", "/1.0/images/7b58622614fa724290eb15c139501394c63641e81411c13d166825cc8c7fae45", "/1.0/images/f91c8741dcff5597d23d63eec9860285fc3cde52b7a9cfaea88aa4850a9a2658", "/1.0/profiles/btrfs", "/1.0/profiles/btrfs2", "/1.0/profiles/btrfs_prod1" ] },
How i can export container for transfer to another node or fix this situation ?
