Problem
When running these commands, with the intention of running commands without entering into a shell, I get the following errors.
# lxc-attach -n vpnLxc -- ls
lxc-attach: vpnLxc: tools/lxc_attach.c: main: 302 You lack access to /home/user/.local/share/lxc
# sudo lxc-attach -n vpnLxc -- ls
lxc-attach: vpnLxc: attach.c: get_attach_context: 405 Connection refused - Failed to get init pid
lxc-attach: vpnLxc: attach.c: lxc_attach: 1469 Connection refused - Failed to get attach context
I’m at a loss why this may be the case, any ideas?
Context
I have the following unprivileged container, which is working fine (I can log in, it’s running the web services I need, etc).
# lxc config show --expanded vpnLxc
image.architecture: amd64
image.description: ubuntu 20.04 LTS amd64 (release) (20210927)
image.label: release
image.os: ubuntu
image.release: focal
image.serial: "20210927"
image.type: squashfs
image.version: "20.04"
volatile.base_image: 56296ba81a6fb502c634697a840d7957c3d2aa1a1805820e605ed21475058851
volatile.eth0.host_name: vethc6de36da
volatile.eth0.hwaddr: 00:16:3e:f5:23:7a
volatile.idmap.base: "0"
volatile.idmap.current: '[{"Isuid":true,"Isgid":false,"Hostid":100000,"Nsid":0,"Maprange":65536},{"Isuid":false,"Isgid":true,"Hostid":100000,"Nsid":0,"Maprange":65536}]'
volatile.idmap.next: '[{"Isuid":true,"Isgid":false,"Hostid":100000,"Nsid":0,"Maprange":65536},{"Isuid":false,"Isgid":true,"Hostid":100000,"Nsid":0,"Maprange":65536}]'
volatile.last_state.idmap: '[{"Isuid":true,"Isgid":false,"Hostid":100000,"Nsid":0,"Maprange":65536},{"Isuid":false,"Isgid":true,"Hostid":100000,"Nsid":0,"Maprange":65536}]'
volatile.uuid: d7bc7358-b05f-46dc-95a1-51a28c30f553
nictype: bridged
parent: br0
pool: lxcDefaultPool
shareFolder:
path: /home/ubuntu/media
source: /home/share_user/media
