Just updated the server, then I get this when attach a container to an ovs bridge:
incus profile add test ovs2
Error: Failed to start device "eth0": Failed to connect to OVS: Failed to connect to OVS: Failed to connect to OVS: failed to connect to unix:/run/openvswitch/db.sock: database Open_vSwitch validation error (3): Mapper Error. Object type ovsmodel.Datapath contains field CTZoneDefaultLimit (*int) ovs tag ct_zone_default_limit: Column does not exist in schema. Mapper Error. Object type ovsmodel.IPFIX contains field StatsInterval (*int) ovs tag stats_interval: Column does not exist in schema. Mapper Error. Object type ovsmodel.CTZone contains field Limit (*int) ovs tag limit: Column does not exist in schema
Old instances connect to the ovs bridge still working. Just can’t add new one. I think if I restart server, I won’t be able to connect to it again, so I won’t do it.
incus version
Client version: 7.5.1
Server version: 7.5.1
incus profile show ovs2
config: {}
description: connect to ovsbr2
nictype: bridged
parent: ovsbr2
The same container can connect to incus created network with native bridge driver.
And I can’t create network with openvswitch bridge driver.
incus network create mo bridge.driver=openvswitch
Error: Couldn't connect to OpenVSwitch: Failed to connect to OVS: Failed to connect to OVS: failed to connect to unix:/run/openvswitch/db.sock: database Open_vSwitch validation error (3): Mapper Error. Object type ovsmodel.IPFIX contains field StatsInterval (\*int) ovs tag stats_interval: Column does not exist in schema. Mapper Error. Object type ovsmodel.CTZone contains field Limit (\*int) ovs tag limit: Column does not exist in schema. Mapper Error. Object type ovsmodel.Datapath contains field CTZoneDefaultLimit (\*int) ovs tag ct_zone_default_limit: Column does not exist in schema
I just create a bridge use ovs-vsctl, and it worked.
