Github issues are used for bug reports. For support questions, please use …[our forum](https://discuss.linuxcontainers.org).
Please fill the template below as it will greatly help us track down your issue and reproduce it on our side.
Feel free to remove anything which doesn't apply to you and add more information where it makes sense.
# Required information
* Distribution: `Arch Linux`
* Distribution version: -
* The output of "lxc info" or if that fails:
<details>
<summary>lxc info</summary>
config: <snip>
api_extensions:
- container_stop_priority
- container_syscall_filtering
- auth_pki
- container_last_used_at
- etag
- patch
- usb_devices
- https_allowed_credentials
- image_compression_algorithm
- directory_manipulation
- container_cpu_time
- storage_zfs_use_refquota
- storage_lvm_mount_options
- network
- profile_usedby
- container_push
- container_exec_recording
- certificate_update
- gpu_devices
- container_image_properties
- migration_progress
- id_map
- network_firewall_filtering
- network_routes
- storage
- file_delete
- file_append
- network_dhcp_expiry
- storage_lvm_vg_rename
- storage_lvm_thinpool_rename
- network_vlan
- image_create_aliases
- container_stateless_copy
- container_only_migration
- storage_zfs_clone_copy
- unix_device_rename
- storage_lvm_use_thinpool
- storage_rsync_bwlimit
- network_vxlan_interface
- storage_btrfs_mount_options
- entity_description
- image_force_refresh
- storage_lvm_lv_resizing
- id_map_base
- file_symlinks
- container_push_target
- network_vlan_physical
- storage_images_delete
- container_edit_metadata
- storage_driver_ceph
- storage_ceph_user_name
- resource_limits
- resources
- kernel_limits
- storage_api_volume_rename
- macaroon_authentication
- network_sriov
- console
- restrict_devlxd
- migration_pre_copy
- infiniband
- maas_network
- devlxd_events
- proxy
- network_dhcp_gateway
- file_get_symlink
- network_leases
- unix_device_hotplug
- operation_description
- clustering
- event_lifecycle
- nvidia_runtime
- container_mount_propagation
- container_backup
- devlxd_images
- proxy_unix
- proxy_udp
- clustering_join
- network_state
- proxy_unix_dac_properties
- container_protection_delete
- unix_priv_drop
- pprof_http
- proxy_haproxy_protocol
- network_hwaddr
- proxy_nat
- network_nat_order
- container_full
- candid_authentication
- backup_compression
- candid_config
- nvidia_runtime_config
- storage_unmapped
- projects
- candid_config_key
- network_vxlan_ttl
- container_incremental_copy
- usb_optional_vendorid
- snapshot_scheduling
- snapshot_schedule_aliases
- container_copy_project
- clustering_server_address
- container_protection_shift
- snapshot_expiry
- snapshot_expiry_creation
- network_leases_location
- resources_cpu_socket
- resources_gpu
- resources_numa
- kernel_features
- id_map_current
- event_location
- network_nat_address
- container_nic_routes
- rbac
- cluster_internal_copy
- seccomp_notify
- lxc_features
- container_nic_ipvlan
- network_vlan_sriov
- storage_cephfs
- container_nic_ipfilter
- resources_v2
- container_syscall_intercept
- container_disk_shift
- storage_shifted
- resources_infiniband
- daemon_storage
- instances
- image_types
- resources_disk_sata
- clustering_roles
- images_expiry
- resources_network_firmware
- ceph_data_pool_name
- compression_squashfs
- container_raw_mount
- container_nic_routed
- container_disk_ceph
- virtual-machines
- image_profiles
- clustering_architecture
- resources_disk_id
- storage_lvm_stripes
- vm_boot_priority
- unix_hotplug_devices
- api_filtering
- instance_nic_network
- clustering_sizing
- firewall_driver
- projects_limits
- limits_hugepages
- projects_restrictions
- volume_snapshot_scheduling
- trust_ca_certificates
- snapshot_disk_usage
- clustering_edit_roles
- resources_usb_pci
- resources_cpu_threads_numa
- resources_cpu_core_die
- api_os
- container_nic_ipvlan_mode
- resources_system
- images_push_relay
- network_dns_search
- container_nic_routed_limits
- instance_nic_bridged_vlan
- network_state_bond_bridge
- usedby_consistency
- custom_block_volumes
- clustering_failure_domains
- resources_gpu_mdev
- console_vga_type
- projects_limits_disk
- network_type_macvlan
- network_type_sriov
- network_type_ovn
- projects_networks
- custom_volume_backup
- backup_override_name
- storage_rsync_compression
- network_type_physical
- network_ovn_nat
- tpm_device_type
- gpu_mdev
- resources_pci_iommu
- resources_network_usb
- resources_disk_address
- network_ovn_dhcp
- projects_limits_instances
- network_state_vlan
- instance_bulk_state_change
- network_gvrp
- instance_pool_move
- gpu_sriov
- pci_device_type
- storage_volume_state
- network_acl
- migration_stateful
- disk_state_quota
- storage_ceph_features
- projects_compression
- certificate_project
- network_ovn_acl
- projects_images_auto_update
- images_default_architecture
- network_ovn_acl_defaults
- gpu_mig
- project_usage
- network_bridge_acl
- warnings
- clustering_join_token
- clustering_description
- server_trusted_proxy
- clustering_update_cert
- storage_api_project
- resources_gpu_usb
- clustering_evacuation
- network_ovn_nat_address
- network_bgp
- network_forward
- custom_volume_refresh
- network_counters_errors_dropped
- metrics
- image_source_project
- clustering_config
- network_peer
- linux_sysctl
- network_dns
- ovn_nic_acceleration
- certificate_self_renewal
- instance_project_move
- storage_volume_project_move
- cloud_init
- network_dns_nat
- database_leader
- instance_all_projects
- clustering_groups
- ceph_rbd_du
- instance_get_full
- qemu_metrics
- gpu_mig_uuid
- event_project
- clustering_evacuation_live
- instance_allow_inconsistent_copy
- network_state_ovn
- storage_volume_api_filtering
- image_restrictions
- storage_zfs_export
- network_dns_records
- storage_zfs_reserve_space
- network_acl_log
- storage_zfs_blocksize
- metrics_cpu_seconds
- instance_snapshot_never
- certificate_token
- instance_nic_routed_neighbor_probe
- event_hub
- agent_nic_config
- projects_restricted_intercept
- metrics_authentication
- images_target_project
- cluster_migration_inconsistent_copy
- cluster_ovn_chassis
- container_syscall_intercept_sched_setscheduler
- storage_lvm_thinpool_metadata_size
- storage_volume_state_total
- instance_file_head
- instances_nic_host_name
- image_copy_profile
- container_syscall_intercept_sysinfo
- clustering_evacuation_mode
- resources_pci_vpd
- qemu_raw_conf
- storage_cephfs_fscache
- network_load_balancer
- vsock_api
- instance_ready_state
- network_bgp_holdtime
- storage_volumes_all_projects
- metrics_memory_oom_total
- storage_buckets
- storage_buckets_create_credentials
- metrics_cpu_effective_total
- projects_networks_restricted_access
- storage_buckets_local
- loki
- acme
- internal_metrics
- cluster_join_token_expiry
- remote_token_expiry
api_status: stable
api_version: "1.0"
auth: trusted
public: false
auth_methods:
- tls
environment:
addresses: <snip>
architectures:
- x86_64
- i686
certificate: <snip>
certificate_fingerprint: <snip>
driver: qemu | lxc
driver_version: 7.1.0 | 5.0.1
firewall: xtables
kernel: Linux
kernel_architecture: x86_64
kernel_features:
idmapped_mounts: "true"
netnsid_getifaddrs: "true"
seccomp_listener: "true"
shiftfs: "false"
uevent_injection: "true"
unpriv_fscaps: "true"
kernel_version: 6.0.7-arch1-1
lxc_features:
cgroup2: "true"
core_scheduling: "true"
devpts_fd: "true"
idmapped_mounts_v2: "true"
mount_injection_file: "true"
network_ipvlan: "true"
network_l2proxy: "true"
network_veth_router: "true"
pidfd: "true"
seccomp_notify: "true"
os_name: Arch Linux
os_version: ""
project: default
server: lxd
server_clustered: false
server_event_mode: full-mesh
server_name: <snip>
server_pid: 603
server_version: "5.7"
storage: ceph
storage_version: 17.2.5
storage_supported_drivers:
- name: lvm
version: 2.03.16(2) (2022-05-18) / 1.02.185 (2022-05-18) / 4.47.0
remote: false
- name: btrfs
version: "6.0"
remote: false
- name: ceph
version: 17.2.5
remote: true
- name: cephfs
version: 17.2.5
remote: true
- name: dir
version: "1"
remote: false
</details>
# Coping from a volume snapshot does not work
I am attempting to copy a volume snapshot to another LXD instance, using the schema provided by the CLI:
Usage:
lxc storage volume copy [<remote>:]<pool>/<volume>[/<snapshot>] [<remote>:]<pool>/<volume> [flags]
Specially: `lxc storage volume copy $A:$pool/$volume/snap0 $B:$pool/$volume`
This fails because it attempts to hit an endpoint that doesn't exist (or, isn't documented at any rate):
DEBUG [2022-11-12T15:59:16Z] Connected to the websocket: wss://$A/1.0/events
DEBUG [2022-11-12T15:59:16Z] Sending request to LXD etag= method=POST url="https://$A/1.0/storage-pools/$pool/volumes/custom/$volume/snap0"
See https://linuxcontainers.org/lxd/docs/master/api/#/storage, search `storage-pools/{name}/volumes/{type}/{volume}` and note the lack of a `/{snapshot}` endpoint.
# Steps to reproduce
1. Create 2 LXD clusters
2. Create a custom volume
3. Snapshot volume
4. Attempt copy snapshot to second cluster: `lxc storage volume copy $A:$pool/$volume/snap0 $B:$pool/$volume`
# Information to attach
<details>
<summary>--debug output of copy attempt</summary>
❯ lxc storage volume copy $A:$pool/$volume/snap0 $B:$pool/$volume
DEBUG [2022-11-12T16:13:59Z] Connecting to a remote LXD over HTTPS
DEBUG [2022-11-12T16:13:59Z] Sending request to LXD etag= method=GET url="https://$A/1.0"
DEBUG [2022-11-12T16:13:59Z] Got response struct from LXD
"config": "<snip>",
"api_extensions": [
"storage_zfs_remove_snapshots",
"container_host_shutdown_timeout",
"container_stop_priority",
"container_syscall_filtering",
"auth_pki",
"container_last_used_at",
"etag",
"patch",
"usb_devices",
"https_allowed_credentials",
"image_compression_algorithm",
"directory_manipulation",
"container_cpu_time",
"storage_zfs_use_refquota",
"storage_lvm_mount_options",
"network",
"profile_usedby",
"container_push",
"container_exec_recording",
"certificate_update",
"container_exec_signal_handling",
"gpu_devices",
"container_image_properties",
"migration_progress",
"id_map",
"network_firewall_filtering",
"network_routes",
"storage",
"file_delete",
"file_append",
"network_dhcp_expiry",
"storage_lvm_vg_rename",
"storage_lvm_thinpool_rename",
"network_vlan",
"image_create_aliases",
"container_stateless_copy",
"container_only_migration",
"storage_zfs_clone_copy",
"unix_device_rename",
"storage_lvm_use_thinpool",
"storage_rsync_bwlimit",
"network_vxlan_interface",
"storage_btrfs_mount_options",
"entity_description",
"image_force_refresh",
"storage_lvm_lv_resizing",
"id_map_base",
"file_symlinks",
"container_push_target",
"network_vlan_physical",
"storage_images_delete",
"container_edit_metadata",
"container_snapshot_stateful_migration",
"storage_driver_ceph",
"storage_ceph_user_name",
"resource_limits",
"storage_volatile_initial_source",
"storage_ceph_force_osd_reuse",
"storage_block_filesystem_btrfs",
"resources",
"kernel_limits",
"storage_api_volume_rename",
"macaroon_authentication",
"network_sriov",
"console",
"restrict_devlxd",
"migration_pre_copy",
"infiniband",
"maas_network",
"devlxd_events",
"proxy",
"network_dhcp_gateway",
"file_get_symlink",
"network_leases",
"unix_device_hotplug",
"storage_api_local_volume_handling",
"operation_description",
"clustering",
"event_lifecycle",
"storage_api_remote_volume_handling",
"nvidia_runtime",
"container_mount_propagation",
"container_backup",
"devlxd_images",
"container_local_cross_pool_handling",
"proxy_unix",
"proxy_udp",
"clustering_join",
"proxy_tcp_udp_multi_port_handling",
"network_state",
"proxy_unix_dac_properties",
"container_protection_delete",
"unix_priv_drop",
"pprof_http",
"proxy_haproxy_protocol",
"network_hwaddr",
"proxy_nat",
"network_nat_order",
"container_full",
"candid_authentication",
"backup_compression",
"candid_config",
"nvidia_runtime_config",
"storage_api_volume_snapshots",
"storage_unmapped",
"projects",
"candid_config_key",
"network_vxlan_ttl",
"container_incremental_copy",
"usb_optional_vendorid",
"snapshot_scheduling",
"snapshot_schedule_aliases",
"container_copy_project",
"clustering_server_address",
"clustering_image_replication",
"container_protection_shift",
"snapshot_expiry",
"container_backup_override_pool",
"snapshot_expiry_creation",
"network_leases_location",
"resources_cpu_socket",
"resources_gpu",
"resources_numa",
"kernel_features",
"id_map_current",
"event_location",
"storage_api_remote_volume_snapshots",
"network_nat_address",
"container_nic_routes",
"rbac",
"cluster_internal_copy",
"seccomp_notify",
"lxc_features",
"container_nic_ipvlan",
"network_vlan_sriov",
"storage_cephfs",
"container_nic_ipfilter",
"resources_v2",
"container_exec_user_group_cwd",
"container_syscall_intercept",
"container_disk_shift",
"storage_shifted",
"resources_infiniband",
"daemon_storage",
"instances",
"image_types",
"resources_disk_sata",
"clustering_roles",
"images_expiry",
"resources_network_firmware",
"backup_compression_algorithm",
"ceph_data_pool_name",
"container_syscall_intercept_mount",
"compression_squashfs",
"container_raw_mount",
"container_nic_routed",
"container_syscall_intercept_mount_fuse",
"container_disk_ceph",
"virtual-machines",
"image_profiles",
"clustering_architecture",
"resources_disk_id",
"storage_lvm_stripes",
"vm_boot_priority",
"unix_hotplug_devices",
"api_filtering",
"instance_nic_network",
"clustering_sizing",
"firewall_driver",
"projects_limits",
"container_syscall_intercept_hugetlbfs",
"limits_hugepages",
"container_nic_routed_gateway",
"projects_restrictions",
"custom_volume_snapshot_expiry",
"volume_snapshot_scheduling",
"trust_ca_certificates",
"snapshot_disk_usage",
"clustering_edit_roles",
"container_nic_routed_host_address",
"container_nic_ipvlan_gateway",
"resources_usb_pci",
"resources_cpu_threads_numa",
"resources_cpu_core_die",
"api_os",
"container_nic_routed_host_table",
"container_nic_ipvlan_host_table",
"container_nic_ipvlan_mode",
"resources_system",
"images_push_relay",
"network_dns_search",
"container_nic_routed_limits",
"instance_nic_bridged_vlan",
"network_state_bond_bridge",
"usedby_consistency",
"custom_block_volumes",
"clustering_failure_domains",
"resources_gpu_mdev",
"console_vga_type",
"projects_limits_disk",
"network_type_macvlan",
"network_type_sriov",
"container_syscall_intercept_bpf_devices",
"network_type_ovn",
"projects_networks",
"projects_networks_restricted_uplinks",
"custom_volume_backup",
"backup_override_name",
"storage_rsync_compression",
"network_type_physical",
"network_ovn_external_subnets",
"network_ovn_nat",
"network_ovn_external_routes_remove",
"tpm_device_type",
"storage_zfs_clone_copy_rebase",
"gpu_mdev",
"resources_pci_iommu",
"resources_network_usb",
"resources_disk_address",
"network_physical_ovn_ingress_mode",
"network_ovn_dhcp",
"network_physical_routes_anycast",
"projects_limits_instances",
"network_state_vlan",
"instance_nic_bridged_port_isolation",
"instance_bulk_state_change",
"network_gvrp",
"instance_pool_move",
"gpu_sriov",
"pci_device_type",
"storage_volume_state",
"network_acl",
"migration_stateful",
"disk_state_quota",
"storage_ceph_features",
"projects_compression",
"projects_images_remote_cache_expiry",
"certificate_project",
"network_ovn_acl",
"projects_images_auto_update",
"projects_restricted_cluster_target",
"images_default_architecture",
"network_ovn_acl_defaults",
"gpu_mig",
"project_usage",
"network_bridge_acl",
"warnings",
"projects_restricted_backups_and_snapshots",
"clustering_join_token",
"clustering_description",
"server_trusted_proxy",
"clustering_update_cert",
"storage_api_project",
"server_instance_driver_operational",
"server_supported_storage_drivers",
"event_lifecycle_requestor_address",
"resources_gpu_usb",
"clustering_evacuation",
"network_ovn_nat_address",
"network_bgp",
"network_forward",
"custom_volume_refresh",
"network_counters_errors_dropped",
"metrics",
"image_source_project",
"clustering_config",
"network_peer",
"linux_sysctl",
"network_dns",
"ovn_nic_acceleration",
"certificate_self_renewal",
"instance_project_move",
"storage_volume_project_move",
"cloud_init",
"network_dns_nat",
"database_leader",
"instance_all_projects",
"clustering_groups",
"ceph_rbd_du",
"instance_get_full",
"qemu_metrics",
"gpu_mig_uuid",
"event_project",
"clustering_evacuation_live",
"instance_allow_inconsistent_copy",
"network_state_ovn",
"storage_volume_api_filtering",
"image_restrictions",
"storage_zfs_export",
"network_dns_records",
"storage_zfs_reserve_space",
"network_acl_log",
"storage_zfs_blocksize",
"metrics_cpu_seconds",
"instance_snapshot_never",
"certificate_token",
"instance_nic_routed_neighbor_probe",
"event_hub",
"agent_nic_config",
"projects_restricted_intercept",
"metrics_authentication",
"images_target_project",
"cluster_migration_inconsistent_copy",
"cluster_ovn_chassis",
"container_syscall_intercept_sched_setscheduler",
"storage_lvm_thinpool_metadata_size",
"storage_volume_state_total",
"instance_file_head",
"instances_nic_host_name",
"image_copy_profile",
"container_syscall_intercept_sysinfo",
"clustering_evacuation_mode",
"resources_pci_vpd",
"qemu_raw_conf",
"storage_cephfs_fscache",
"network_load_balancer",
"vsock_api",
"instance_ready_state",
"network_bgp_holdtime",
"storage_volumes_all_projects",
"metrics_memory_oom_total",
"storage_buckets",
"storage_buckets_create_credentials",
"metrics_cpu_effective_total",
"projects_networks_restricted_access",
"storage_buckets_local",
"loki",
"acme",
"internal_metrics",
"cluster_join_token_expiry",
"remote_token_expiry"
"api_status": "stable",
"api_version": "1.0",
"auth": "trusted",
"public": false,
"auth_methods": [
"tls"
"environment": {
"addresses": [
"<snip>"
"architectures": [
"x86_64",
"i686"
"certificate": "<snip>",
"certificate_fingerprint": "<snip>",
"driver": "lxc | qemu",
"driver_version": "5.0.1 | 7.1.0",
"firewall": "xtables",
"kernel": "Linux",
"kernel_architecture": "x86_64",
"kernel_features": {
"idmapped_mounts": "true",
"netnsid_getifaddrs": "true",
"seccomp_listener": "true",
"seccomp_listener_continue": "true",
"shiftfs": "false",
"uevent_injection": "true",
"unpriv_fscaps": "true"
"kernel_version": "6.0.7-arch1-1",
"lxc_features": {
"cgroup2": "true",
"core_scheduling": "true",
"devpts_fd": "true",
"idmapped_mounts_v2": "true",
"mount_injection_file": "true",
"network_gateway_device_route": "true",
"network_ipvlan": "true",
"network_l2proxy": "true",
"network_phys_macvlan_mtu": "true",
"network_veth_router": "true",
"pidfd": "true",
"seccomp_allow_deny_syntax": "true",
"seccomp_notify": "true",
"seccomp_proxy_send_notify_fd": "true"
"os_name": "Arch Linux",
"os_version": "",
"project": "default",
"server": "lxd",
"server_clustered": false,
"server_event_mode": "full-mesh",
"server_name": "<snip>",
"server_pid": 603,
"server_version": "5.7",
"storage": "ceph",
"storage_version": "17.2.5",
"storage_supported_drivers": [
"Name": "lvm",
"Version": "2.03.16(2) (2022-05-18) / 1.02.185 (2022-05-18) / 4.47.0",
"Remote": false
"Name": "btrfs",
"Version": "6.0",
"Remote": false
"Name": "ceph",
"Version": "17.2.5",
"Remote": true
"Name": "cephfs",
"Remote": true
"Name": "dir",
"Version": "1",
"Remote": false
DEBUG [2022-11-12T16:13:59Z] Sending request to LXD etag= method=GET url="https://$B/1.0"
"config": "<snip>",
"api_extensions": [
"auth_pki",
"etag",
"patch",
"usb_devices",
"network",
"profile_usedby",
"container_push",
"gpu_devices",
"id_map",
"network_routes",
"storage",
"file_delete",
"file_append",
"network_vlan",
"id_map_base",
"file_symlinks",
"resource_limits",
"resources",
"kernel_limits",
"network_sriov",
"console",
"restrict_devlxd",
"infiniband",
"maas_network",
"devlxd_events",
"proxy",
"file_get_symlink",
"network_leases",
"clustering",
"event_lifecycle",
"nvidia_runtime",
"container_backup",
"devlxd_images",
"proxy_unix",
"proxy_udp",
"clustering_join",
"network_state",
"unix_priv_drop",
"pprof_http",
"network_hwaddr",
"proxy_nat",
"container_full",
"candid_config",
"storage_unmapped",
"projects",
"snapshot_expiry",
"resources_gpu",
"resources_numa",
"kernel_features",
"id_map_current",
"event_location",
"rbac",
"seccomp_notify",
"lxc_features",
"storage_cephfs",
"resources_v2",
"storage_shifted",
"daemon_storage",
"instances",
"image_types",
"clustering_roles",
"images_expiry",
"virtual-machines",
"image_profiles",
"vm_boot_priority",
"api_filtering",
"firewall_driver",
"projects_limits",
"limits_hugepages",
"api_os",
"resources_system",
"console_vga_type",
"network_type_ovn",
"network_ovn_nat",
"tpm_device_type",
"gpu_mdev",
"network_ovn_dhcp",
"network_gvrp",
"gpu_sriov",
"pci_device_type",
"network_acl",
"disk_state_quota",
"network_ovn_acl",
"gpu_mig",
"project_usage",
"warnings",
"network_bgp",
"network_forward",
"metrics",
"network_peer",
"linux_sysctl",
"network_dns",
"cloud_init",
"network_dns_nat",
"database_leader",
"ceph_rbd_du",
"qemu_metrics",
"gpu_mig_uuid",
"event_project",
"network_acl_log",
"event_hub",
"agent_nic_config",
"qemu_raw_conf",
"vsock_api",
"storage_buckets",
"loki",
"acme",
"internal_metrics",
"auth": "trusted",
"public": false,
"auth_methods": [
"tls"
"environment": {
"addresses": "<snip>",
"architectures": [
"x86_64",
"i686"
"driver": "qemu | lxc",
"driver_version": "7.1.0 | 5.0.1",
"firewall": "nftables",
"kernel": "Linux",
"shiftfs": "false",
"lxc_features": {
"cgroup2": "true",
"pidfd": "true",
"os_version": "",
"server": "lxd",
"server_pid": 675,
"storage": "ceph",
"Name": "btrfs",
"Version": "6.0",
"Remote": false
"Name": "ceph",
"Remote": true
"Name": "cephfs",
"Remote": true
"Name": "dir",
"Version": "1",
"Remote": false
"Name": "lvm",
"Remote": false
DEBUG [2022-11-12T16:13:59Z] Sending request to LXD etag= method=GET url="https://$A/1.0/storage-pools/$pool/volumes/custom/$volume"
"config": "<snip>",
"description": "",
"name": "$volume",
"type": "custom",
"used_by": "<snip>",
"location": "",
"content_type": "filesystem",
DEBUG [2022-11-12T16:13:59Z] Sending request to LXD etag= method=GET url="https://$A/1.0/storage-pools/$pool/volumes/custom/$volume/snapshots/snap0"
"description": "",
"expires_at": "0001-01-01T00:00:00Z",
"name": "snap0",
"config": "<snip>",
DEBUG [2022-11-12T16:13:59Z] Connected to the websocket: wss://$A/1.0/events
DEBUG [2022-11-12T16:13:59Z] Sending request to LXD etag= method=POST url="https://$A/1.0/storage-pools/$pool/volumes/custom/$volume/snap0"
"name": "$volume/snap0",
"pool": "$pool",
"migration": true,
"target": null,
"volume_only": false
Error: not found
</details>
