Github issues are used for bug reports. For support questions, please use …[our forum](https://discuss.linuxcontainers.org).
Please fill the template below as it will greatly help us track down your issue and reproduce it on our side.
Feel free to remove anything which doesn't apply to you and add more information where it makes sense.
# Required information
* Distribution: ubuntu
* Distribution version: 22.04
* The output of "lxc info" or if that fails:
See the debug output
# Issue description
I have an existing cluster, want to add more members but this fails. Removing existing members passes correctly, but can also not be re-added. There is this error at the end:
Error: Failed to join cluster: Failed to initialize member: Failed to initialize storage pools and networks: Failed to update local member project "default": You can't change the features of the default project
# Steps to reproduce
1. lxc cluster remove b104
2. on machine b104:
3. snap remove lxd;snap install lxd;zfs destroy -r tank/lxd;zfs create tank/lxd
4. on a machine of the cluster, get the token: lxc cluster add b104
5. on b104 with lxd init --debug:
yes
yes
yes
token
yes
tank/lxd
tank/lxd
yes
yes
I tried to check this issue on a second cluster which has the same versions of OS, kernel and lxd, but above setup steps works then. I suspect something in the lxd database. Also, I compared the debug outputs of the 2 clusters, but nothing really gives some add debug output, except the error.
Here is the output of lxd init --debug:
Again, thanks in advance for any help and the amazing work!
DEBUG [2022-08-12T09:51:35+02:00] Sending request to LXD etag= method=GET url="http://unix.socket/1.0"
DEBUG [2022-08-12T09:51:37+02:00] Got response struct from LXD
"config": {},
"api_extensions": [
"storage_zfs_remove_snapshots",
"container_host_shutdown_timeout",
"container_stop_priority",
"container_syscall_filtering",
"auth_pki",
"container_last_used_at",
"etag",
"patch",
"usb_devices",
"https_allowed_credentials",
"image_compression_algorithm",
"directory_manipulation",
"container_cpu_time",
"storage_zfs_use_refquota",
"storage_lvm_mount_options",
"network",
"profile_usedby",
"container_push",
"container_exec_recording",
"certificate_update",
"container_exec_signal_handling",
"gpu_devices",
"container_image_properties",
"migration_progress",
"id_map",
"network_firewall_filtering",
"network_routes",
"storage",
"file_delete",
"file_append",
"network_dhcp_expiry",
"storage_lvm_vg_rename",
"storage_lvm_thinpool_rename",
"network_vlan",
"image_create_aliases",
"container_stateless_copy",
"container_only_migration",
"storage_zfs_clone_copy",
"unix_device_rename",
"storage_lvm_use_thinpool",
"storage_rsync_bwlimit",
"network_vxlan_interface",
"storage_btrfs_mount_options",
"entity_description",
"image_force_refresh",
"storage_lvm_lv_resizing",
"id_map_base",
"file_symlinks",
"container_push_target",
"network_vlan_physical",
"storage_images_delete",
"container_edit_metadata",
"container_snapshot_stateful_migration",
"storage_driver_ceph",
"storage_ceph_user_name",
"resource_limits",
"storage_volatile_initial_source",
"storage_ceph_force_osd_reuse",
"storage_block_filesystem_btrfs",
"resources",
"kernel_limits",
"storage_api_volume_rename",
"macaroon_authentication",
"network_sriov",
"console",
"restrict_devlxd",
"migration_pre_copy",
"infiniband",
"maas_network",
"devlxd_events",
"proxy",
"network_dhcp_gateway",
"file_get_symlink",
"network_leases",
"unix_device_hotplug",
"storage_api_local_volume_handling",
"operation_description",
"clustering",
"event_lifecycle",
"storage_api_remote_volume_handling",
"nvidia_runtime",
"container_mount_propagation",
"container_backup",
"devlxd_images",
"container_local_cross_pool_handling",
"proxy_unix",
"proxy_udp",
"clustering_join",
"proxy_tcp_udp_multi_port_handling",
"network_state",
"proxy_unix_dac_properties",
"container_protection_delete",
"unix_priv_drop",
"pprof_http",
"proxy_haproxy_protocol",
"network_hwaddr",
"proxy_nat",
"network_nat_order",
"container_full",
"candid_authentication",
"backup_compression",
"candid_config",
"nvidia_runtime_config",
"storage_api_volume_snapshots",
"storage_unmapped",
"projects",
"candid_config_key",
"network_vxlan_ttl",
"container_incremental_copy",
"usb_optional_vendorid",
"snapshot_scheduling",
"snapshot_schedule_aliases",
"container_copy_project",
"clustering_server_address",
"clustering_image_replication",
"container_protection_shift",
"snapshot_expiry",
"container_backup_override_pool",
"snapshot_expiry_creation",
"network_leases_location",
"resources_cpu_socket",
"resources_gpu",
"resources_numa",
"kernel_features",
"id_map_current",
"event_location",
"storage_api_remote_volume_snapshots",
"network_nat_address",
"container_nic_routes",
"rbac",
"cluster_internal_copy",
"seccomp_notify",
"lxc_features",
"container_nic_ipvlan",
"network_vlan_sriov",
"storage_cephfs",
"container_nic_ipfilter",
"resources_v2",
"container_exec_user_group_cwd",
"container_syscall_intercept",
"container_disk_shift",
"storage_shifted",
"resources_infiniband",
"daemon_storage",
"instances",
"image_types",
"resources_disk_sata",
"clustering_roles",
"images_expiry",
"resources_network_firmware",
"backup_compression_algorithm",
"ceph_data_pool_name",
"container_syscall_intercept_mount",
"compression_squashfs",
"container_raw_mount",
"container_nic_routed",
"container_syscall_intercept_mount_fuse",
"container_disk_ceph",
"virtual-machines",
"image_profiles",
"clustering_architecture",
"resources_disk_id",
"storage_lvm_stripes",
"vm_boot_priority",
"unix_hotplug_devices",
"api_filtering",
"instance_nic_network",
"clustering_sizing",
"firewall_driver",
"projects_limits",
"container_syscall_intercept_hugetlbfs",
"limits_hugepages",
"container_nic_routed_gateway",
"projects_restrictions",
"custom_volume_snapshot_expiry",
"volume_snapshot_scheduling",
"trust_ca_certificates",
"snapshot_disk_usage",
"clustering_edit_roles",
"container_nic_routed_host_address",
"container_nic_ipvlan_gateway",
"resources_usb_pci",
"resources_cpu_threads_numa",
"resources_cpu_core_die",
"api_os",
"container_nic_routed_host_table",
"container_nic_ipvlan_host_table",
"container_nic_ipvlan_mode",
"resources_system",
"images_push_relay",
"network_dns_search",
"container_nic_routed_limits",
"instance_nic_bridged_vlan",
"network_state_bond_bridge",
"usedby_consistency",
"custom_block_volumes",
"clustering_failure_domains",
"resources_gpu_mdev",
"console_vga_type",
"projects_limits_disk",
"network_type_macvlan",
"network_type_sriov",
"container_syscall_intercept_bpf_devices",
"network_type_ovn",
"projects_networks",
"projects_networks_restricted_uplinks",
"custom_volume_backup",
"backup_override_name",
"storage_rsync_compression",
"network_type_physical",
"network_ovn_external_subnets",
"network_ovn_nat",
"network_ovn_external_routes_remove",
"tpm_device_type",
"storage_zfs_clone_copy_rebase",
"gpu_mdev",
"resources_pci_iommu",
"resources_network_usb",
"resources_disk_address",
"network_physical_ovn_ingress_mode",
"network_ovn_dhcp",
"network_physical_routes_anycast",
"projects_limits_instances",
"network_state_vlan",
"instance_nic_bridged_port_isolation",
"instance_bulk_state_change",
"network_gvrp",
"instance_pool_move",
"gpu_sriov",
"pci_device_type",
"storage_volume_state",
"network_acl",
"migration_stateful",
"disk_state_quota",
"storage_ceph_features",
"projects_compression",
"projects_images_remote_cache_expiry",
"certificate_project",
"network_ovn_acl",
"projects_images_auto_update",
"projects_restricted_cluster_target",
"images_default_architecture",
"network_ovn_acl_defaults",
"gpu_mig",
"project_usage",
"network_bridge_acl",
"warnings",
"projects_restricted_backups_and_snapshots",
"clustering_join_token",
"clustering_description",
"server_trusted_proxy",
"clustering_update_cert",
"storage_api_project",
"server_instance_driver_operational",
"server_supported_storage_drivers",
"event_lifecycle_requestor_address",
"resources_gpu_usb",
"clustering_evacuation",
"network_ovn_nat_address",
"network_bgp",
"network_forward",
"custom_volume_refresh",
"network_counters_errors_dropped",
"metrics",
"image_source_project",
"clustering_config",
"network_peer",
"linux_sysctl",
"network_dns",
"ovn_nic_acceleration",
"certificate_self_renewal",
"instance_project_move",
"storage_volume_project_move",
"cloud_init",
"network_dns_nat",
"database_leader",
"instance_all_projects",
"clustering_groups",
"ceph_rbd_du",
"instance_get_full",
"qemu_metrics",
"gpu_mig_uuid",
"event_project",
"clustering_evacuation_live",
"instance_allow_inconsistent_copy",
"network_state_ovn",
"storage_volume_api_filtering",
"image_restrictions",
"storage_zfs_export",
"network_dns_records",
"storage_zfs_reserve_space",
"network_acl_log",
"storage_zfs_blocksize",
"metrics_cpu_seconds",
"instance_snapshot_never",
"certificate_token",
"instance_nic_routed_neighbor_probe",
"event_hub",
"agent_nic_config",
"projects_restricted_intercept",
"metrics_authentication",
"images_target_project",
"cluster_migration_inconsistent_copy",
"cluster_ovn_chassis",
"container_syscall_intercept_sched_setscheduler",
"storage_lvm_thinpool_metadata_size",
"storage_volume_state_total",
"instance_file_head",
"instances_nic_host_name",
"image_copy_profile",
"container_syscall_intercept_sysinfo",
"clustering_evacuation_mode",
"resources_pci_vpd",
"qemu_raw_conf",
"storage_cephfs_fscache",
"network_load_balancer",
"vsock_api"
"api_status": "stable",
"api_version": "1.0",
"auth": "trusted",
"public": false,
"auth_methods": [
"tls"
"environment": {
"addresses": [],
"architectures": [
"x86_64",
"i686"
"certificate": "-----BEGIN CERTIFICATE-----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\n2NRDRhQwcwlCPmaQS8ffspqF963h1lVugDeqGPSmagkC\n-----END CERTIFICATE-----\n",
"certificate_fingerprint": "79718261467bd8358cc6efa171696c3e5ede5bf0872383d48bf1e169dbee2a03",
"driver": "lxc | qemu",
"driver_version": "5.0.1 | 7.0.0",
"firewall": "nftables",
"kernel": "Linux",
"kernel_architecture": "x86_64",
"kernel_features": {
"idmapped_mounts": "true",
"netnsid_getifaddrs": "true",
"seccomp_listener": "true",
"seccomp_listener_continue": "true",
"shiftfs": "false",
"uevent_injection": "true",
"unpriv_fscaps": "true"
"kernel_version": "5.15.0-46-generic",
"lxc_features": {
"cgroup2": "true",
"core_scheduling": "true",
"devpts_fd": "true",
"idmapped_mounts_v2": "true",
"mount_injection_file": "true",
"network_gateway_device_route": "true",
"network_ipvlan": "true",
"network_l2proxy": "true",
"network_phys_macvlan_mtu": "true",
"network_veth_router": "true",
"pidfd": "true",
"seccomp_allow_deny_syntax": "true",
"seccomp_notify": "true",
"seccomp_proxy_send_notify_fd": "true"
"os_name": "Ubuntu",
"os_version": "22.04",
"project": "default",
"server": "lxd",
"server_clustered": false,
"server_event_mode": "full-mesh",
"server_name": "b104",
"server_pid": 12977,
"server_version": "5.4",
"storage": "",
"storage_version": "",
"storage_supported_drivers": [
"Name": "btrfs",
"Version": "5.4.1",
"Remote": false
"Name": "cephfs",
"Version": "15.2.16",
"Remote": true
"Name": "dir",
"Version": "1",
"Remote": false
"Name": "lvm",
"Version": "2.03.07(2) (2019-11-30) / 1.02.167 (2019-11-30) / 4.45.0",
"Remote": false
"Name": "zfs",
"Version": "2.1.4-0ubuntu0.1",
"Remote": false
"Name": "ceph",
"Remote": true
DEBUG [2022-08-12T09:51:37+02:00] Sending request to LXD etag= method=GET url="http://unix.socket/1.0"
"config": {},
"api_extensions": [
"auth_pki",
"etag",
"patch",
"usb_devices",
"network",
"profile_usedby",
"container_push",
"gpu_devices",
"id_map",
"network_routes",
"storage",
"file_delete",
"file_append",
"network_vlan",
"id_map_base",
"file_symlinks",
"resource_limits",
"resources",
"kernel_limits",
"network_sriov",
"console",
"restrict_devlxd",
"infiniband",
"maas_network",
"devlxd_events",
"proxy",
"file_get_symlink",
"network_leases",
"clustering",
"event_lifecycle",
"nvidia_runtime",
"container_backup",
"devlxd_images",
"proxy_unix",
"proxy_udp",
"clustering_join",
"network_state",
"unix_priv_drop",
"pprof_http",
"network_hwaddr",
"proxy_nat",
"container_full",
"candid_config",
"storage_unmapped",
"projects",
"snapshot_expiry",
"resources_gpu",
"resources_numa",
"kernel_features",
"id_map_current",
"event_location",
"rbac",
"seccomp_notify",
"lxc_features",
"storage_cephfs",
"resources_v2",
"storage_shifted",
"daemon_storage",
"instances",
"image_types",
"clustering_roles",
"images_expiry",
"virtual-machines",
"image_profiles",
"vm_boot_priority",
"api_filtering",
"firewall_driver",
"projects_limits",
"limits_hugepages",
"api_os",
"resources_system",
"console_vga_type",
"network_type_ovn",
"network_ovn_nat",
"tpm_device_type",
"gpu_mdev",
"network_ovn_dhcp",
"network_gvrp",
"gpu_sriov",
"pci_device_type",
"network_acl",
"disk_state_quota",
"network_ovn_acl",
"gpu_mig",
"project_usage",
"warnings",
"network_bgp",
"network_forward",
"metrics",
"network_peer",
"linux_sysctl",
"network_dns",
"cloud_init",
"network_dns_nat",
"database_leader",
"ceph_rbd_du",
"qemu_metrics",
"gpu_mig_uuid",
"event_project",
"network_acl_log",
"event_hub",
"agent_nic_config",
"qemu_raw_conf",
"vsock_api"
"auth": "trusted",
"public": false,
"auth_methods": [
"tls"
"environment": {
"addresses": [],
"architectures": [
"x86_64",
"i686"
"kernel": "Linux",
"shiftfs": "false",
"lxc_features": {
"cgroup2": "true",
"pidfd": "true",
"server": "lxd",
"storage": "",
"Name": "btrfs",
"Version": "5.4.1",
"Remote": false
"Name": "cephfs",
"Remote": true
"Name": "dir",
"Version": "1",
"Remote": false
"Name": "lvm",
"Remote": false
"Name": "zfs",
"Remote": false
"Name": "ceph",
"Remote": true
Would you like to use LXD clustering? (yes/no) [default=no]: What IP address or DNS name should be used to reach this node? [default=10.0.127.63]: Are you joining an existing cluster? (yes/no) [default=no]: Do you have a join token? (yes/no/[token]) [default=no]: Please provide join token: All existing data is lost when joining a cluster, continue? (yes/no) [default=no] DEBUG [2022-08-12T09:51:37+02:00] Connecting to a remote LXD over HTTPS
DEBUG [2022-08-12T09:51:37+02:00] Sending request to LXD etag= method=GET url="https://10.0.127.243:8443/1.0"
"config": null,
"api_extensions": [
"auth_pki",
"etag",
"patch",
"usb_devices",
"network",
"profile_usedby",
"container_push",
"gpu_devices",
"id_map",
"network_routes",
"storage",
"file_delete",
"file_append",
"network_vlan",
"id_map_base",
"file_symlinks",
"resource_limits",
"resources",
"kernel_limits",
"network_sriov",
"console",
"restrict_devlxd",
"infiniband",
"maas_network",
"devlxd_events",
"proxy",
"file_get_symlink",
"network_leases",
"clustering",
"event_lifecycle",
"nvidia_runtime",
"container_backup",
"devlxd_images",
"proxy_unix",
"proxy_udp",
"clustering_join",
"network_state",
"unix_priv_drop",
"pprof_http",
"network_hwaddr",
"proxy_nat",
"container_full",
"candid_config",
"storage_unmapped",
"projects",
"snapshot_expiry",
"resources_gpu",
"resources_numa",
"kernel_features",
"id_map_current",
"event_location",
"rbac",
"seccomp_notify",
"lxc_features",
"storage_cephfs",
"resources_v2",
"storage_shifted",
"daemon_storage",
"instances",
"image_types",
"clustering_roles",
"images_expiry",
"virtual-machines",
"image_profiles",
"vm_boot_priority",
"api_filtering",
"firewall_driver",
"projects_limits",
"limits_hugepages",
"api_os",
"resources_system",
"console_vga_type",
"network_type_ovn",
"network_ovn_nat",
"tpm_device_type",
"gpu_mdev",
"network_ovn_dhcp",
"network_gvrp",
"gpu_sriov",
"pci_device_type",
"network_acl",
"disk_state_quota",
"network_ovn_acl",
"gpu_mig",
"project_usage",
"warnings",
"network_bgp",
"network_forward",
"metrics",
"network_peer",
"linux_sysctl",
"network_dns",
"cloud_init",
"network_dns_nat",
"database_leader",
"ceph_rbd_du",
"qemu_metrics",
"gpu_mig_uuid",
"event_project",
"network_acl_log",
"event_hub",
"agent_nic_config",
"qemu_raw_conf",
"vsock_api"
"auth": "untrusted",
"public": false,
"auth_methods": [
"tls"
"environment": {
"addresses": null,
"architectures": null,
"certificate": "",
"certificate_fingerprint": "",
"driver": "",
"driver_version": "",
"firewall": "",
"kernel": "",
"kernel_architecture": "",
"kernel_features": null,
"kernel_version": "",
"lxc_features": null,
"os_name": "",
"os_version": "",
"project": "",
"server": "",
"server_event_mode": "",
"server_name": "",
"server_pid": 0,
"server_version": "",
"storage": "",
"storage_supported_drivers": null
DEBUG [2022-08-12T09:51:37+02:00] Sending request to LXD etag= method=POST url="https://10.0.127.243:8443/1.0/certificates"
"name": "b104",
"type": "server",
"restricted": false,
"projects": null,
"certificate": "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",
"password": "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",
"token": false
"config": {
"cluster.https_address": "10.0.127.243:8443",
"core.https_address": "10.0.127.243:8443",
"core.trust_password": true,
"images.auto_update_interval": "0"
"api_extensions": [
"auth_pki",
"etag",
"patch",
"usb_devices",
"network",
"profile_usedby",
"container_push",
"gpu_devices",
"id_map",
"network_routes",
"storage",
"file_delete",
"file_append",
"network_vlan",
"id_map_base",
"file_symlinks",
"resource_limits",
"resources",
"kernel_limits",
"network_sriov",
"console",
"restrict_devlxd",
"infiniband",
"maas_network",
"devlxd_events",
"proxy",
"file_get_symlink",
"network_leases",
"clustering",
"event_lifecycle",
"nvidia_runtime",
"container_backup",
"devlxd_images",
"proxy_unix",
"proxy_udp",
"clustering_join",
"network_state",
"unix_priv_drop",
"pprof_http",
"network_hwaddr",
"proxy_nat",
"container_full",
"candid_config",
"storage_unmapped",
"projects",
"snapshot_expiry",
"resources_gpu",
"resources_numa",
"kernel_features",
"id_map_current",
"event_location",
"rbac",
"seccomp_notify",
"lxc_features",
"storage_cephfs",
"resources_v2",
"storage_shifted",
"daemon_storage",
"instances",
"image_types",
"clustering_roles",
"images_expiry",
"virtual-machines",
"image_profiles",
"vm_boot_priority",
"api_filtering",
"firewall_driver",
"projects_limits",
"limits_hugepages",
"api_os",
"resources_system",
"console_vga_type",
"network_type_ovn",
"network_ovn_nat",
"tpm_device_type",
"gpu_mdev",
"network_ovn_dhcp",
"network_gvrp",
"gpu_sriov",
"pci_device_type",
"network_acl",
"disk_state_quota",
"network_ovn_acl",
"gpu_mig",
"project_usage",
"warnings",
"network_bgp",
"network_forward",
"metrics",
"network_peer",
"linux_sysctl",
"network_dns",
"cloud_init",
"network_dns_nat",
"database_leader",
"ceph_rbd_du",
"qemu_metrics",
"gpu_mig_uuid",
"event_project",
"network_acl_log",
"event_hub",
"agent_nic_config",
"qemu_raw_conf",
"vsock_api"
"auth": "trusted",
"public": false,
"auth_methods": [
"tls"
"environment": {
"addresses": [
"10.0.127.243:8443"
"architectures": [
"x86_64",
"i686"
"certificate": "-----BEGIN CERTIFICATE-----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\nRGLxv2CfyOmWDN1j05Ss1Zv+k5HWXFTe57ZJk9VetgjG2A==\n-----END CERTIFICATE-----\n",
"certificate_fingerprint": "36556f6577d083457439e86f9bb4d347973c4022bcb4d0d4b8b12b71c7120722",
"driver": "qemu | lxc",
"driver_version": "7.0.0 | 5.0.1",
"kernel": "Linux",
"shiftfs": "false",
"lxc_features": {
"cgroup2": "true",
"pidfd": "true",
"server": "lxd",
"server_clustered": true,
"server_name": "b403",
"server_pid": 3799,
"storage": "zfs",
"storage_version": "2.1.4-0ubuntu0.1",
"Name": "zfs",
"Remote": false
"Name": "ceph",
"Remote": true
"Name": "btrfs",
"Version": "5.4.1",
"Remote": false
"Name": "cephfs",
"Remote": true
"Name": "dir",
"Version": "1",
"Remote": false
"Name": "lvm",
"Remote": false
DEBUG [2022-08-12T09:51:37+02:00] Sending request to LXD etag= method=GET url="https://10.0.127.243:8443/1.0/cluster"
"enabled": true,
"member_config": [
"entity": "storage-pool",
"name": "local",
"key": "source",
"value": "",
"description": "\"source\" property for storage pool \"local\""
"name": "local",
"key": "zfs.pool_name",
"value": "",
"description": "\"zfs.pool_name\" property for storage pool \"local\""
Choose "source" property for storage pool "local": Choose "zfs.pool_name" property for storage pool "local": Would you like a YAML "lxd init" preseed to be printed? (yes/no) [default=no]: config: {}
networks: []
storage_pools: []
profiles: []
projects: []
cluster:
server_name: b104
enabled: true
member_config:
- entity: storage-pool
key: source
value: tank/lxd
description: '"source" property for storage pool "local"'
key: zfs.pool_name
value: tank/lxd
description: '"zfs.pool_name" property for storage pool "local"'
cluster_address: 10.0.127.243:8443
cluster_certificate: |
server_address: 10.0.127.63:8443
cluster_password: ""
cluster_certificate_path: ""
cluster_token: ""
DEBUG [2022-08-12T09:51:37+02:00] Connected to the websocket: ws://unix.socket/1.0/events
DEBUG [2022-08-12T09:51:37+02:00] Sending request to LXD etag= method=PUT url="http://unix.socket/1.0/cluster"
"enabled": true,
"member_config": [
"name": "local",
"key": "source",
"value": "tank/lxd",
"name": "local",
"cluster_address": "10.0.127.243:8443",
"cluster_certificate": "-----BEGIN CERTIFICATE-----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\nRGLxv2CfyOmWDN1j05Ss1Zv+k5HWXFTe57ZJk9VetgjG2A==\n-----END CERTIFICATE-----\n",
"server_address": "10.0.127.63:8443",
"cluster_password": ""
DEBUG [2022-08-12T09:51:37+02:00] Got operation from LXD
"id": "27694780-78cc-4ca6-8b99-9d12bcbe71e0",
"class": "task",
"description": "Joining cluster",
"created_at": "2022-08-12T09:51:37.860941757+02:00",
"updated_at": "2022-08-12T09:51:37.860941757+02:00",
"status": "Running",
"status_code": 103,
"resources": {
"cluster": null
"metadata": null,
"may_cancel": false,
"err": "",
"location": "none"
DEBUG [2022-08-12T09:51:37+02:00] Sending request to LXD etag= method=GET url="http://unix.socket/1.0/operations/27694780-78cc-4ca6-8b99-9d12bcbe71e0"
"class": "task",
"status_code": 103,
"resources": {
"cluster": null
"metadata": null,
"err": "",
"location": "none"
