Hi
A bit of context: I have an container that’s been running for a while and stated life on an earlier version of LXD (not sure which one, but the container image was 17.10, and is now upgraded to 20.04).
I want to share a disk (custom) volume between two containers. The above one, and a new one created on LXD 4.14:
~$ lxc version
Client version: 4.14
Server version: 4.14
The volume is attached to the new container, and then I wanted to add it to the older container:
$ lxc config device add syncthing paperless disk pool=default source=paperless-ng-syncthing path=/srv/paperless-ng
Error: Failed to start device "paperless": Failed shifting storage volume "paperless-ng-syncthing" of type "custom" on storage pool "default": Idmaps of container and storage volume are not identical
So I checked the idmaps of the two containers. First the old one:
volatile.idmap.base: "0"
volatile.idmap.current: '[{"Isuid":true,"Isgid":false,"Hostid":100000,"Nsid":0,"Maprange":65536},{"Isuid":false,"Isgid":true,"Hostid":100000,"Nsid":0,"Maprange":65536}]'
volatile.idmap.next: '[{"Isuid":true,"Isgid":false,"Hostid":100000,"Nsid":0,"Maprange":65536},{"Isuid":false,"Isgid":true,"Hostid":100000,"Nsid":0,"Maprange":65536}]'
volatile.last_state.idmap: '[{"Isuid":true,"Isgid":false,"Hostid":100000,"Nsid":0,"Maprange":65536},{"Isuid":false,"Isgid":true,"Hostid":100000,"Nsid":0,"Maprange":65536}]'
And now the new one:
The difference seems to be that the old one has a Maprange
of 65536
and the new one is 1000000000
Is it possible to update the old one to match the new one, or is there another trick to get the volume attached to old container?
Thanks.
