I fail to see how this is caused by cgroups. They seem to be setup correctly. The eexist on last error is only happening because a prior container start failed and the cgroups did not get cleaned up properly.
Clearing out the cgroup files did not alleviate the problem. Also upon the first run of the container after boot, there were no such errors as the files didn’t exist.
I might be able to set up a test machine at some point, but I’m fighting fires left and right here right now. Thanks for your reply.
Then what’s the startup failure in that log? That’s the only thing that appears to cause an error and tear down.
Here’s the full trace I have from when I attempted to start a stock Ubuntu container after having purged the cgroup dirs that it was complaining about in the other logs:
[root@team-dev2 user]# lxc info --show-log wdelgenio-test1
Remote: unix://
Created: 2019/07/24 14:03 UTC
Status: Stopped
Type: persistent
Profiles: default
Log:
lxc wdelgenio-test1 20190724143740.776 TRACE commands - commands.c:lxc_cmd:303 - Connection refused - Command "get_state" failed to connect command socket
lxc wdelgenio-test1 20190724143740.776 TRACE start - start.c:lxc_init_handler:774 - Created anonymous pair {3,5} of unix sockets
lxc wdelgenio-test1 20190724143740.776 TRACE commands - commands.c:lxc_cmd_init:1310 - Created abstract unix socket "/var/snap/lxd/common/lxd/containers/wdelgenio-test1/command"
lxc wdelgenio-test1 20190724143740.776 TRACE start - start.c:lxc_init_handler:786 - Unix domain socket 7 for command server is ready
lxc wdelgenio-test1 20190724143740.777 INFO lxccontainer - lxccontainer.c:do_lxcapi_start:993 - Set process title to [lxc monitor] /var/snap/lxd/common/lxd/containers wdelgenio-test1
lxc wdelgenio-test1 20190724143740.778 INFO start - start.c:lxc_check_inherited:311 - Closed inherited fd 4
lxc wdelgenio-test1 20190724143740.783 TRACE start - start.c:lxc_start:2145 - Doing lxc_start
lxc wdelgenio-test1 20190724143740.783 INFO lsm - lsm/lsm.c:lsm_init:50 - LSM security driver nop
lxc wdelgenio-test1 20190724143740.783 TRACE start - start.c:lxc_init:805 - Initialized LSM
lxc wdelgenio-test1 20190724143740.783 TRACE seccomp - seccomp.c:get_new_ctx:488 - Added arch 2 to main seccomp context
lxc wdelgenio-test1 20190724143740.783 TRACE seccomp - seccomp.c:get_new_ctx:496 - Removed native arch from main seccomp context
lxc wdelgenio-test1 20190724143740.783 TRACE seccomp - seccomp.c:get_new_ctx:488 - Added arch 3 to main seccomp context
lxc wdelgenio-test1 20190724143740.783 TRACE seccomp - seccomp.c:get_new_ctx:501 - Arch 4 already present in main seccomp context
lxc wdelgenio-test1 20190724143740.783 INFO seccomp - seccomp.c:parse_config_v2:789 - Processing "reject_force_umount # comment this to allow umount -f; not recommended"
lxc wdelgenio-test1 20190724143740.783 INFO seccomp - seccomp.c:do_resolve_add_rule:535 - Set seccomp rule to reject force umounts
lxc wdelgenio-test1 20190724143740.783 INFO seccomp - seccomp.c:parse_config_v2:975 - Added native rule for arch 0 for reject_force_umount action 0(kill)
lxc wdelgenio-test1 20190724143740.784 INFO seccomp - seccomp.c:do_resolve_add_rule:535 - Set seccomp rule to reject force umounts
lxc wdelgenio-test1 20190724143740.784 INFO seccomp - seccomp.c:parse_config_v2:984 - Added compat rule for arch 1073741827 for reject_force_umount action 0(kill)
lxc wdelgenio-test1 20190724143740.784 INFO seccomp - seccomp.c:parse_config_v2:994 - Added compat rule for arch 1073741886 for reject_force_umount action 0(kill)
lxc wdelgenio-test1 20190724143740.784 INFO seccomp - seccomp.c:parse_config_v2:1004 - Added native rule for arch -1073741762 for reject_force_umount action 0(kill)
lxc wdelgenio-test1 20190724143740.784 INFO seccomp - seccomp.c:parse_config_v2:789 - Processing "[all]"
lxc wdelgenio-test1 20190724143740.784 INFO seccomp - seccomp.c:parse_config_v2:789 - Processing "kexec_load errno 38"
lxc wdelgenio-test1 20190724143740.784 INFO seccomp - seccomp.c:parse_config_v2:975 - Added native rule for arch 0 for kexec_load action 327718(errno)
lxc wdelgenio-test1 20190724143740.784 INFO seccomp - seccomp.c:parse_config_v2:984 - Added compat rule for arch 1073741827 for kexec_load action 327718(errno)
lxc wdelgenio-test1 20190724143740.784 INFO seccomp - seccomp.c:parse_config_v2:994 - Added compat rule for arch 1073741886 for kexec_load action 327718(errno)
lxc wdelgenio-test1 20190724143740.784 INFO seccomp - seccomp.c:parse_config_v2:1004 - Added native rule for arch -1073741762 for kexec_load action 327718(errno)
lxc wdelgenio-test1 20190724143740.784 INFO seccomp - seccomp.c:parse_config_v2:789 - Processing "open_by_handle_at errno 38"
lxc wdelgenio-test1 20190724143740.784 INFO seccomp - seccomp.c:parse_config_v2:975 - Added native rule for arch 0 for open_by_handle_at action 327718(errno)
lxc wdelgenio-test1 20190724143740.784 INFO seccomp - seccomp.c:parse_config_v2:984 - Added compat rule for arch 1073741827 for open_by_handle_at action 327718(errno)
lxc wdelgenio-test1 20190724143740.784 INFO seccomp - seccomp.c:parse_config_v2:994 - Added compat rule for arch 1073741886 for open_by_handle_at action 327718(errno)
lxc wdelgenio-test1 20190724143740.784 INFO seccomp - seccomp.c:parse_config_v2:1004 - Added native rule for arch -1073741762 for open_by_handle_at action 327718(errno)
lxc wdelgenio-test1 20190724143740.784 INFO seccomp - seccomp.c:parse_config_v2:789 - Processing "init_module errno 38"
lxc wdelgenio-test1 20190724143740.784 INFO seccomp - seccomp.c:parse_config_v2:975 - Added native rule for arch 0 for init_module action 327718(errno)
lxc wdelgenio-test1 20190724143740.784 INFO seccomp - seccomp.c:parse_config_v2:984 - Added compat rule for arch 1073741827 for init_module action 327718(errno)
lxc wdelgenio-test1 20190724143740.784 INFO seccomp - seccomp.c:parse_config_v2:994 - Added compat rule for arch 1073741886 for init_module action 327718(errno)
lxc wdelgenio-test1 20190724143740.784 INFO seccomp - seccomp.c:parse_config_v2:1004 - Added native rule for arch -1073741762 for init_module action 327718(errno)
lxc wdelgenio-test1 20190724143740.784 INFO seccomp - seccomp.c:parse_config_v2:789 - Processing "finit_module errno 38"
lxc wdelgenio-test1 20190724143740.784 INFO seccomp - seccomp.c:parse_config_v2:975 - Added native rule for arch 0 for finit_module action 327718(errno)
lxc wdelgenio-test1 20190724143740.784 INFO seccomp - seccomp.c:parse_config_v2:984 - Added compat rule for arch 1073741827 for finit_module action 327718(errno)
lxc wdelgenio-test1 20190724143740.784 INFO seccomp - seccomp.c:parse_config_v2:994 - Added compat rule for arch 1073741886 for finit_module action 327718(errno)
lxc wdelgenio-test1 20190724143740.784 INFO seccomp - seccomp.c:parse_config_v2:1004 - Added native rule for arch -1073741762 for finit_module action 327718(errno)
lxc wdelgenio-test1 20190724143740.784 INFO seccomp - seccomp.c:parse_config_v2:789 - Processing "delete_module errno 38"
lxc wdelgenio-test1 20190724143740.784 INFO seccomp - seccomp.c:parse_config_v2:975 - Added native rule for arch 0 for delete_module action 327718(errno)
lxc wdelgenio-test1 20190724143740.784 INFO seccomp - seccomp.c:parse_config_v2:984 - Added compat rule for arch 1073741827 for delete_module action 327718(errno)
lxc wdelgenio-test1 20190724143740.784 INFO seccomp - seccomp.c:parse_config_v2:994 - Added compat rule for arch 1073741886 for delete_module action 327718(errno)
lxc wdelgenio-test1 20190724143740.784 INFO seccomp - seccomp.c:parse_config_v2:1004 - Added native rule for arch -1073741762 for delete_module action 327718(errno)
lxc wdelgenio-test1 20190724143740.784 INFO seccomp - seccomp.c:parse_config_v2:1008 - Merging compat seccomp contexts into main context
lxc wdelgenio-test1 20190724143740.784 TRACE seccomp - seccomp.c:parse_config_v2:1018 - Merged first compat seccomp context into main context
lxc wdelgenio-test1 20190724143740.784 TRACE seccomp - seccomp.c:parse_config_v2:1034 - Merged second compat seccomp context into main context
lxc wdelgenio-test1 20190724143740.784 TRACE start - start.c:lxc_init:812 - Read seccomp policy
lxc wdelgenio-test1 20190724143740.784 TRACE start - start.c:lxc_serve_state_clients:474 - Set container state to STARTING
lxc wdelgenio-test1 20190724143740.784 TRACE start - start.c:lxc_serve_state_clients:477 - No state clients registered
lxc wdelgenio-test1 20190724143740.784 TRACE start - start.c:lxc_init:820 - Set container state to "STARTING"
lxc wdelgenio-test1 20190724143740.784 TRACE start - start.c:lxc_init:883 - Set environment variables
lxc wdelgenio-test1 20190724143740.784 INFO conf - conf.c:run_script_argv:374 - Executing script "/proc/439929/exe callhook /var/snap/lxd/common/lxd 118 start" for container "wdelgenio-test1"
lxc wdelgenio-test1 20190724143740.784 TRACE conf - conf.c:run_script_argv:421 - Set environment variable: LXC_HOOK_TYPE=pre-start
lxc wdelgenio-test1 20190724143740.784 TRACE conf - conf.c:run_script_argv:429 - Set environment variable: LXC_HOOK_SECTION=lxc
lxc wdelgenio-test1 20190724143740.846 TRACE start - start.c:lxc_init:890 - Ran pre-start hooks
lxc wdelgenio-test1 20190724143740.846 TRACE start - start.c:setup_signal_fd:356 - Created signal file descriptor 4
lxc wdelgenio-test1 20190724143740.846 TRACE start - start.c:lxc_init:901 - Set up signal fd
lxc wdelgenio-test1 20190724143740.847 DEBUG terminal - terminal.c:lxc_terminal_peer_default:676 - No such device - The process does not have a controlling terminal
lxc wdelgenio-test1 20190724143740.847 DEBUG terminal - terminal.c:lxc_terminal_create_log_file:848 - Using "/var/snap/lxd/common/lxd/logs/wdelgenio-test1/console.log" as terminal log file
lxc wdelgenio-test1 20190724143740.847 TRACE terminal - terminal.c:lxc_terminal_create_ringbuf:829 - Allocated 131072 byte terminal ringbuffer
lxc wdelgenio-test1 20190724143740.847 TRACE start - start.c:lxc_init:909 - Created console
lxc wdelgenio-test1 20190724143740.847 TRACE terminal - terminal.c:lxc_terminal_map_ids:1192 - Chowned terminal "/dev/pts/0"
lxc wdelgenio-test1 20190724143740.847 TRACE start - start.c:lxc_init:916 - Chowned console
lxc wdelgenio-test1 20190724143740.847 TRACE cgfsng - cgroups/cgfsng.c:lxc_cgfsng_print_basecg_debuginfo:1018 - basecginfo is:
lxc wdelgenio-test1 20190724143740.847 TRACE cgfsng - cgroups/cgfsng.c:lxc_cgfsng_print_basecg_debuginfo:1019 - 11:blkio:/
10:hugetlb:/
9:memory:/
8:cpuacct,cpu:/
7:net_prio,net_cls:/
6:pids:/
5:devices:/
4:cpuset:/
3:freezer:/
2:perf_event:/
1:name=systemd:/
lxc wdelgenio-test1 20190724143740.847 TRACE cgfsng - cgroups/cgfsng.c:lxc_cgfsng_print_basecg_debuginfo:1022 - kernel subsystem 0: blkio
lxc wdelgenio-test1 20190724143740.847 TRACE cgfsng - cgroups/cgfsng.c:lxc_cgfsng_print_basecg_debuginfo:1022 - kernel subsystem 1: hugetlb
lxc wdelgenio-test1 20190724143740.847 TRACE cgfsng - cgroups/cgfsng.c:lxc_cgfsng_print_basecg_debuginfo:1022 - kernel subsystem 2: memory
lxc wdelgenio-test1 20190724143740.847 TRACE cgfsng - cgroups/cgfsng.c:lxc_cgfsng_print_basecg_debuginfo:1022 - kernel subsystem 3: cpuacct
lxc wdelgenio-test1 20190724143740.847 TRACE cgfsng - cgroups/cgfsng.c:lxc_cgfsng_print_basecg_debuginfo:1022 - kernel subsystem 4: cpu
lxc wdelgenio-test1 20190724143740.847 TRACE cgfsng - cgroups/cgfsng.c:lxc_cgfsng_print_basecg_debuginfo:1022 - kernel subsystem 5: net_prio
lxc wdelgenio-test1 20190724143740.847 TRACE cgfsng - cgroups/cgfsng.c:lxc_cgfsng_print_basecg_debuginfo:1022 - kernel subsystem 6: net_cls
lxc wdelgenio-test1 20190724143740.847 TRACE cgfsng - cgroups/cgfsng.c:lxc_cgfsng_print_basecg_debuginfo:1022 - kernel subsystem 7: pids
lxc wdelgenio-test1 20190724143740.847 TRACE cgfsng - cgroups/cgfsng.c:lxc_cgfsng_print_basecg_debuginfo:1022 - kernel subsystem 8: devices
lxc wdelgenio-test1 20190724143740.847 TRACE cgfsng - cgroups/cgfsng.c:lxc_cgfsng_print_basecg_debuginfo:1022 - kernel subsystem 9: cpuset
lxc wdelgenio-test1 20190724143740.847 TRACE cgfsng - cgroups/cgfsng.c:lxc_cgfsng_print_basecg_debuginfo:1022 - kernel subsystem 10: freezer
lxc wdelgenio-test1 20190724143740.848 TRACE cgfsng - cgroups/cgfsng.c:lxc_cgfsng_print_basecg_debuginfo:1022 - kernel subsystem 11: perf_event
lxc wdelgenio-test1 20190724143740.848 TRACE cgfsng - cgroups/cgfsng.c:lxc_cgfsng_print_basecg_debuginfo:1025 - named subsystem 0: name=systemd
lxc wdelgenio-test1 20190724143740.848 TRACE cgfsng - cgroups/cgfsng.c:cg_hybrid_init:2589 - Writable cgroup hierarchies:
lxc wdelgenio-test1 20190724143740.848 TRACE cgfsng - cgroups/cgfsng.c:lxc_cgfsng_print_hierarchies:999 - Hierarchies:
lxc wdelgenio-test1 20190724143740.848 TRACE cgfsng - cgroups/cgfsng.c:lxc_cgfsng_print_hierarchies:1004 - 0: base_cgroup: /
lxc wdelgenio-test1 20190724143740.848 TRACE cgfsng - cgroups/cgfsng.c:lxc_cgfsng_print_hierarchies:1005 - mountpoint: /sys/fs/cgroup/systemd
lxc wdelgenio-test1 20190724143740.848 TRACE cgfsng - cgroups/cgfsng.c:lxc_cgfsng_print_hierarchies:1006 - controllers:
lxc wdelgenio-test1 20190724143740.848 TRACE cgfsng - cgroups/cgfsng.c:lxc_cgfsng_print_hierarchies:1008 - 0: name=systemd
lxc wdelgenio-test1 20190724143740.848 TRACE cgfsng - cgroups/cgfsng.c:lxc_cgfsng_print_hierarchies:1004 - 1: base_cgroup: /
lxc wdelgenio-test1 20190724143740.848 TRACE cgfsng - cgroups/cgfsng.c:lxc_cgfsng_print_hierarchies:1005 - mountpoint: /sys/fs/cgroup/perf_event
lxc wdelgenio-test1 20190724143740.848 TRACE cgfsng - cgroups/cgfsng.c:lxc_cgfsng_print_hierarchies:1008 - 0: perf_event
lxc wdelgenio-test1 20190724143740.848 TRACE cgfsng - cgroups/cgfsng.c:lxc_cgfsng_print_hierarchies:1004 - 2: base_cgroup: /
lxc wdelgenio-test1 20190724143740.848 TRACE cgfsng - cgroups/cgfsng.c:lxc_cgfsng_print_hierarchies:1005 - mountpoint: /sys/fs/cgroup/freezer
lxc wdelgenio-test1 20190724143740.848 TRACE cgfsng - cgroups/cgfsng.c:lxc_cgfsng_print_hierarchies:1008 - 0: freezer
lxc wdelgenio-test1 20190724143740.848 TRACE cgfsng - cgroups/cgfsng.c:lxc_cgfsng_print_hierarchies:1004 - 3: base_cgroup: /
lxc wdelgenio-test1 20190724143740.848 TRACE cgfsng - cgroups/cgfsng.c:lxc_cgfsng_print_hierarchies:1005 - mountpoint: /sys/fs/cgroup/cpuset
lxc wdelgenio-test1 20190724143740.848 TRACE cgfsng - cgroups/cgfsng.c:lxc_cgfsng_print_hierarchies:1008 - 0: cpuset
lxc wdelgenio-test1 20190724143740.848 TRACE cgfsng - cgroups/cgfsng.c:lxc_cgfsng_print_hierarchies:1004 - 4: base_cgroup: /
lxc wdelgenio-test1 20190724143740.848 TRACE cgfsng - cgroups/cgfsng.c:lxc_cgfsng_print_hierarchies:1005 - mountpoint: /sys/fs/cgroup/devices
lxc wdelgenio-test1 20190724143740.848 TRACE cgfsng - cgroups/cgfsng.c:lxc_cgfsng_print_hierarchies:1008 - 0: devices
lxc wdelgenio-test1 20190724143740.848 TRACE cgfsng - cgroups/cgfsng.c:lxc_cgfsng_print_hierarchies:1004 - 5: base_cgroup: /
lxc wdelgenio-test1 20190724143740.848 TRACE cgfsng - cgroups/cgfsng.c:lxc_cgfsng_print_hierarchies:1005 - mountpoint: /sys/fs/cgroup/pids
lxc wdelgenio-test1 20190724143740.848 TRACE cgfsng - cgroups/cgfsng.c:lxc_cgfsng_print_hierarchies:1008 - 0: pids
lxc wdelgenio-test1 20190724143740.848 TRACE cgfsng - cgroups/cgfsng.c:lxc_cgfsng_print_hierarchies:1004 - 6: base_cgroup: /
lxc wdelgenio-test1 20190724143740.848 TRACE cgfsng - cgroups/cgfsng.c:lxc_cgfsng_print_hierarchies:1005 - mountpoint: /sys/fs/cgroup/net_cls,net_prio
lxc wdelgenio-test1 20190724143740.848 TRACE cgfsng - cgroups/cgfsng.c:lxc_cgfsng_print_hierarchies:1008 - 0: net_cls
lxc wdelgenio-test1 20190724143740.848 TRACE cgfsng - cgroups/cgfsng.c:lxc_cgfsng_print_hierarchies:1008 - 1: net_prio
lxc wdelgenio-test1 20190724143740.848 TRACE cgfsng - cgroups/cgfsng.c:lxc_cgfsng_print_hierarchies:1004 - 7: base_cgroup: /
lxc wdelgenio-test1 20190724143740.848 TRACE cgfsng - cgroups/cgfsng.c:lxc_cgfsng_print_hierarchies:1005 - mountpoint: /sys/fs/cgroup/cpu,cpuacct
lxc wdelgenio-test1 20190724143740.848 TRACE cgfsng - cgroups/cgfsng.c:lxc_cgfsng_print_hierarchies:1008 - 1: cpuacct
lxc wdelgenio-test1 20190724143740.849 TRACE cgfsng - cgroups/cgfsng.c:lxc_cgfsng_print_hierarchies:1004 - 8: base_cgroup: /
lxc wdelgenio-test1 20190724143740.849 TRACE cgfsng - cgroups/cgfsng.c:lxc_cgfsng_print_hierarchies:1005 - mountpoint: /sys/fs/cgroup/memory
lxc wdelgenio-test1 20190724143740.849 TRACE cgfsng - cgroups/cgfsng.c:lxc_cgfsng_print_hierarchies:1006 - controllers:
lxc wdelgenio-test1 20190724143740.849 TRACE cgfsng - cgroups/cgfsng.c:lxc_cgfsng_print_hierarchies:1008 - 0: memory
lxc wdelgenio-test1 20190724143740.849 TRACE cgfsng - cgroups/cgfsng.c:lxc_cgfsng_print_hierarchies:1004 - 9: base_cgroup: /
lxc wdelgenio-test1 20190724143740.849 TRACE cgfsng - cgroups/cgfsng.c:lxc_cgfsng_print_hierarchies:1005 - mountpoint: /sys/fs/cgroup/hugetlb
lxc wdelgenio-test1 20190724143740.849 TRACE cgfsng - cgroups/cgfsng.c:lxc_cgfsng_print_hierarchies:1008 - 0: hugetlb
lxc wdelgenio-test1 20190724143740.849 TRACE cgfsng - cgroups/cgfsng.c:lxc_cgfsng_print_hierarchies:1004 - 10: base_cgroup: /
lxc wdelgenio-test1 20190724143740.849 TRACE cgfsng - cgroups/cgfsng.c:lxc_cgfsng_print_hierarchies:1005 - mountpoint: /sys/fs/cgroup/blkio
lxc wdelgenio-test1 20190724143740.849 TRACE cgfsng - cgroups/cgfsng.c:lxc_cgfsng_print_hierarchies:1008 - 0: blkio
lxc wdelgenio-test1 20190724143740.849 TRACE cgroup - cgroups/cgroup.c:cgroup_init:61 - Initialized cgroup driver cgfsng
lxc wdelgenio-test1 20190724143740.849 TRACE cgroup - cgroups/cgroup.c:cgroup_init:64 - Running with legacy cgroup layout
lxc wdelgenio-test1 20190724143740.849 TRACE start - start.c:lxc_init:923 - Initialized cgroup driver
lxc wdelgenio-test1 20190724143740.849 TRACE start - start.c:lxc_init:930 - Initialized LSM
lxc wdelgenio-test1 20190724143740.849 INFO start - start.c:lxc_init:932 - Container "wdelgenio-test1" is initialized
lxc wdelgenio-test1 20190724143740.849 DEBUG cgfsng - cgroups/cgfsng.c:cg_legacy_filter_and_set_cpus:502 - Removed isolated or offline cpus from cpuset
lxc wdelgenio-test1 20190724143740.849 TRACE cgfsng - cgroups/cgfsng.c:cg_legacy_handle_cpuset_hierarchy:616 - "cgroup.clone_children" was already set to "1"
lxc wdelgenio-test1 20190724143740.864 INFO cgfsng - cgroups/cgfsng.c:cgfsng_monitor_create:1405 - The monitor process uses "lxc.monitor/wdelgenio-test1" as cgroup
lxc wdelgenio-test1 20190724143740.864 DEBUG storage - storage/storage.c:get_storage_by_name:232 - Detected rootfs type "dir"
lxc wdelgenio-test1 20190724143740.865 DEBUG cgfsng - cgroups/cgfsng.c:cg_legacy_filter_and_set_cpus:502 - Removed isolated or offline cpus from cpuset
lxc wdelgenio-test1 20190724143740.871 DEBUG lxccontainer - lxccontainer.c:wait_on_daemonized_start:861 - First child 440282 exited
lxc wdelgenio-test1 20190724143740.871 ERROR lxccontainer - lxccontainer.c:wait_on_daemonized_start:864 - No such file or directory - Failed to receive the container state
lxc 20190724143740.871 WARN commands - commands.c:lxc_cmd_rsp_recv:135 - Connection reset by peer - Failed to receive response for command "get_state"
Yeah, I’m looking at the liblxc code and trying to figure out where it fails and why we don’t have an error message.
@wdelgenio can you check that this is not segfaulting, please.
I saw no core dumps when I was working on this, so I don’t believe there were any segfaults. Can’t be sure, but I no longer have the CentOS environment to test.
Hm, so for the container. It uses macvlan
. Does the interface eth0
exist?
Yeah, that’s not it.
Here’s the log from 3.0.4 before I did the echo 1000 > /proc/sys/user/max_user_namespaces
and unshare -U
and unshare -m
Log:
lxc working-gopher 20190724155154.320 ERROR start - start.c:lxc_spawn:1737 - Invalid argument - Failed to clone a new set of namespaces
lxc working-gopher 20190724155154.322 ERROR start - start.c:__lxc_start:2019 - Failed to spawn container "working-gopher"
lxc working-gopher 20190724155154.323 ERROR lxccontainer - lxccontainer.c:wait_on_daemonized_start:851 - Received container state "ABORTING" instead of "RUNNING"
lxc working-gopher 20190724155154.754 ERROR conf - conf.c:userns_exec_1:4311 - Failed to clone process in new user namespace
lxc working-gopher 20190724155154.755 WARN cgfsng - cgroups/cgfsng.c:cgfsng_payload_destroy:1108 - Failed to destroy cgroups
lxc 20190724155154.105 WARN commands - commands.c:lxc_cmd_rsp_recv:135 - Connection reset by peer - Failed to receive response for command "get_state"
I did eventually get that working-gopher container to run on 3.0.4
I really can’t explain the error at the moment. The only thing that comes to mind is a segfault.
Hi everyone,
I recently encountered a very similar problem, the containers did not start with the same error that the TS @wdelgenio indicated. In my case, the cause of the problems was commonplace - time desynchronization on cluster members. One of the servers was 10 seconds lag due to an ntp configuration error. After correcting ntp settings the containers were created and launched without problems. Maybe this will be useful to someone
Too many dependencies on all the nodes working exactly 100% correct for the cluster to work well. We have seen one bad server cause lots of issues for the whole cluster.
