TomvB
(Tom)
1
Today I wanted to patch and reboot the containers, but unfortunately they don’t start anymore.
Logs:
Tried to detach the default, but without success.
lxc network detach lxdbr0 webserver default
I’m using:
lxc config device add webserver eth0 nic nictype=routed ipv6.address=IPv6 on the container
This problem only affects the IPv6 containers with nictype=routed.
lxd 4.21 22114 latest/stable canonical✓
tomp
(Thomas Parrott)
2
Looks like the same issue as:
The workaround until the fix is published is to set:
lxc config device set <instance> <device> ipv{n}.gateway=none
