Ceph and Ovn integration
Are there any plans for integration alternatives to microcloud with Ovn and Ceph for Incus?
LXD itself doesn’t really have anything special to handle MicroOVN/MicroCeph, it just talks to the OpenVswitch socket or reads ceph.conf respectively.
So for Incus, the same will apply, exactly how you deployed your OVN or Ceph cluster doesn’t really matter. You could absolutely keep using MicroOVN and MicroCeph for that, or you can use some Ansible book to deploy those services or whatever else works best for you.
