I am trying to learn to use cephfs and when I attach the profile with the cephfs volume to an instance I get the error
Error: Failed add validation for device “foo”: Failed loading custom volume: Storage volume not found
What might I be missing? I think I am close …
I am using ceph installed via cephadm and docker. ceph is working to create a container.
type or paste code here
snap, set, lxd, ceph.external=true
systemctl reload snap.lxd.daemon
ceph osd pool create persist-cephfs_data 8
ceph osd pool create persist-cephfs_metadata 8
ceph fs new persist-cephfs persist-cephfs_metadata persist-cephfs_data
ceph fs set persist-cephfs allow_new_snaps true
ceph orch apply mds persist-cephfs --placement="3 v1 v2 v3"
lxc storage create remotefs cephfs source=persist-cephfs/foo --target=v1
lxc storage create remotefs cephfs source=persist-cephfs/foo --target=v2
lxc storage create remotefs cephfs source=persist-cephfs/foo --target=v3
lxc profile create foo
Profile foo created
lxc profile device add foo foo disk pool=remote-fs source=foo path=/foo
Device foo added to foo
lxc profile add c1 foo
Error: Failed add validation for device "foo": Failed loading custom volume: Storage volume not found
ceph -s
cluster:
health: HEALTH_OK
services:
mon: 3 daemons, quorum v1,v2,v3 (age 3h)
mgr: v1.efyabb(active, since 3h), standbys: v2.cplcdk
mds: 1/1 daemons up, 2 standby
osd: 9 osds: 9 up (since 3h), 9 in (since 3h)
data:
volumes: 1/1 healthy
pools: 5 pools, 105 pgs
objects: 300 objects, 961 MiB
usage: 3.2 GiB used, 897 GiB / 900 GiB avail
pgs: 105 active+clean
ceph fs status
persist-cephfs - 3 clients
RANK STATE MDS ACTIVITY DNS INOS DIRS CAPS
0 active persist-cephfs.v3.wgqopp Reqs: 0 /s 16 16 15 9
POOL TYPE USED AVAIL
persist-cephfs_metadata metadata 336k 283G
persist-cephfs_data data 0 283G
STANDBY MDS
persist-cephfs.v1.whxauz
persist-cephfs.v2.szaiwo
MDS version: ceph version 17.2.5 (98318ae89f1a893a6ded3a640405cdbb33e08757) quincy (stable)
ceph osd tree
ID CLASS WEIGHT TYPE NAME STATUS REWEIGHT PRI-AFF
-1 0.87918 root default
-7 0.29306 host v1
2 hdd 0.09769 osd.2 up 1.00000 1.00000
5 hdd 0.09769 osd.5 up 1.00000 1.00000
8 hdd 0.09769 osd.8 up 1.00000 1.00000
-5 0.29306 host v2
0 hdd 0.09769 osd.0 up 1.00000 1.00000
3 hdd 0.09769 osd.3 up 1.00000 1.00000
6 hdd 0.09769 osd.6 up 1.00000 1.00000
-3 0.29306 host v3
1 hdd 0.09769 osd.1 up 1.00000 1.00000
4 hdd 0.09769 osd.4 up 1.00000 1.00000
7 hdd 0.09769 osd.7 up 1.00000 1.00000
ceph osd pool ls
lxd
.mgr
persist-cephfs_data
remote
lxc version
Client version: 5.9
Server version: 5.9
