Hi folks,
I notice on startup of my Ubuntu 20.04 server I get a failed process.
cgmanager failed to start.
I don’t fully understand cgmanager’s role in LXC/LXD, how can I fix this error…
Ive tried restarting etc but it just doesnt come up.
journalctl -xe produces the following:
-- The unit cgmanager.service has entered the 'failed' state with result 'exit-code'.
Jul 21 10:09:41 VMsrv01 systemd[1]: Failed to start Cgroup management daemon.
-- Subject: A start job for unit cgmanager.service has failed
-- Defined-By: systemd
-- Support: http://www.ubuntu.com/support
-- A start job for unit cgmanager.service has finished with a failure.
-- The job identifier is 7028 and the job result is failed.
Jul 21 10:09:41 VMsrv01 sudo[147326]: pam_unix(sudo:session): session closed for user root
Jul 21 10:09:50 VMsrv01 sudo[147333]: tom : TTY=pts/0 ; PWD=/home/tom ; USER=root ; COMMAND=/bin/systemctl status cgmanager
Jul 21 10:09:50 VMsrv01 sudo[147333]: pam_unix(sudo:session): session opened for user root by tom(uid=0)
Jul 21 10:09:50 VMsrv01 sudo[147333]: pam_unix(sudo:session): session closed for user root
Jul 21 10:10:23 VMsrv01 smartd[1062]: Device: /dev/sda [SAT], SMART Usage Attribute: 194 Temperature_Celsius changed from 111 to 110
Jul 21 10:11:49 VMsrv01 systemd[143976]: Started snap.lxd.lxc.b316ccfb-b9f5-4338-ac7c-0205cc9d6795.scope.
Any thoughts on this error?
