s4uliu5
(Saulius Gurklys)
1
I had two storage pools (zfs and btrs) and by accident lost one (btrfs) of them.
“lxc list” still lists all containers including ones from lost pool.
I can not delete gone containers
# lxc delete f1
Error: no such file or directory
or storage pool and volumes
# lxc storage volume delete btrfs f1
Error: No such object
# lxc storage delete btrfs
Error: storage pool "btrfs" has volumes attached to it
Is there a way to cleanup information/data about lost containers and storage pool and volumes?
Thank you.
stgraber
(Stéphane Graber)
2
Easiest is to temporarily re-create the pool, even if empty, then you can remove everything.
Can you show lxc storage show btrfs
s4uliu5
(Saulius Gurklys)
3
My
returns
btrfs.mount_options: compress=zstd
source: /btrfs/lxd
volatile.initial_source: /btrfs/lxd
driver: btrfs
- /1.0/containers/alpine-edge
- /1.0/containers/docker1
- /1.0/containers/f1
- /1.0/containers/f2
- /1.0/images/af646b495f250dad72a2b5dd6f604264936b9d932a52878e7686891f285173c6
- /1.0/profiles/btrfs
status: Created
locations:
- none
So I just need to create /btrfs/lxd
Thank you.
stgraber
(Stéphane Graber)
4
Yep, creating /btrfs/lxd should do the trick
s4uliu5
(Saulius Gurklys)
5
I created /btrfs/lxd
directory. And then I was able to delete all containers, images, profiles and storage pool. My problem has been solved
