I need to rebuild nodes in my incus
cluster after one node disaster. All instances, volumes and images are located on shared ceph
and cephfs
storages.
I use the workflow as below:
- Evacuate node with the
cluster evacuate <node>
command (all instance profiles configured withcluster.evacuate=move
) - Remove node from the cluster with the
cluster remove <node>
command - Rebuild host OS
- Add node to the cluster with the same name using
cluster add <node>
;admin cluster init
commands - Try to revert moved nodes back to the node with the
cluster restore <node>
command.
Everything goes smooth except placing instances back to the node. Restore process did not find any orphan instances (as I assumed) and did not move instances back to the re-added node.
All evacuated instances have configuration option volatile.evacuate.origin=<node>
Of course, I can script the restoring instances placement using volatile.evacuate.origin
The incus
documentation do not cover such case. So it’s not clear if such case is supported, or I missed something
