While developing MAAS I often have the need to create containers for testing. MAAS itself runs a DHCP server so when creating a container to run MAAS I need a network which MAAS can control. To do that I need to start a container with a static IP address. Network configuration in MAAS and many other clouds is actually done by cloud-init using netplan syntax. You can do the same with LXD
lxc init ubuntu:20.04 maas
net_cfg=$(mktemp setup_maas_XXXX)
cat <<EOF >> $net_cfg
network:
version: 2
ethernets:
# MAAS network
addresses: [10.0.0.2/24]
gateway4: 10.0.0.1
nameservers:
search: [maas]
addresses: [10.0.0.2, 10.0.0.1]
# Standard LXD network
eth1:
dhcp4: true
EOF
lxc file push $net_cfg maas/etc/cloud/cloud.cfg.d/network.cfg
rm $net_cfg
lxc start maas
