Hi all, i have strange issue with networking and will be thankful if some one can point me to right direction to solve it.
LXD version 4.2
OS: OpenSUSE Tumbleweed with kernel 4.7.5
Networking with NetworkManager
Im running NGINX server in one container and in second container i want to get file from the NGINX by wget but connection hang, i get only first 27kB of file. Files smaller that 1.5kB are transfered correctly.
The same wget work when i run it from other hosts on network.
Two containers are on the same bridge and network on one host and:
- bridge is stantard br created manualy not by LXD
- firewalling is disabled
- no rouitng or nat on network
- ping between containers work but only to size 1476 bytes
- containers are also visible for other host on network
Any ideas ?
Thanks.
