I’m having some problems getting things running in the correct locations.
I’m running Ubuntu 16.04.3 LTS with lxc/lxd 2.18.
lxc --version
2.18
I created a storage volume (data2dir) on a device that has more space available than the default storage device:
lxc storage list
| data2dir | | dir | /data2/virtual/lxd2 | 4 |
| default | | dir | /var/lib/lxd/storage-pools/default | 1 |
Then I created a container on data2dir:
lxc launch images:ubuntu/xenial nextcloud -s data2dir
And here are the containers that are supposed to be on data2dir:
lxc storage show data2dir
source: /data2/virtual/lxd2
volatile.initial_source: /data2/virtual/lxd2
driver: dir
- /1.0/containers/church
- /1.0/containers/cops
- /1.0/containers/nextcloud
- /1.0/containers/web
cd /data2/virtual/lxd2/containers/
ls
church nextcloud web
However, I later found out the /var/lib/ lists BOTH storage pools:
ls /var/lib/lxd/storage-pools/
data2dir default
And when I look at the /var/lib/ version of the data2dir pool, I find my data directory (nextclouddata)!
ls /var/lib/lxd/storage-pools/data2dir/containers/nextcloud/rootfs/
bin boot dev etc home lib lib64 media mnt nextclouddata opt proc root run sbin srv sys tmp usr var
But it is NOT where it is supposed to be!!!
ls /data2/virtual/lxd2/containers/nextcloud/rootfs
bin boot dev etc home lib lib64 media mnt opt proc root run sbin snap srv sys tmp usr var
This is a running system!
Why didn’t the container get created where it was supposed to be?
How do I get the data where it belongs and keep it there?
If you need anything else from me, please let me know what that is.
Thanks,
Harlan…
