I forgot to clear out some btrfs snapshots yesterday and the root volume filled up (~400MB left), this has happened many times before on 2.x. I cleaned up snapshots and rebooted the server, but now any containers with a disk in a storage-pool won’t start saying that it can’t find them, but they are there. I’m running LXD in a snap.
t=2019-10-12T09:05:09-0800 lvl=info msg="LXD 3.18 is starting in normal mode" path=/var/snap/lxd/common/lxd
t=2019-10-12T09:05:10-0800 lvl=eror msg="Failed to start container 'scrypt': Common start logic: Failed to start device 'scrypt_blockchains': Source path /var/snap/lxd/common/lxd/storage-pools/hdd/custom/scrypt_blockchains doesn't exist for device scrypt_blockchains"
t=2019-10-12T09:05:20-0800 lvl=eror msg="Failed to start container 'x11': Common start logic: Failed to start device 'x11_blockchains': Source path /var/snap/lxd/common/lxd/storage-pools/hdd/custom/x11_blockchains doesn't exist for device x11_blockchains"
t=2019-10-12T09:05:25-0800 lvl=eror msg="Failed to start container 'neoscrypt': Common start logic: Failed to start device 'neoscrypt_blockchains': Source path /var/snap/lxd/common/lxd/storage-pools/hdd/custom/neoscrypt_blockchains doesn't exist for device neoscrypt_blockchains"
Here is the storage-pool:
# ls -lh /var/snap/lxd/common/lxd/storage-pools/hdd/custom/
total 0
drwxr-xr-x 1 1001001 1001001 90 Nov 24 2018 betelgeuse_data
drwxrwxrwx 1 1000000 1000000 218 Nov 24 2018 mythtv_data
drwxr-xr-x 1 1001000 1001000 24 Nov 23 2018 neoscrypt_blockchains
drwxrws--- 1 www-data www-data 202 Nov 24 2018 owncloud_data
drwxr-xr-x 1 1001000 1001000 114 Nov 23 2018 scrypt_blockchains
drwxr-xr-x 1 1001000 1001000 174 Jun 22 17:11 sha256_blockchains
drwxr-xr-x 1 1000000 1000000 0 Nov 23 2018 vpntest_storage
drwxr-xr-x 1 1001000 1001000 48 Nov 23 2018 x11_blockchains
I not sure if I have db corruption or what and can’t find the lxd.db file as mentioned it other threads.
Any containers not using this storage pool start up just fine.
Please advise.
