Hi
For some reasons i must convert some lxd containers into lxc containers.
When i compress lxd container and create lxc from lxd container’s rootfs archive, the new container doesn’t work properly.
Can you provide a list of the commands that you are currently using to create the container image?
In addition, show whatever fails when you try to launch the new container.
