Hello there,
I’m running LXD 3.5 (from snap package) on two hosts running the same last Ubuntu 18.04 version.
Each time I try to transfer a snapshot from a big container (~50GB) from host A to host B I get the following error:
lxc copy xenon:g-mastodon/g-mstdn g-mastodon
Error: Failed container creation:
- https://REDACTED:8443: Error transferring container data: Unable to connect to: REDACTED]:8443
- https://REDACTED:8443: Error transferring container data: exit status 11
- https://REDACTED:8443: Error transferring container data: Unable to connect to: REDACTED:8443
On a small container (eg. ~10GB) I don’t have this problem and the command runs quietly.
Thanks in advance for your help.
Ps. here is some diag infos, let me know if u need more
Host B
lxc info
config: {}
api_extensions:
- container_stop_priority
- container_syscall_filtering
- auth_pki
- container_last_used_at
- etag
- patch
- usb_devices
- https_allowed_credentials
- image_compression_algorithm
- directory_manipulation
- container_cpu_time
- storage_zfs_use_refquota
- storage_lvm_mount_options
- network
- profile_usedby
- container_push
- container_exec_recording
- certificate_update
- gpu_devices
- container_image_properties
- migration_progress
- id_map
- network_firewall_filtering
- network_routes
- storage
- file_delete
- file_append
- network_dhcp_expiry
- storage_lvm_vg_rename
- storage_lvm_thinpool_rename
- network_vlan
- image_create_aliases
- container_stateless_copy
- container_only_migration
- storage_zfs_clone_copy
- unix_device_rename
- storage_lvm_use_thinpool
- storage_rsync_bwlimit
- network_vxlan_interface
- storage_btrfs_mount_options
- entity_description
- image_force_refresh
- storage_lvm_lv_resizing
- id_map_base
- file_symlinks
- container_push_target
- network_vlan_physical
- storage_images_delete
- container_edit_metadata
- storage_driver_ceph
- storage_ceph_user_name
- resource_limits
- resources
- kernel_limits
- storage_api_volume_rename
- macaroon_authentication
- network_sriov
- console
- restrict_devlxd
- migration_pre_copy
- infiniband
- maas_network
- devlxd_events
- proxy
- network_dhcp_gateway
- file_get_symlink
- network_leases
- unix_device_hotplug
- operation_description
- clustering
- event_lifecycle
- nvidia_runtime
- container_mount_propagation
- container_backup
- devlxd_images
- proxy_unix
- proxy_udp
- clustering_join
- network_state
- proxy_unix_dac_properties
- container_protection_delete
- unix_priv_drop
- pprof_http
- proxy_haproxy_protocol
- network_hwaddr
- proxy_nat
- network_nat_order
- container_full
- candid_authentication
- backup_compression
- candid_config
api_status: stable
api_version: "1.0"
auth: trusted
public: false
auth_methods:
- tls
environment:
addresses: []
architectures:
- x86_64
- i686
certificate: |
-----BEGIN CERTIFICATE-----
REDACTED
-----END CERTIFICATE-----
certificate_fingerprint: 8a3f123bcfeb1d3aec2840f5a58eaf294db5afdb73944a408853d4007174ef2b
driver: lxc
driver_version: 3.0.2
kernel: Linux
kernel_architecture: x86_64
kernel_version: 4.15.0-34-generic
server: lxd
server_pid: 2429
server_version: "3.5"
storage: lvm
storage_version: 2.02.133(2) (2015-10-30) / 1.02.110 (2015-10-30) / 4.37.0
server_clustered: false
server_name: B
Host A
lxc info
core.https_address: '[::]:8443'
core.trust_password: true
api_extensions:
- auth_pki
- etag
- patch
- usb_devices
- network
- profile_usedby
- container_push
- gpu_devices
- id_map
- network_routes
- storage
- file_delete
- file_append
- network_vlan
- id_map_base
- file_symlinks
- resource_limits
- resources
- kernel_limits
- network_sriov
- console
- restrict_devlxd
- infiniband
- maas_network
- devlxd_events
- proxy
- file_get_symlink
- network_leases
- clustering
- event_lifecycle
- nvidia_runtime
- container_backup
- devlxd_images
- proxy_unix
- proxy_udp
- clustering_join
- network_state
- unix_priv_drop
- pprof_http
- network_hwaddr
- proxy_nat
- network_nat_order
- container_full
- candid_config
api_status: stable
api_version: "1.0"
auth: trusted
public: false
auth_methods:
- tls
environment:
addresses:
- 138.201.32.141:8443
- '[2a01:4f8:171:340c::2]:8443'
- 10.217.155.1:8443
- '[fd42:6b4:84b0:4d34::1]:8443'
architectures:
- x86_64
- i686
certificate: |
REDACTED
certificate_fingerprint: 78effb8ba14c228e9303c26d5577be376201981f512e56b62a7af1fda85e33b5
driver: lxc
kernel: Linux
server: lxd
server_pid: 28040
storage: lvm
server_name: A
