yes, it still happens
Ubuntu 18.04.6 LTS
snap list lxd
lxd 4.22 22258 latest/stable canonical* -
lxd sql global .dump | grep sequence
DELETE FROM sqlite_sequence;
INSERT INTO sqlite_sequence VALUES('schema',8);
INSERT INTO sqlite_sequence VALUES('config',1);
INSERT INTO sqlite_sequence VALUES('cluster_groups',1);
INSERT INTO sqlite_sequence VALUES('projects',1);
INSERT INTO sqlite_sequence VALUES('images',1);
INSERT INTO sqlite_sequence VALUES('images_aliases',1);
INSERT INTO sqlite_sequence VALUES('nodes',1);
INSERT INTO sqlite_sequence VALUES('images_nodes',1);
INSERT INTO sqlite_sequence VALUES('profiles',1);
INSERT INTO sqlite_sequence VALUES('images_properties',8);
INSERT INTO sqlite_sequence VALUES('images_source',1);
INSERT INTO sqlite_sequence VALUES('instances',4);
INSERT INTO sqlite_sequence VALUES('instances_backups',0);
INSERT INTO sqlite_sequence VALUES('instances_config',134);
INSERT INTO sqlite_sequence VALUES('instances_devices',2);
INSERT INTO sqlite_sequence VALUES('instances_devices_config',8);
INSERT INTO sqlite_sequence VALUES('instances_profiles',6);
INSERT INTO sqlite_sequence VALUES('instances_snapshots',0);
INSERT INTO sqlite_sequence VALUES('instances_snapshots_config',0);
INSERT INTO sqlite_sequence VALUES('instances_snapshots_devices',0);
INSERT INTO sqlite_sequence VALUES('instances_snapshots_devices_config',0);
INSERT INTO sqlite_sequence VALUES('networks',0);
INSERT INTO sqlite_sequence VALUES('networks_acls',0);
INSERT INTO sqlite_sequence VALUES('networks_config',0);
INSERT INTO sqlite_sequence VALUES('networks_forwards',0);
INSERT INTO sqlite_sequence VALUES('networks_forwards_config',0);
INSERT INTO sqlite_sequence VALUES('networks_nodes',0);
INSERT INTO sqlite_sequence VALUES('networks_peers',0);
INSERT INTO sqlite_sequence VALUES('networks_peers_config',0);
INSERT INTO sqlite_sequence VALUES('networks_zones',0);
INSERT INTO sqlite_sequence VALUES('networks_zones_config',0);
INSERT INTO sqlite_sequence VALUES('nodes_config',0);
INSERT INTO sqlite_sequence VALUES('operations',232);
INSERT INTO sqlite_sequence VALUES('profiles_config',0);
INSERT INTO sqlite_sequence VALUES('profiles_devices',2);
INSERT INTO sqlite_sequence VALUES('profiles_devices_config',7);
INSERT INTO sqlite_sequence VALUES('projects_config',4);
INSERT INTO sqlite_sequence VALUES('storage_pools',2);
INSERT INTO sqlite_sequence VALUES('storage_pools_config',10);
INSERT INTO sqlite_sequence VALUES('storage_pools_nodes',2);
INSERT INTO sqlite_sequence VALUES('storage_volumes',NULL);
INSERT INTO sqlite_sequence VALUES('storage_volumes_backups',0);
INSERT INTO sqlite_sequence VALUES('storage_volumes_config',14);
INSERT INTO sqlite_sequence VALUES('storage_volumes_snapshots_config',0);
INSERT INTO sqlite_sequence VALUES('warnings',2);
