Edit: Its much more. The whole init process doesn’t start properly.
When i try to ‘halt’ a Debian Jessie container on an Openrc host (OpenWRT) i get this error:
Failed to talk to init daemon.
Doing ‘systemctl status’ gets:
Failed to get D-Bus connection: Unknown error -1
I already installed ‘systemd, systemd-sysv, dbus’ packages but it doesn’t help.
Dbus doesn’t run when the container gets up.
root@debian:~# ps aux
USER PID %CPU %MEM VSZ RSS TTY STAT START TIME COMMAND
root 1 0.0 0.4 4380 2404 ? Ss 14:39 0:00 /sbin/init
root 13 0.0 0.5 3616 2864 pts/2 Ss 14:54 0:00 /bin/bash
/sbin/init points to systemd binary.
lxc-start -n debian -F
lxc-start: debian: utils.c: safe_mount: 1707 No such file or directory - Failed to mount /usr/lib/lxc/rootfs/proc/tty onto /usr/lib/lxc/rootfs/proc/sys/net
Failed to mount cgroup at /sys/fs/cgroup/systemd: Operation not permitted
How can i get dbus fixed inside the container to be able to shutdown the container gracefully from outside and get the init process working? It doesn’t even start the nics.
lxc-start --version = 2.1.1
Linux OpenWrt 4.14.43 #0 PREEMPT Fri May 25 18:36:46 2018 i686 GNU/Linux
