Hi all,
I do not seem to be able to find a way to set security.idmap.isolated=true
as the default for all containers.
I have tried:
lxc config set security.idmap.isolated true
The answer I get is:
Error: cannot set 'security.idmap.isolated' to 'true': unknown key
What I want to is to set security.idmap.isolated=true as deafult for all containers.
So when you launch a container with:
lxc launch images:debian/10
The container should be launched with security.idmap.isolated=true
and you do not have to remember to set it manually.
Is there a way to achieve this?
Many thanks in advance!!
Best regards
Marcux
