Device type proxy fails after upgrade to 6.9
Host: Ubuntu 20.04 Linux 5.4.0-205-generic
incus --version 6.9
Container: Alpine edge (3.20.0_alpha20231219)
    ipv4.address: 10.0.4.10
    nictype: bridged
    parent: lxdbr0
  ws:
    connect: tcp:127.0.0.1:59997,59998,59999
    listen: tcp:185.216.xxx.xxx:59997,59998,59999
    type: proxy
185.216.xxx.xxx is public IP on Host.
This had worked prior to incus 6.9 update, though now instance is not starting:
Instance: xyz: Failed to start device "ws": Error occurred when starting proxy device: Error: Invalid argument - Failed setns to connector namespaces
The issue here is the 5.4 kernel which is very old and missing some APIs that we’re using.
You may want to install the HWE kernel which would fix that.
Incus 6.10 will also have a change to try to better handle those old kernels.
