Hello
I’m using an unprivileged lxc3 container launching by user.
Inside it, I use Virtualbox. Virtualbox need /dev/vboxdrv.
My config is the following :
lxc.idmap = u 0 100000 65536
lxc.idmap = g 0 100000 65536
lxc.mount.entry = /dev/vboxdrv dev/vboxdrv none bind,create=file 0 0
lxc.cgroup.devices.allow = c 10:57 rwm
I can’t use Virtualbox if before launching my container I don’t set
chmod 777 /dev/vboxdrv on my host.
Perhaps, you have understand I have no problem. Everything work fine, but I find my solution little bit unsecure both for my host and guest.
Is there an elegant way to do that ?
Thank you !
