Specify a comma-separated list of filesystems that are safe to mount for processes inside the instance
security.syscalls.intercept.mount.fuse
string
yes
container
Whether to mount shiftfs on top of filesystems handled through mount syscall interception
security.syscalls.intercept.mount.shift
boolean
false
yes
container
Whether to redirect mounts of a given filesystem to their fuse implemenation (e.g. ext4=fuse2fs)
I have a couple questions:
Are the ‘mount.allowed’ and ‘mount.fuse’ options mutually exclusive? In other words, if ‘ext4’ is in the ‘mount.allowed’ list then ‘ext4=fuse2fs’ can’t be in ‘mount.fuse’ also, right?
Are the comments for ‘mount.fuse’ and ‘mount.shift’ swapped? The one for shift makes mention of fuse and the one for fuse makes mention of shiftfs.
Is there an easy way to identify which Ubuntu kernel versions (HWE included) have support for seccomp_listener? I have been sifting through changelogs, but it isn’t very clear.
I know that 5.3.0-40-generic through HWE does support it, but only because I have a running machine I could check it on. What about if I need to answer this question for a kernel version that isn’t actively running somewhere that I can do ‘lxc info’ to see?
I am on the machine with the 5.3.0-40-generic kernel and the container starts. However, when I run the following mount command in the container it just hangs:
mount nfs-server:/data /data
The container log shows the following:
lxc test-intercept-mount 20200417200313.518 WARN seccomp - seccomp.c:do_resolve_add_rule:522 - Failed to resolve syscall “fsinfo”
lxc test-intercept-mount 20200417200313.518 WARN seccomp - seccomp.c:do_resolve_add_rule:523 - This syscall will NOT be handled by seccomp
lxc test-intercept-mount 20200417200313.518 ERROR cgfsng - cgroups/cgfsng.c:mkdir_eexist_on_last:1143 - File exists - Failed to create directory “/sys/fs/cgroup/cpuset//lxc.monitor.test-intercept-mount”
lxc test-intercept-mount 20200417200313.519 ERROR cgfsng - cgroups/cgfsng.c:mkdir_eexist_on_last:1143 - File exists - Failed to create directory “/sys/fs/cgroup/cpuset//lxc.payload.test-intercept-mount”
lxc test-intercept-mount 20200417200313.520 ERROR utils - utils.c:lxc_can_use_pidfd:1855 - Invalid argument - Kernel does not support waiting on processes through pidfds
lxc test-intercept-mount 20200417200313.522 WARN cgfsng - cgroups/cgfsng.c:fchowmodat:1455 - No such file or directory - Failed to fchownat(17, memory.oom.group, 65536, 0, AT_EMPTY_PATH | AT_SYMLINK_NOFOLLOW )
So NFS is probably one of the most annoying filesystems to run through interception because of its network component and built-in uid/gid concept, so hmm, that may be a fun one.
I’m not sure why things would hang though, I’d just expect outright failure, or success with a potentially weird mount point.
It seems to work fine with nobody:nogroup ownership and the ‘all_squash’ option set on the server side export.
I disabled ‘all_squash’ on the server side and did chmod o+w on the exported path temporarily. Touching a file from within the container (client side) worked and shows as follows:
# touch test
# ls -la
total 3
drwxr-xrwx 2 nobody nogroup 3 Apr 17 21:00 .
drwxr-xr-x 22 root root 22 Apr 7 15:52 ..
-rw-rw-rw- 1 root root 0 Apr 17 21:04 test
Here is one funny where it appears the umask isn’t being honored. All commands below were executed from within the container and under the NFS mounted path:
# umask
0022
# touch test
# ls -la test
-rw-rw-rw- 1 root root 0 Apr 17 23:11 test
# rm test
# umask 0027
# umask
0027
# touch test
# ls -la test
Am I just misunderstanding a behavior of LXD and/or NFS or is the above not correct?
