Looking for some advice here. I have an LXD 3.6 server running at Digital Ocean (Debian 9.5) with a bridge network of 192.168.191.0/24. I am running three alpine containers - each specific packages (nginx, etc). My goal is to get a direct connection to this bridge network so I can run some management tools on the containers (phpMyAdmin, etc).
I have looked at setting up OpenVPN and IPSec server code on the Debian-9 server, but that seems awfully complicated for what I need.
Next, I tried “sshuttle” which essentially is a poor-man’s VPN over ssh. I was able to get the connection established, but the bridge network does not appear in the list of valid subnets. A verbose dump of the connection provides this (the real IP is obfuscated with “XXX.YYY.ZZZ.AAA”)
firewall manager: Got subnets: [(2, 32, False, ‘XXX.YYY.ZZZ.AAA’, 0, 0), (2, 0, False, ‘0.0.0.0’, 0, 0), (2, 32, True, ‘127.0.0.1’, 0, 0), (30, 128, True, ‘::1’, 0, 0)]
A list of the LXD networks:
root@bmyers-dev1:~# lxc network list
| NAME | TYPE | MANAGED | DESCRIPTION | USED BY |
| eth0 | physical | NO | | 0 |
| lxdbr0 | bridge | YES | | 4 |
A list of containers running
root@bmyers-dev1:~# lxc list
| db01 | RUNNING | 192.168.191.11 (eth0) | fd42:... (eth0) | PERSISTENT | |
| nginx-proxy | RUNNING | 192.168.191.10 (eth0) | fd42:... (eth0) | PERSISTENT | |
| www-server-01 | RUNNING | 192.168.191.101 (eth0) | fd42:... (eth0) | PERSISTENT | |
Wondering if anyone has solved this problem before using sshuttle. If not, can you recommend a different tool that is easy to use (aside from ssh with multiple port forwarding statements)?
. It would be helpful to know what you are typing at the command line to invoke sshuttle and the parameters you are passing. It’s hard for me to tell exactly what was passed at the command line based on the log.
