Hello, I’m using Incus 7.0.1 from Debian 13 (backports)
Container uses DIR storage driver and
$ incus config device set MyMachine root cache=unsafe
Error: Invalid devices: Device validation failed for “root”: Invalid device option “cache”
Machine I suppose uses qcow2 file for storage and
$ incus config device set MyContainerName root cache=unsafe
1. Is it possible to do so for containers?
2. How to I make QEMU receives cache=unsafe parameter for disk specification?
Thank you.
bensmrs
(Benjamin Somers)
August 12, 2026, 4:31pm
2
Disk devices don’t have a cache option, as the error message says. There is however an io.cache option, which is only available with virtual machines.
$ incus config set MyMachine io.cache=unsafe
Error: Invalid expanded config: Unknown configuration key: io.cache
$ incus config device set MyMachine root io.cache=unsafe
Error: Failed to update device "root": Failed applying limits for disk device "root": DeviceNotFound: Device 'dev-incus_root' not found
$ incus config device show MyMachine
host_name: MyMV-eth0
ipv4.address: 192.168.2.12
network: MyBridge1
pool: local
(It’s using disk image file, and QEMU allows cache=unsafe specification for this)
bensmrs
(Benjamin Somers)
August 12, 2026, 4:45pm
4
The option only applies to devices, not instances as a whole.
Well that one’s weird, does that ring any bell, @stgraber ?
stgraber
(Stéphane Graber)
August 13, 2026, 3:50am
5
bensmrs:
That’s something we fixed in 7.3 I believe.
Oh, could that fix be backported to LTS version please?
stgraber
(Stéphane Graber)
August 14, 2026, 6:36am
7
It most likely has already been, we process backports every week, but LTS only releases every 3 months or so, so you’ll need to wait for 7.0.2 for the fix.
