Is there a way to get both shift and recursive behaviour for disk devices in LXD 4.19? When I add a ZFS based disk device with both shift
and recursive
set to true, only the base directory is mounted in the container with the shift overlay. My devices looks like:
data:
path: /data
recursive: "true"
shift: "true"
source: /host/test
In the container /data
does not not have any of the ZFS filesystems mounted in /host/test
on the host. If the host has another filesystem mounted at /host/test/child
, then the directory /data/child
is in the container, but is empty because the filesystem is not mounted. If I remove the shift
then the child filesystem(s) are mounted, but of course none have the shift overlay.
Ubuntu 20.04 with snap LXD 4.19
