lxc console -t vga -v fedora-33
(spicy:56956): GSpice-WARNING **: 19:54:32.166: main-1:0: could not set sockopt TCP_NODELAY: Operation not supported on socket
** Message: 19:54:32.253: main channel: opened
(spicy:56956): GSpice-WARNING **: 19:54:32.284: display-2:0: could not set sockopt TCP_NODELAY: Operation not supported on socket
(spicy:56956): GSpice-WARNING **: 19:54:32.284: usbredir-9:2: could not set sockopt TCP_NODELAY: Operation not supported on socket
(spicy:56956): GSpice-WARNING **: 19:54:32.284: usbredir-9:1: could not set sockopt TCP_NODELAY: Operation not supported on socket
(spicy:56956): GSpice-WARNING **: 19:54:32.284: usbredir-9:0: could not set sockopt TCP_NODELAY: Operation not supported on socket
spicy(56956,0x16c08f000) malloc: *** error for object 0x1287c2130: pointer being freed was not allocated
spicy(56956,0x16c08f000) malloc: *** set a breakpoint in malloc_error_break to debug
◰³ venv39 ~/W/theater-pi lxc console -t vga fedora-33 二 6/15 23:16:51 2021
(remote-viewer:79553): GSpice-WARNING **: 23:16:55.821: main-1:0: could not set sockopt TCP_NODELAY: Operation not supported on socket
(remote-viewer:79553): GSpice-WARNING **: 23:16:55.995: display-2:0: could not set sockopt TCP_NODELAY: Operation not supported on socket
(remote-viewer:79553): GSpice-WARNING **: 23:16:55.995: usbredir-9:2: could not set sockopt TCP_NODELAY: Operation not supported on socket
(remote-viewer:79553): GSpice-WARNING **: 23:16:55.995: usbredir-9:1: could not set sockopt TCP_NODELAY: Operation not supported on socket
(remote-viewer:79553): GSpice-WARNING **: 23:16:55.995: usbredir-9:0: could not set sockopt TCP_NODELAY: Operation not supported on socket
remote-viewer(79553,0x16d6d7000) malloc: *** error for object 0x11d7f8dc0: pointer being freed was not allocated
remote-viewer(79553,0x16d6d7000) malloc: *** set a breakpoint in malloc_error_break to debug
virt-viewer -c 'qemu+ssh://tongchia@192.168.123.191/system?socket=/var/run/libvirt/libvirt-sock' 2553ms 三 6/16 00:38:51 2021
(virt-viewer:86177): GSpice-WARNING **: 00:38:58.073: main-1:0: could not set sockopt TCP_NODELAY: Operation not supported on socket
(virt-viewer:86177): GSpice-WARNING **: 00:38:58.405: usbredir-9:1: could not set sockopt TCP_NODELAY: Operation not supported on socket
(virt-viewer:86177): GSpice-WARNING **: 00:38:58.405: usbredir-9:0: could not set sockopt TCP_NODELAY: Operation not supported on socket
(virt-viewer:86177): GSpice-WARNING **: 00:38:58.405: playback-5:0: could not set sockopt TCP_NODELAY: Operation not supported on socket
(virt-viewer:86177): GSpice-WARNING **: 00:38:58.405: record-6:0: could not set sockopt TCP_NODELAY: Operation not supported on socket
(virt-viewer:86177): GSpice-WARNING **: 00:38:58.405: display-2:0: could not set sockopt TCP_NODELAY: Operation not supported on socket
virt-viewer(86177,0x17042b000) malloc: *** error for object 0x116f047e0: pointer being freed was not allocated
virt-viewer(86177,0x17042b000) malloc: *** set a breakpoint in malloc_error_break to debug
Ok, so that definitely suggests a bug, most likely with gtk on the M1 Mac platform.
I’m not sure who the best contact point for such an issue would be though,
Sorry to revive a somewhat older issue (maybe it’s resolved by now), but this appears to be happening on non-M1 Intel-based MacOS as well. I ran into this issue today, and the internet gods brought me here…
I posted that without really thinking it through, and probably should’ve left the issue as is. I’m not really contributing anything useful, and didn’t mean to offend.
