LXD cluster upgraded to 4.9 and it cannot launch a container from ubuntu:20.04 image in a specific project, but it can launch a container which is based on image created from local containers in that project. Solved the problem by deleting the image from the project and than creating a container from ubuntu:20.04, so it downloaded the ubuntu fresh image and worked fine. One more caveat is rootfs download of ubuntu:20.04 is very slow on aws instances. The metadata download is fast in MB/s but for rootfs is around 300 kB/s.
Following is the output.
$ lxc launch ubuntu:20.04 test-1 --project testproj
Creating test-1
Error: Failed instance creation: Failed creating instance record: Failed initialising instance: Invalid devices: Failed detecting root disk device: No root device could be found
$ lxc project show testproj
features.images: "true"
features.profiles: "false"
features.storage.volumes: "false"
- /1.0/images/27782dbdcd2613dbe421fec9dc1c63096eba6c49abf133ae1d0471b0e8f00daa?project=testproj
- /1.0/images/295380c67ce8b70177d5755ad461291ca63f00497879e66ee91468bb4d9e7882?project=testproj
- /1.0/images/2e8d975e1ac663922e877c3b1cc71587af56dd8c17fb9cce7e10c61efafb338a?project=testproj
- /1.0/images/95d4230091724e8d774b6c9b2053e70bebee51570afb896f6157bf8b99625e59?project=testproj
- /1.0/images/e0c3495ffd489748aa5151628fa56619e6143958f041223cb4970731ef939cb6?project=testproj
- /1.0/instances/test-tip-1?project=testproj
$ lxc storage info local
info:
driver: zfs
space used: 11.19GB
total space: 528.42GB
used by:
images:
- 95d4230091724e8d774b6c9b2053e70bebee51570afb896f6157bf8b99625e59?project=testproj
- e0c3495ffd489748aa5151628fa56619e6143958f041223cb4970731ef939cb6?project=testproj
- e4c8dd5922cefe65861e2b2b96026de2cae16b0a6d27533760161407891cb0d0
instances:
- test-tip-2?project=testproj
- logs-1
- pypi-1
- test
$ lxc image delete e0c3495ffd48 --project testproj
Creating test-1
Retrieving image: rootfs: 10% (325.47kB/s)
Starting test-1
