I power on my host machine today and all my containers now in STOPPED state. So I searched the problem a little bit deeper but I get the following error when I execute the “lxc storage volume list lxd-pool” command. Can someone assist me about the problem?
Error: sql: Scan error on column index 0, name “node_id”: converting NULL to int is unsupported
Here are some details about lxc/lxd configuration:
lxc --version
4.5
indiana@mars:~$ lxd sql global "SELECT * FROM storage_pools;"
| id | name | driver | description | state |
| 5 | default | ceph | Ceph Storage | 1 |
| 11 | lxd-pool | zfs | ZFS Storage | 1 |
indiana@mars:~$ lxc list
| alpine312-zfs | STOPPED | | | CONTAINER | 0 |
| c1-7 | STOPPED | | | CONTAINER | 0 |
| centos7-zfs | STOPPED | | | CONTAINER | 0 |
| fedora32-zfs | STOPPED | | | CONTAINER | 0 |
| test | RUNNING | 10.35.95.133 (eth0) | fd42:c787:d33a:ae82:216:3eff:fefe:c0a5 (eth0) | CONTAINER | 0 |
| u1 | STOPPED | | | CONTAINER | 0 |
indiana@mars:~$ lxc start c1-7
Error: Common start logic: No such object
Try `lxc info --show-log c1-7` for more info
stgraber
(Stéphane Graber)
August 29, 2020, 3:55pm
2
Ok, so to confirm, this is a cluster setup with ceph remote storage and you’re running 4.5?
Can you show:
lxd sql global "SELECT * FROM storage_volumes;"
lxd sql global "SELECT * FROM nodes;"
Hi, @stgraber .
No it is not a cluster setup, just two storage systems are defined, zfs and ceph. But ceph storage is not running exactly. Briefly Two days ago this system is up and running, but now it is not responding.
Here are the outputs:
indiana@mars:~$ lxd sql global "SELECT * FROM storage_volumes;"
| id | name | storage_pool_id | node_id | type | description | project_id | content_type |
| 25 | centos8-zfs | 11 | <nil> | 0 | | 1 | 0 |
| 28 | centos7-zfs | 11 | <nil> | 0 | | 1 | 0 |
| 38 | alpine312-zfs | 11 | <nil> | 0 | | 1 | 0 |
| 91 | fedora32-zfs | 11 | <nil> | 0 | | 1 | 0 |
| 95 | c09302b8149908cc7a644ebae91032d72f542a1554acebc9b1ae409aa23a5017 | 11 | <nil> | 1 | | 1 | 0 |
| 106 | u1 | 11 | <nil> | 0 | | 1 | 0 |
| 107 | a92eaa65a5c5e53c6bf788b4443f4e5d2afac1665486247c336aa90959522bb6 | 11 | <nil> | 1 | | 1 | 0 |
| 116 | a2fe9ac5c8af831dda579a6dc9a83acc1a4193e46ba1e2407fc99f5fd6db8bd0 | 5 | <nil> | 1 | | 1 | 0 |
| 117 | c1-7 | 11 | <nil> | 0 | | 1 | 0 |
| 121 | f603184f60a0f9cfe6641b33596edcb27e7852e6795cbd3cc06cfc3fdd647512 | 11 | <nil> | 1 | | 1 | 0 |
| 122 | 66567b32341b2b382399af0531bdeb2d537b305cb0725ede2ab8291f3830105f | 11 | <nil> | 1 | | 1 | 0 |
| 123 | f6d9407e26ce18aaec845d120a5decc7c86113798854f0358774c4e22868902f | 11 | <nil> | 1 | | 1 | 0 |
| 124 | cc2693832478ccd5071d18ca1b3a6fe5cc1837c2d7d2e90d479f354b95fcf367 | 11 | <nil> | 1 | | 1 | 0 |
| 125 | d5f778088f05ea04e109fa0c232a1c318746b630623e2d5ff8d8f9c1482007a6 | 11 | <nil> | 1 | | 1 | 0 |
| 126 | test | 11 | 1 | 0 | | 1 | 0 |
| 127 | f603184f60a0f9cfe6641b33596edcb27e7852e6795cbd3cc06cfc3fdd647512 | 11 | 1 | 1 | | 1 | 0 |
indiana@mars:~$ lxd sql global "SELECT * FROM nodes;"
| id | name | description | address | schema | api_extensions | heartbeat | pending | arch | failure_domain_id |
| 1 | none | | 0.0.0.0 | 35 | 203 | 2020-07-05T11:58:59+03:00 | 0 | 2 | <nil> |
I have just created a test container which name is test, for health of the lxd system, and it works. But the existing ones, for example c1-7 is not started.
stgraber
(Stéphane Graber)
August 29, 2020, 6:41pm
5
@monstermunchkin don’t suppose you’re around and have an idea of what’s going on here?
stgraber
(Stéphane Graber)
August 29, 2020, 6:43pm
6
@cemzafer could you make a tarball of /var/snap/lxd/common/lxd/database
and e-mail that to me at stgraber_at_ubuntu_dot_com?
Once you’ve done that, I think you can fix your setup with:
lxd sql global "UPDATE storage_volumes SET node_id=1 WHERE storage_pool_id=11;"
The tarball should help me have an easy way to reproduce the upgrade and see what happened to cause this issue.
@stgraber , I can not send the database via gmail because of security reasons. Is there any another method to post that database?
Thanks.
Nevermind, I post the file but I have to change the suffix. For your information, it is a gzip tar file.
Thanks.
stgraber
(Stéphane Graber)
August 29, 2020, 10:59pm
9
Got it, thanks.
Did you try the fix? Does that get you back to working order?
I get the following error.
indiana@mars:~$ lxd sql global "UPDATE storage_volumes SET node_id=1 WHERE storage_pool_id=11;"
Error: Failed to exec query: UNIQUE constraint failed: storage_volumes.storage_pool_id, storage_volumes.node_id, storage_volumes.project_id, storage_volumes.name, storage_volumes.type
Yeah, this is definitely a bug. I was able to reproduce this by creating a zfs pool and a ceph pool. When the database is updated, it will incorrectly set the node ID of any existing storage volumes to nil. I’m working on a fix.
Thanks @monstermunchkin , nice to hear that is a bug.
Regards.
So, here is the fix: https://github.com/lxc/lxd/pull/7829
You should be able to get rid of the error by calling
lxd sql global "DELETE FROM storage_volumes WHERE id=127;"
(deletes the latest db entry)
(fixes the incorrect entries)
Thanks, I replied the posted commands and everything runs smoothly.
Regards.
