After migration from deb to snap at Ubuntu 20.04, lxd doesn’t start with error:
DBUG[09-14|08:04:36] Initializing and checking storage pool “storage”
DBUG[09-14|08:04:36] Mount started driver=dir pool=storage
DBUG[09-14|08:04:46] Mount finished driver=dir pool=storage
EROR[09-14|08:04:46] Failed to start the daemon: Failed initializing storage pool “storage”: Failed to mount “/var/lib/snapd/hostfs/storage/lxc/” on “/var/snap/lxd/common/lxd/storage-pools/storage” using “none”: no such file or directory
How can I completely remove this storage pool? Directory /var/lib/snapd/hostfs is empty.
