I can create the container but could not start it.
I have used a different template.
lxc-minimal.sh template
#!/bin/sh
# lxc: linux Container library
# Authors:
# Daniel Lezcano daniel.lezcano@free.fr
# This library is free software; you can redistribute it and/or
# modify it under the terms of the GNU Lesser General Public
# License as published by the Free Software Foundation; either
# version 2.1 of the License, or (at your option) any later version.
# This library is distributed in the hope that it will be useful,
# but WITHOUT ANY WARRANTY; without even the implied warranty of
# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
# Lesser General Public License for more details.
# You should have received a copy of the GNU Lesser General Public
# License along with this library; if not, write to the Free Software
# Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, MA 02110-1301 USA
# Detect use under userns (unsupported)
for arg in “$@”; do
[ “$arg” = “–” ] && break
if [ “$arg” = “–mapped-uid” -o “$arg” = “–mapped-gid” ]; then
echo “This template can’t be used for unprivileged containers.” 1>&2
echo “You may want to try the “download” template instead.” 1>&2
exit 1
fi
done
# Make sure the usual locations are in PATH
export PATH=$PATH:/usr/sbin:/usr/bin:/sbin:/bin
install_minimal()
rootfs=$1
tree="\
$rootfs/var/run/minimal
$rootfs/var/empty/minimal
$rootfs/var/lib/empty/minimal
$rootfs/etc/init.d
$rootfs/etc/rc.d
$rootfs/etc/sysconfig/network-scripts
$rootfs/dev/shm
$rootfs/run/shm
$rootfs/proc
$rootfs/sys
$rootfs/bin
$rootfs/sbin
$rootfs/usr
$rootfs/tmp
$rootfs/home
$rootfs/root
$rootfs/lib
$rootfs/lib64"
mkdir -p $tree
if [ $? -ne 0 ]; then
return 1
fi
return 0
configure_minimal()
rootfs=$1
cat <<EOF > $rootfs/etc/passwd
root:x:0:0:root:/root:/bin/bash
EOF
cat <<EOF > $rootfs/etc/group
root:x:0:root
EOF
return 0
copy_configuration()
path=$1
rootfs=$2
name=$3
grep -q "^lxc.rootfs" $path/config 2>/dev/null || echo "lxc.rootfs = $rootfs" >> $path/config
cat <> $path/config
lxc.utsname = $name
lxc.pts = 1024
lxc.kmsg = 0
lxc.cap.drop = sys_module mac_admin mac_override sys_time
# When using LXC with apparmor, uncomment the next line to run unconfined:
#lxc.aa_profile = unconfined
lxc.mount.entry = /dev dev none ro,bind 0 0
lxc.mount.entry = /lib lib none ro,bind 0 0
lxc.mount.entry = /bin bin none ro,bind 0 0
lxc.mount.entry = /usr usr none ro,bind 0 0
lxc.mount.entry = /sbin sbin none ro,bind 0 0
lxc.mount.entry = /usr/share/lxc/templates/lxc-minimal sbin/init none ro,bind 0 0
lxc.mount.entry = proc proc proc nodev,noexec,nosuid 0 0
lxc.mount.entry = sysfs sys sysfs ro 0 0
lxc.mount.entry = /etc/init.d etc/init.d none ro,bind 0 0
EOF
# Oracle Linux and Fedora need the following two bind mounted
if [ -d /etc/sysconfig/network-scripts ]; then
cat <<EOF >> $path/config
lxc.mount.entry = /etc/sysconfig/network-scripts etc/sysconfig/network-scripts none ro,bind 0 0
EOF
fi
if [ -d /etc/rc.d ]; then
lxc.mount.entry = /etc/rc.d etc/rc.d none ro,bind 0 0
EOF
fi
# if no .ipv4 section in config, then have the container run dhcp
grep -q "^lxc.network.ipv4" $path/config || touch $rootfs/run-dhcp
if [ "$(uname -m)" = "x86_64" ]; then
lxc.mount.entry = /lib64 lib64 none ro,bind 0 0
EOF
fi
usage()
cat <<EOF
$1 -h|–help -p|–path= [–rootfs=]
EOF
return 0
check_for_cmd()
cmd_path=type $1
echo “The command ‘$1’ $cmd_path is not accessible on the system”
exit 1
fi
# we use cut instead of awk because awk is alternatives symlink on ubuntu
# and /etc/alternatives isn’t bind mounted
cmd_path=echo $cmd_path |cut -d ' ' -f 3
options=$(getopt -o hp:n:S: -l help,rootfs:,path:,name: – “$@”)
usage $(basename $0)
exit 1
fi
eval set – “$options”
while true
do
case “$1” in
-h|–help) usage $0 && exit 0;;
-p|–path) path=$2; shift 2;;
–rootfs) rootfs=$2; shift 2;;
-n|–name) name=$2; shift 2;;
–) shift 1; break ;;
*) break ;;
esac
done
if [ “$(id -u)” != “0” ]; then
echo “This script should be run as ‘root’”
exit 1
fi
cat << ‘EOF’ > /tmp/boringd
#! /usr/bin/env bash
/usr/bin/daemon – watch ls /tmp
EOF
chmod +x /tmp/boringd
if [ $0 = “/sbin/init” ]; then
PATH="$PATH:/bin:/sbin:/usr/sbin"
check_for_cmd /usr/lib/lxc/lxc-init
check_for_cmd /tmp/boringd
daemon_path=$cmd_path
echo "init'ing with ${daemon_path}"
exec /usr/lib/lxc/lxc-init -- $daemon_path
exit 1
fi
if [ -z “$path” ]; then
echo “‘path’ parameter is required”
exit 1
fi
# detect rootfs
config="$path/config"
if [ -z “$rootfs” ]; then
if grep -q ‘^lxc.rootfs’ $config 2>/dev/null ; then
rootfs=$(awk -F= ‘/^lxc.rootfs =/{ print $2 }’ $config)
else
rootfs=$path/rootfs
fi
fi
install_minimal $rootfs
echo “failed to install minimal’s rootfs”
exit 1
fi
configure_minimal $rootfs
echo “failed to configure minimal template”
exit 1
fi
copy_configuration $path $rootfs $name
echo “failed to write configuration file”
exit 1
fi
end of template
running command as root: lxc-start -n my-container -d -l trace -o debug.out
lxc-start 20170623081935.192 INFO lxc_start_ui - tools/lxc_start.c:main:275 - using rcfile /home/intern/.local/share/lxc/LXC/config
lxc-start 20170623081935.192 ERROR lxc_start_ui - tools/lxc_start.c:main:317 - Executing ‘/sbin/init’ with no configuration file may crash the host
lxc-start 20170623081943.706 INFO lxc_start_ui - tools/lxc_start.c:main:275 - using rcfile /var/lib/lxc/LXC/config
lxc-start 20170623081943.706 DEBUG lxc_monitor - monitor.c:lxc_monitord_spawn:309 - Going to wait for pid 28616.
lxc-start 20170623081943.706 DEBUG lxc_monitor - monitor.c:lxc_monitord_spawn:328 - Trying to sync with child process.
lxc-start 20170623081943.706 INFO lxc_start - start.c:lxc_check_inherited:235 - Closed inherited fd: 3.
lxc-start 20170623081943.706 INFO lxc_start - start.c:lxc_check_inherited:235 - Closed inherited fd: 5.
lxc-start 20170623081943.706 DEBUG lxc_monitor - monitor.c:lxc_monitord_spawn:366 - Using pipe file descriptor 6 for monitord.
lxc-start 20170623081943.708 DEBUG lxc_monitor - monitor.c:lxc_monitord_spawn:343 - Sucessfully synced with child process.
lxc-start 20170623081943.709 DEBUG lxc_monitor - monitor.c:lxc_monitord_spawn:312 - Finished waiting on pid 28616.
lxc-start 20170623081943.709 INFO lxc_container - lxccontainer.c:do_lxcapi_start:804 - Attempting to set proc title to [lxc monitor] /var/lib/lxc LXC
lxc-start 20170623081943.709 INFO lxc_start - start.c:lxc_check_inherited:235 - Closed inherited fd: 3.
lxc-start 20170623081943.709 INFO lxc_lsm - lsm/lsm.c:lsm_init:48 - LSM security driver AppArmor
lxc-start 20170623081943.709 DEBUG lxc_start - start.c:setup_signal_fd:273 - Set SIGCHLD handler with file descriptor: 5.
lxc-start 20170623081943.709 DEBUG lxc_monitor - monitor.c:lxc_monitord_spawn:309 - Going to wait for pid 28620.
lxc-start 20170623081943.709 DEBUG lxc_monitor - monitor.c:lxc_monitord_spawn:328 - Trying to sync with child process.
lxc-start 20170623081943.709 INFO lxc_start - start.c:lxc_check_inherited:235 - Closed inherited fd: 5.
lxc-start 20170623081943.709 DEBUG console - console.c:lxc_console_peer_default:468 - no console peer
lxc-start 20170623081943.709 INFO lxc_start - start.c:lxc_init:475 - Container “LXC” is initialized.
lxc-start 20170623081943.709 DEBUG lxc_monitor - monitor.c:lxc_monitord_spawn:366 - Using pipe file descriptor 6 for monitord.
lxc-start 20170623081943.710 DEBUG lxc_start - start.c:__lxc_start:1317 - Not dropping CAP_SYS_BOOT or watching utmp.
lxc-start 20170623081943.712 INFO lxc_conf - conf.c:instantiate_veth:2647 - Retrieved mtu 1500 from lxcbr0
lxc-start 20170623081943.712 INFO lxc_conf - conf.c:instantiate_veth:2672 - Attached ‘veth17YY3G’: to the bridge ‘lxcbr0’:
lxc-start 20170623081943.712 DEBUG lxc_conf - conf.c:instantiate_veth:2689 - instantiated veth ‘veth17YY3G/vethXE1GU4’, index is ‘23’
lxc-start 20170623081943.712 INFO lxc_cgroup - cgroups/cgroup.c:cgroup_init:68 - cgroup driver cgroupfs-ng initing for LXC
lxc-start 20170623081943.712 ERROR lxc_cgfsng - cgroups/cgfsng.c:create_path_for_hierarchy:1306 - Path “/sys/fs/cgroup/systemd//lxc/LXC” already existed.
lxc-start 20170623081943.712 ERROR lxc_cgfsng - cgroups/cgfsng.c:cgfsng_create:1363 - No such file or directory - Failed to create /sys/fs/cgroup/systemd//lxc/LXC: No such file or directory
lxc-start 20170623081943.712 DEBUG lxc_cgfsng - cgroups/cgfsng.c:filter_and_set_cpus:474 - No isolated cpus detected.
lxc-start 20170623081943.712 DEBUG lxc_cgfsng - cgroups/cgfsng.c:handle_cpuset_hierarchy:644 - “cgroup.clone_children” was already set to “1”.
lxc-start 20170623081943.713 INFO lxc_start - start.c:lxc_spawn:1154 - Cloned CLONE_NEWNS.
lxc-start 20170623081943.713 INFO lxc_start - start.c:lxc_spawn:1154 - Cloned CLONE_NEWPID.
lxc-start 20170623081943.713 INFO lxc_start - start.c:lxc_spawn:1154 - Cloned CLONE_NEWUTS.
lxc-start 20170623081943.713 INFO lxc_start - start.c:lxc_spawn:1154 - Cloned CLONE_NEWIPC.
lxc-start 20170623081943.713 INFO lxc_start - start.c:lxc_spawn:1154 - Cloned CLONE_NEWNET.
lxc-start 20170623081943.713 DEBUG lxc_monitor - monitor.c:lxc_monitord_spawn:343 - Sucessfully synced with child process.
lxc-start 20170623081943.714 DEBUG lxc_monitor - monitor.c:lxc_monitord_spawn:312 - Finished waiting on pid 28620.
lxc-start 20170623081943.714 INFO lxc_monitor - monitor.c:lxc_monitor_sock_name:185 - Using monitor socket name “lxc/ad055575fe28ddd5//var/lib/lxc”.
lxc-start 20170623081943.752 DEBUG lxc_conf - conf.c:lxc_assign_network:3185 - move ‘vethXE1GU4’/’(null)’ to ‘28632’: .
lxc-start 20170623081943.752 DEBUG lxc_conf - conf.c:setup_rootfs:1273 - mounted ‘/var/lib/lxc/LXC/rootfs’ on ‘/usr/lib/x86_64-linux-gnu/lxc’
lxc-start 20170623081943.752 INFO lxc_conf - conf.c:setup_utsname:901 - ‘LXC’ hostname has been setup
lxc-start 20170623081943.784 DEBUG lxc_conf - conf.c:setup_hw_addr:2225 - mac address ‘00:16:3e:ed:c3:28’ on ‘eth0’ has been setup
lxc-start 20170623081943.784 DEBUG lxc_conf - conf.c:setup_netdev:2452 - ‘eth0’ has been setup
lxc-start 20170623081943.784 INFO lxc_conf - conf.c:setup_network:2473 - network has been setup
lxc-start 20170623081943.784 INFO lxc_conf - conf.c:mount_autodev:1130 - Mounting container /dev
lxc-start 20170623081943.784 INFO lxc_conf - conf.c:mount_autodev:1153 - Mounted tmpfs onto /usr/lib/x86_64-linux-gnu/lxc/dev
lxc-start 20170623081943.784 INFO lxc_conf - conf.c:mount_autodev:1171 - Mounted container /dev
lxc-start 20170623081943.784 DEBUG lxc_conf - conf.c:mount_entry:1715 - remounting /dev on /usr/lib/x86_64-linux-gnu/lxc/dev to respect bind or remount options
lxc-start 20170623081943.784 DEBUG lxc_conf - conf.c:mount_entry:1730 - (at remount) flags for /dev was 4098, required extra flags are 3
lxc-start 20170623081943.784 DEBUG lxc_conf - conf.c:mount_entry:1765 - mounted ‘/dev’ on ‘/usr/lib/x86_64-linux-gnu/lxc/dev’, type ‘none’
lxc-start 20170623081943.784 DEBUG lxc_conf - conf.c:mount_entry:1715 - remounting /lib on /usr/lib/x86_64-linux-gnu/lxc/lib to respect bind or remount options
lxc-start 20170623081943.784 DEBUG lxc_conf - conf.c:mount_entry:1730 - (at remount) flags for /lib was 4096, required extra flags are 1
lxc-start 20170623081943.784 DEBUG lxc_conf - conf.c:mount_entry:1765 - mounted ‘/lib’ on ‘/usr/lib/x86_64-linux-gnu/lxc/lib’, type ‘none’
lxc-start 20170623081943.784 DEBUG lxc_conf - conf.c:mount_entry:1715 - remounting /bin on /usr/lib/x86_64-linux-gnu/lxc/bin to respect bind or remount options
lxc-start 20170623081943.784 DEBUG lxc_conf - conf.c:mount_entry:1730 - (at remount) flags for /bin was 4096, required extra flags are 1
lxc-start 20170623081943.784 DEBUG lxc_conf - conf.c:mount_entry:1765 - mounted ‘/bin’ on ‘/usr/lib/x86_64-linux-gnu/lxc/bin’, type ‘none’
lxc-start 20170623081943.784 DEBUG lxc_conf - conf.c:mount_entry:1715 - remounting /usr on /usr/lib/x86_64-linux-gnu/lxc/usr to respect bind or remount options
lxc-start 20170623081943.784 DEBUG lxc_conf - conf.c:mount_entry:1730 - (at remount) flags for /usr was 4096, required extra flags are 1
lxc-start 20170623081943.784 DEBUG lxc_conf - conf.c:mount_entry:1765 - mounted ‘/usr’ on ‘/usr/lib/x86_64-linux-gnu/lxc/usr’, type ‘none’
lxc-start 20170623081943.784 DEBUG lxc_conf - conf.c:mount_entry:1715 - remounting /sbin on /usr/lib/x86_64-linux-gnu/lxc/sbin to respect bind or remount options
lxc-start 20170623081943.784 DEBUG lxc_conf - conf.c:mount_entry:1730 - (at remount) flags for /sbin was 4096, required extra flags are 1
lxc-start 20170623081943.784 DEBUG lxc_conf - conf.c:mount_entry:1765 - mounted ‘/sbin’ on ‘/usr/lib/x86_64-linux-gnu/lxc/sbin’, type ‘none’
lxc-start 20170623081943.784 ERROR lxc_utils - utils.c:open_without_symlink:1682 - Too many levels of symbolic links - init in /usr/lib/x86_64-linux-gnu/lxc/sbin/init was a symbolic link!
lxc-start 20170623081943.784 ERROR lxc_conf - conf.c:mount_entry:1708 - Too many levels of symbolic links - failed to mount ‘/usr/share/lxc/templates/lxc-minimal’ on ‘/usr/lib/x86_64-linux-gnu/lxc/sbin/init’
lxc-start 20170623081943.784 ERROR lxc_conf - conf.c:lxc_setup:3869 - failed to setup the mount entries for ‘LXC’
lxc-start 20170623081943.784 ERROR lxc_start - start.c:do_start:811 - Failed to setup container “LXC”.
lxc-start 20170623081943.784 ERROR lxc_sync - sync.c:__sync_wait:57 - An error occurred in another process (expected sequence number 3)
lxc-start 20170623081943.784 INFO lxc_conf - conf.c:lxc_delete_network:3005 - Interface “(null)” with index 23 already deleted or existing in different network namespace.
lxc-start 20170623081943.836 INFO lxc_conf - conf.c:lxc_delete_network:3040 - Removed interface “veth17YY3G” from host.
lxc-start 20170623081943.836 ERROR lxc_start - start.c:__lxc_start:1346 - Failed to spawn container “LXC”.
lxc-start 20170623081943.868 WARN lxc_commands - commands.c:lxc_cmd_rsp_recv:172 - Command get_cgroup failed to receive response: Connection reset by peer.
lxc-start 20170623081948.873 ERROR lxc_start_ui - tools/lxc_start.c:main:366 - The container failed to start.
lxc-start 20170623081948.873 ERROR lxc_start_ui - tools/lxc_start.c:main:368 - To get more details, run the container in foreground mode.
lxc-start 20170623081948.873 ERROR lxc_start_ui - tools/lxc_start.c:main:370 - Additional information can be obtained by setting the --logfile and --logpriority options.
why do I have the error “Too many levels of symbolic links”?
