Error: Failed to handle idmapped storage: invalid argument - Failed to change ACLs on /var/snap/lxd/common/lxd/storage-pools/lxdstoragepool/containers/arlanger/rootfs/var/log/journal
My host is archlinux as was my previous host.
storage pool is lxdstoragepool and I have 3 containers: 1 ubuntu container and 2 archlinux containers.
I did an lxd recover
after changing my host to another partition. However, I ended up removing lxd on the new host and re-installing using snap.
After performing lxd recover, I was able to successfully remap an ubuntu container:
lxc launch rails
A month later I tried to launch an arch based container:
lxc launch rusty
Which gave me the error shown above.
$ lxc info --show-log rusty
Status: STOPPED
Type: container
Created: 2021/03/29 03:00 EDT
Last Used: 2021/12/24 06:23 EST
Log
$ lxc info --show-log rails
Status: RUNNING
Type: container
PID: 558488
Created: 2021/03/31 23:48 EDT
Last Used: 2022/01/12 10:24 EST
Resources:
Processes: 98
CPU usage:
CPU usage (in seconds): 21
Memory usage:
Memory (current): 748.52MiB
Network usage:
docker0:
Type: broadcast
State: UP
MAC address: 02:42:aa:ed:dd:ca
MTU: 1500
Bytes received: 0B
Bytes sent: 0B
Packets received: 0
Packets sent: 0
IP addresses:
inet: 172.17.0.1/16 (global)
Type: broadcast
State: UP
Host interface: vethea2b1676
MAC address: 00:16:3e:db:b1:13
MTU: 1500
Bytes received: 42.68kB
Bytes sent: 22.43kB
Packets received: 79
Packets sent: 71
IP addresses:
inet: 10.127.202.21/24 (global)
inet6: fd42:5b3b:2863:6328:216:3eff:fedb:b113/64 (global)
inet6: fe80::216:3eff:fedb:b113/64 (link)
lo:
Type: loopback
State: UP
MTU: 65536
Bytes received: 501.62kB
Bytes sent: 501.62kB
Packets received: 1485
Packets sent: 1485
IP addresses:
inet: 127.0.0.1/8 (local)
inet6: ::1/128 (local)
Snapshots:
| NAME | TAKEN AT | EXPIRES AT | STATEFUL |
| railsBAK01 | 2021/07/15 03:35 EDT | | NO |
| xenial-ruby243p205-rail514-psql95 | 2017/12/15 00:15 EST | | NO |
Log:
lxc rails 20220112152409.902 WARN conf - conf.c:lxc_map_ids:3579 - newuidmap binary is missing
lxc rails 20220112152409.902 WARN conf - conf.c:lxc_map_ids:3585 - newgidmap binary is missing
lxc rails 20220112152409.903 WARN conf - conf.c:lxc_map_ids:3579 - newuidmap binary is missing
lxc rails 20220112152409.903 WARN conf - conf.c:lxc_map_ids:3585 - newgidmap binary is missing
$ sudo su
ls -l /var/snap/lxd/common/lxd/storage-pools/lxdstoragepool/
total 0
