I’m trying to join a second node to a cluster in a new project. However, when I try and lxd init it into the cluster, I get this message and it fails: “Error: Failed to join cluster: Failed request to add member: Missing network “lxdfan0” in project “default””
I’m not sure what may be causing this as, to my knowledge, all necessary ports and such are open between the hosts. Nothing useful is showing up in the logs and the “verbose” option to the init command, isn’t verbose. It doesn’t say anything more than the non-verbose.
In /var/snap/lxd/common/lxd/logs/lxd.log? Unfortunately, nothing is logged. Not nothing useful, nothing at all after the last time lxd itself was started
So, in a case of “surprise!”, no, they weren’t the same version. Not entirely certain how that happened, as these are all brand new VMs, so I’ll just chuck it up to “Because GCP”. I snap removed and snap installed LXD and that seems to have cured the initial issue.
However, it did result in a new issue where the “lxd” command says this:
/snap/lxd/20750/commands/lxd: 18: SNAP_CURRENT: parameter not set
basename: missing operand
Try 'basename --help' for more information.
