Hi guys,
I create a container instance named dddd, and start it with REST API, but start returns failed occasionally. This issue happens for first time after create it.
{“type”:“sync”,“status”:“Success”,“status_code”:200,“operation”:"",“error_code”:0,“error”:"",“metadata”:{“id”:“b19149bd-74c8-4c94-ba22-1069c6aeaec6”,“class”:“task”,“description”:“Starting container”,“created_at”:“2021-06-25T14:37:00.19801582+08:00”,“updated_at”:“2021-06-25T14:37:00.19801582+08:00”,“status”:“Failure”,“status_code”:400,“resources”:{“containers”:["/1.0/containers/dddd"]},“metadata”:null,“may_cancel”:false,“err”:"Failed to run: /usr/sbin/lxd forkstart dddd /var/lib/lxd/containers /var/log/lxd/dddd/lxc.conf: ",“location”:“none”}}
with lxc info returns
[root@cube:~]# lxc info --show-log dddd
Remote: unix://
Architecture: aarch64
Created: 2021/06/25 08:40 UTC
Status: Stopped
Type: persistent
Profiles: docker
Log:
lxc dddd 20210625084025.312 WARN initutils - initutils.c:setproctitle:341 - Invalid argument - Failed to set cmdline
lxc dddd 20210625084026.175 ERROR start - start.c:proc_pidfd_open:1644 - Function not implemented - Failed to send signal through pidfd
lxc dddd 20210625084026.385 ERROR start - start.c:start:2121 - No such file or directory - Failed to exec “/sbin/init”
lxc dddd 20210625084026.389 ERROR sync - sync.c:__sync_wait:62 - An error occurred in another process (expected sequence number 7)
lxc dddd 20210625084026.389 WARN network - network.c:lxc_delete_network_priv:3374 - Failed to rename interface with index 109 from “eth0” to its initial name “veth7433008c”
lxc dddd 20210625084026.390 ERROR lxccontainer - lxccontainer.c:wait_on_daemonized_start:873 - Received container state “ABORTING” instead of “RUNNING”
lxc dddd 20210625084026.394 ERROR start - start.c:__lxc_start:2036 - Failed to spawn container “dddd”
lxc 20210625084027.740 WARN commands - commands.c:lxc_cmd_rsp_recv:135 - Connection reset by peer - Failed to receive response for command “get_state”
any ideas?
