lxc vm739943 20210117111705.577 ERROR cgfsng - cgroups/cgfsng.c:cgfsng_setup_limits:2957 - Numerical result out of range - Failed to set “cpu.weight” to “0”
lxc vm739943 20210117111705.577 ERROR start - start.c:lxc_spawn:1756 - Failed to setup cgroup limits for container “vm739943”
lxc vm739943 20210117111705.577 ERROR lxccontainer - lxccontainer.c:wait_on_daemonized_start:859 - Received container state “ABORTING” instead of “RUNNING”
lxc vm739943 20210117111705.577 ERROR start - start.c:__lxc_start:1999 - Failed to spawn container “vm739943”
lxc vm739943 20210117111705.577 WARN start - start.c:lxc_abort:1012 - No such process - Failed to send SIGKILL via pidfd 18 for process 10618
lxc 20210117111705.607 WARN commands - commands.c:lxc_cmd_rsp_recv:124 - Connection reset by peer - Failed to receive response for command “get_state”
limits.cpu.allowance: 0%
limits.cpu.priority: “0”
I don’t know how this came into the equation.
I changed it to non-zero and now it starts fine.
Thank you !
