Failed to start container on centos 6.10 (32bit)
im trying to setup lxc on an centos 6.10 (32 bit) vps.
i have installed lxc and lxc-templates using yum and created a debian (stretch 32bit) container using following command
lxc-create -t download -n c1
and everything is ok. but when i want to start this container using following command:
lxc-start -n c1
i get following error message:
lxc-start -n c1
lxc-start: cgfs.c: handle_cgroup_settings: 2153 Device or resource busy - failed to set memory.use_hierarchy to 1; continuing
Failed to determine whether /sys is a mount point: Invalid argument
Failed to determine whether /proc is a mount point: Invalid argument
Failed to determine whether /dev is a mount point: Invalid argument
Failed to determine whether /run is a mount point: Invalid argument
Failed to mount tmpfs at /sys/fs/cgroup: No such file or directory
Failed to mount cgroup at /sys/fs/cgroup/systemd: No such file or directory
[!!!] Failed to mount A…ystems, freezing.
Freezing execution.
whats wrong?
thanks
