Thanks, It seems the issue was solved. The storage pool got out of space and they rebooted the server, so the DB seems to be corrupted. Deleting the last segment-transaction-file solved the issue as you suggested in another post.
All are dated Dec 10th because the directory is a copy of the previous database directory from a previous attempt but it was like 4 days old in reality, nothing was lost.
After this snap start lxd worked just fine
root@node33:~# rm /var/snap/lxd/common/lxd/unix.socket
root@node33:~# lxd --debug --group lxd
INFO[12-01|13:38:49] LXD 3.18 is starting in normal mode path=/var/snap/lxd/common/lxd
INFO[12-01|13:38:49] Kernel uid/gid map:
INFO[12-01|13:38:49] - u 0 0 4294967295
INFO[12-01|13:38:49] - g 0 0 4294967295
INFO[12-01|13:38:49] Configured LXD uid/gid map:
INFO[12-01|13:38:49] - u 0 1000000 1000000000
INFO[12-01|13:38:49] - g 0 1000000 1000000000
WARN[12-01|13:38:49] CGroup memory swap accounting is disabled, swap limits will be ignored.
INFO[12-01|13:38:49] Kernel features:
INFO[12-01|13:38:49] - netnsid-based network retrieval: no
INFO[12-01|13:38:49] - uevent injection: no
INFO[12-01|13:38:49] - seccomp listener: no
INFO[12-01|13:38:49] - unprivileged file capabilities: yes
INFO[12-01|13:38:49] - shiftfs support: no
INFO[12-01|13:38:49] Initializing local database
DBUG[12-01|13:38:49] Initializing database gateway
DBUG[12-01|13:38:49] Start database node id=1 address=
06:02:38.912 [DEBUG]: data dir: /var/snap/lxd/common/lxd/database/global
06:02:38.912 [DEBUG]: metadata1: version 193, term 29, voted for 1
06:02:38.912 [DEBUG]: metadata2: version 194, term 29, voted for 1
06:02:38.912 [DEBUG]: metadata: version 196, term 29, voted for 1
06:02:38.912 [DEBUG]: I/O: direct 0, async 0, block 4096
06:02:38.912 [INFO ]: starting
06:02:38.912 [DEBUG]: segment 633388-634109
06:02:38.912 [DEBUG]: segment 634110-634238
06:02:38.912 [DEBUG]: segment 634239-634318
06:02:38.912 [DEBUG]: segment 634319-634473
06:02:38.912 [DEBUG]: segment 634474-634540
06:02:38.912 [DEBUG]: segment 634541-634778
06:02:38.912 [DEBUG]: segment 634779-635594
06:02:38.912 [DEBUG]: segment 635595-635879
06:02:38.912 [DEBUG]: segment 635880-635996
06:02:38.912 [DEBUG]: segment 635997-636343
06:02:38.912 [DEBUG]: segment 636344-636562
06:02:38.912 [DEBUG]: segment 636563-637378
06:02:38.912 [DEBUG]: segment 637379-637399
06:02:38.912 [DEBUG]: segment 637400-637719
06:02:38.912 [DEBUG]: segment 637720-637945
06:02:38.912 [DEBUG]: segment 637946-638035
06:02:38.912 [DEBUG]: segment 638036-638396
06:02:38.912 [DEBUG]: segment 638397-639118
06:02:38.912 [DEBUG]: segment 639119-639625
06:02:38.912 [DEBUG]: segment 639626-640439
06:02:38.912 [DEBUG]: segment 640440-641253
06:02:38.912 [DEBUG]: segment 641254-641344
06:02:38.912 [DEBUG]: segment 641345-641628
06:02:38.912 [DEBUG]: segment 641629-641719
06:02:38.912 [DEBUG]: segment 641720-642006
06:02:38.912 [DEBUG]: ignore db.bin
06:02:38.912 [DEBUG]: ignore db.bin-shm
06:02:38.912 [DEBUG]: ignore db.bin-wal
06:02:38.912 [DEBUG]: ignore metadata1
06:02:38.912 [DEBUG]: ignore metadata2
06:02:38.912 [DEBUG]: ignore snapshot-26-640555-4145502219
06:02:38.912 [DEBUG]: snapshot snapshot-26-640555-4145502219.meta
06:02:38.912 [DEBUG]: ignore snapshot-27-641579-5534976152
06:02:38.912 [DEBUG]: snapshot snapshot-27-641579-5534976152.meta
06:02:38.912 [DEBUG]: most recent snapshot at 641579
06:02:38.912 [DEBUG]: most recent closed segment is 641720-642006
06:02:38.912 [DEBUG]: load segment 633388-634109
06:02:38.912 [DEBUG]: load segment 634110-634238
06:02:38.912 [DEBUG]: load segment 634239-634318
06:02:38.912 [DEBUG]: load segment 634319-634473
06:02:38.912 [DEBUG]: load segment 634474-634540
06:02:38.912 [DEBUG]: load segment 634541-634778
06:02:38.912 [DEBUG]: load segment 634779-635594
06:02:38.912 [DEBUG]: load segment 635595-635879
06:02:38.912 [DEBUG]: load segment 635880-635996
06:02:38.912 [DEBUG]: load segment 635997-636343
06:02:38.912 [DEBUG]: load segment 636344-636562
06:02:38.912 [DEBUG]: load segment 636563-637378
06:02:38.912 [DEBUG]: load segment 637379-637399
06:02:38.912 [DEBUG]: load segment 637400-637719
06:02:38.912 [DEBUG]: load segment 637720-637945
06:02:38.912 [DEBUG]: load segment 637946-638035
06:02:38.912 [DEBUG]: load segment 638036-638396
06:02:38.912 [DEBUG]: load segment 638397-639118
06:02:38.912 [DEBUG]: load segment 639119-639625
06:02:38.912 [DEBUG]: load segment 639626-640439
06:02:38.912 [DEBUG]: load segment 640440-641253
06:02:38.912 [DEBUG]: load segment 641254-641344
06:02:38.912 [DEBUG]: load segment 641345-641628
06:02:38.912 [DEBUG]: load segment 641629-641719
06:02:38.912 [DEBUG]: load segment 641720-642006
06:02:38.912 [ERROR]: batch has zero entries (preamble at 3041088)
EROR[12-01|13:38:49] Failed to start the daemon: Failed to start dqlite server: failed to start task
INFO[12-01|13:38:49] Starting shutdown sequence
DBUG[12-01|13:38:49] Not unmounting temporary filesystems (containers are still running)
Error: Failed to start dqlite server: failed to start task
root@node33:~# cd /var/snap/lxd/common/lxd/database/global
root@node33:/var/snap/lxd/common/lxd/database/global# ls -l
total 93850
-rw------- 1 root root 7414424 Dec 10 2019 633388-634109
-rw------- 1 root root 1306064 Dec 10 2019 634110-634238
-rw------- 1 root root 785408 Dec 10 2019 634239-634318
-rw------- 1 root root 1570592 Dec 10 2019 634319-634473
-rw------- 1 root root 661376 Dec 10 2019 634474-634540
-rw------- 1 root root 2417864 Dec 10 2019 634541-634778
-rw------- 1 root root 8385632 Dec 10 2019 634779-635594
-rw------- 1 root root 2938472 Dec 10 2019 635595-635879
-rw------- 1 root root 1354424 Dec 10 2019 635880-635996
-rw------- 1 root root 3533760 Dec 10 2019 635997-636343
-rw------- 1 root root 2231840 Dec 10 2019 636344-636562
-rw------- 1 root root 8385632 Dec 10 2019 636563-637378
-rw------- 1 root root 210824 Dec 10 2019 637379-637399
-rw------- 1 root root 3429312 Dec 10 2019 637400-637719
-rw------- 1 root root 2330816 Dec 10 2019 637720-637945
-rw------- 1 root root 913376 Dec 10 2019 637946-638035
-rw------- 1 root root 3731792 Dec 10 2019 638036-638396
-rw------- 1 root root 7418552 Dec 10 2019 638397-639118
-rw------- 1 root root 5195096 Dec 10 2019 639119-639625
-rw------- 1 root root 8385552 Dec 10 2019 639626-640439
-rw------- 1 root root 8385584 Dec 10 2019 640440-641253
-rw------- 1 root root 938168 Dec 10 2019 641254-641344
-rw------- 1 root root 2995800 Dec 10 2019 641345-641628
-rw------- 1 root root 1044840 Dec 10 2019 641629-641719
-rw------- 1 root root 3053472 Dec 10 2019 641720-642006
-rw------- 1 root root 536576 Dec 10 2019 db.bin
-rw------- 1 root root 32768 Dec 10 2019 db.bin-shm
-rw------- 1 root root 997072 Dec 10 2019 db.bin-wal
-rw------- 1 root root 32 Dec 1 2019 metadata1
-rw------- 1 root root 32 Dec 1 2019 metadata2
-rw------- 1 root root 2856208 Dec 10 2019 snapshot-26-640555-4145502219
-rw------- 1 root root 56 Dec 10 2019 snapshot-26-640555-4145502219.meta
-rw------- 1 root root 1064008 Dec 10 2019 snapshot-27-641579-5534976152
-rw------- 1 root root 56 Dec 10 2019 snapshot-27-641579-5534976152.meta
root@node33:/var/snap/lxd/common/lxd/database/global# rm 641720-642006
root@node33:/var/snap/lxd/common/lxd/database/global# lxd --debug --group lxd
INFO[12-01|07:32:08] LXD 3.18 is starting in normal mode path=/var/snap/lxd/common/lxd
INFO[12-01|07:32:08] Kernel uid/gid map:
INFO[12-01|07:32:08] - u 0 0 4294967295
INFO[12-01|07:32:08] - g 0 0 4294967295
INFO[12-01|07:32:08] Configured LXD uid/gid map:
INFO[12-01|07:32:08] - u 0 1000000 1000000000
INFO[12-01|07:32:08] - g 0 1000000 1000000000
WARN[12-01|07:32:08] CGroup memory swap accounting is disabled, swap limits will be ignored.
INFO[12-01|07:32:08] Kernel features:
INFO[12-01|07:32:08] - netnsid-based network retrieval: no
INFO[12-01|07:32:08] - uevent injection: no
INFO[12-01|07:32:08] - seccomp listener: no
INFO[12-01|07:32:08] - unprivileged file capabilities: yes
INFO[12-01|07:32:08] - shiftfs support: no
INFO[12-01|07:32:08] Initializing local database
DBUG[12-01|07:32:08] Initializing database gateway
DBUG[12-01|07:32:08] Start database node address= id=1
INFO[12-01|07:32:09] Starting /dev/lxd handler:
INFO[12-01|07:32:09] - binding devlxd socket socket=/var/snap/lxd/common/lxd/devlxd/sock
INFO[12-01|07:32:09] REST API daemon:
INFO[12-01|07:32:09] - binding Unix socket socket=/var/snap/lxd/common/lxd/unix.socket
INFO[12-01|07:32:09] - binding TCP socket socket=[::]:8443
INFO[12-01|07:32:09] Initializing global database
DBUG[12-01|07:32:09] Dqlite: connected address=1 id=1 attempt=0
INFO[12-01|07:32:09] Initializing storage pools
DBUG[12-01|07:32:09] Initializing and checking storage pool “default”
DBUG[12-01|07:32:09] Checking ZFS storage pool “default”
DBUG[12-01|07:32:09] Initializing and checking storage pool “data”
DBUG[12-01|07:32:09] Checking BTRFS storage pool “data”
INFO[12-01|07:32:09] Initializing networks
DBUG[12-01|07:32:09] New task Operation: 639176f8-331e-4e5c-9a9a-7ed2c03c2e0f
INFO[12-01|07:32:09] Pruning leftover image files
DBUG[12-01|07:32:09] Started task operation: 639176f8-331e-4e5c-9a9a-7ed2c03c2e0f
INFO[12-01|07:32:09] Done pruning leftover image files
INFO[12-01|07:32:09] Loading daemon configuration
DBUG[12-01|07:32:09] Success for task operation: 639176f8-331e-4e5c-9a9a-7ed2c03c2e0f
DBUG[12-01|07:32:09] Initialized inotify with file descriptor 23
DBUG[12-01|07:32:09] New task Operation: e2e034a3-309c-4ba0-b6cf-b0be236f4ccc
INFO[12-01|07:32:09] Pruning expired images
DBUG[12-01|07:32:09] Started task operation: e2e034a3-309c-4ba0-b6cf-b0be236f4ccc
INFO[12-01|07:32:09] Done pruning expired images
DBUG[12-01|07:32:09] New task Operation: f5fe9dbc-86f1-4d61-869a-cab750a1ee83
DBUG[12-01|07:32:09] Success for task operation: e2e034a3-309c-4ba0-b6cf-b0be236f4ccc
INFO[12-01|07:32:09] Pruning expired container backups
DBUG[12-01|07:32:09] Started task operation: f5fe9dbc-86f1-4d61-869a-cab750a1ee83
INFO[12-01|07:32:09] Done pruning expired container backups
DBUG[12-01|07:32:09] Success for task operation: f5fe9dbc-86f1-4d61-869a-cab750a1ee83
DBUG[12-01|07:32:09] New task Operation: 551c001f-f573-4a8d-a150-086b5e6089a9
DBUG[12-01|07:32:09] New task Operation: 2e3f7d83-36e3-4faf-9cf3-813da3d8ef0b
INFO[12-01|07:32:09] Updating instance types
DBUG[12-01|07:32:09] Started task operation: 2e3f7d83-36e3-4faf-9cf3-813da3d8ef0b
INFO[12-01|07:32:09] Done updating instance types
INFO[12-01|07:32:09] Expiring log files
DBUG[12-01|07:32:09] Started task operation: 551c001f-f573-4a8d-a150-086b5e6089a9
INFO[12-01|07:32:09] Done expiring log files
DBUG[12-01|07:32:09] New task Operation: 30d32bcc-ff03-4d53-9911-02d827f50505
DBUG[12-01|07:32:09] Success for task operation: 551c001f-f573-4a8d-a150-086b5e6089a9
INFO[12-01|07:32:09] Updating images
DBUG[12-01|07:32:09] Started task operation: 30d32bcc-ff03-4d53-9911-02d827f50505
INFO[12-01|07:32:10] Done updating images
DBUG[12-01|07:32:10] Success for task operation: 30d32bcc-ff03-4d53-9911-02d827f50505
DBUG[12-01|07:32:10] Scheduler: network: vethb9a8d89b has been added: updating network priorities
DBUG[12-01|04:28:09] Scheduler: network: veth10f6e5de has been added: updating network priorities
DBUG[12-01|04:28:09] Scheduler: network: veth901e6e35 has been added: updating network priorities
DBUG[12-01|04:28:09] Scheduler: network: veth38838223 has been added: updating network priorities
DBUG[12-01|04:28:09] Scheduler: network: veth5eb946a7 has been added: updating network priorities
DBUG[12-01|04:28:09] Scheduler: network: veth2a8dc423 has been added: updating network priorities
DBUG[12-01|04:28:09] Mounting ZFS storage volume for container “maas-icts” on storage pool “default”
WARN[12-01|04:28:09] Unable to connect to MAAS, trying again in a minute url=http://10.3.4.10:5240/MAAS err=“unexpected: ServerError: 401 Unauthorized (Authorization Error: ‘Expired timestamp: given 1575154689 and now 1575165730 has a greater difference than threshold 300’)”
DBUG[12-01|04:28:09] Mounted ZFS storage volume for container “maas-icts” on storage pool “default”
DBUG[12-01|04:28:10] Mounting ZFS storage volume for container “maas-icts” on storage pool “default”
DBUG[12-01|04:28:10] Mounted ZFS storage volume for container “maas-icts” on storage pool “default”
INFO[12-01|04:28:10] Starting container created=2018-08-31T11:38:04+0530 ephemeral=false used=2019-12-06T15:42:30+0530 stateful=false project=default name=maas-icts action=start
DBUG[12-01|04:28:10] Handling method=GET url=/internal/containers/62/onstart ip=@ user=
DBUG[12-01|04:28:10] Scheduler: container maas-icts started: re-balancing
“type”: “sync”,
“status”: “Success”,
“status_code”: 200,
“operation”: “”,
“error_code”: 0,
“error”: “”,
“metadata”: {}
INFO[12-01|04:28:11] Started container project=default name=maas-icts action=start created=2018-08-31T11:38:04+0530 ephemeral=false used=2019-12-06T15:42:30+0530 stateful=false
DBUG[12-01|04:28:11] Scheduler: network: vetha4b16631 has been added: updating network priorities
DBUG[12-01|04:28:11] Scheduler: network: veth73329768 has been added: updating network priorities
DBUG[12-01|04:28:11] Scheduler: network: vethfbc36932 has been added: updating network priorities
DBUG[12-01|04:28:11] Scheduler: network: veth623dbc90 has been added: updating network priorities
DBUG[12-01|04:28:11] Scheduler: network: veth71ed1b81 has been added: updating network priorities
DBUG[12-01|04:28:11] Scheduler: network: veth0ea1166c has been added: updating network priorities
DBUG[12-01|04:28:11] Scheduler: network: veth477c2b84 has been added: updating network priorities
DBUG[12-01|04:28:11] Scheduler: network: veth560e984d has been added: updating network priorities
DBUG[12-01|04:28:11] Scheduler: network: vetha3268729 has been added: updating network priorities
DBUG[12-01|04:28:11] Scheduler: network: veth48c189ea has been added: updating network priorities
DBUG[12-01|04:28:11] Scheduler: network: veth9709d039 has been added: updating network priorities
DBUG[12-01|04:28:11] Scheduler: network: veth1381be08 has been added: updating network priorities
DBUG[12-01|04:28:11] Mounting ZFS storage volume for container “gateway-icts” on storage pool “default”
DBUG[12-01|04:28:11] Mounted ZFS storage volume for container “gateway-icts” on storage pool “default”
INFO[12-01|04:28:11] Starting container project=default name=gateway-icts action=start created=2018-08-31T11:43:17+0530 ephemeral=false used=2019-12-06T15:23:54+0530 stateful=false
DBUG[12-01|04:28:12] Handling ip=@ user= method=GET url=/internal/containers/69/onstart
DBUG[12-01|04:28:12] Mounting ZFS storage volume for container “gateway-icts” on storage pool “default”
DBUG[12-01|04:28:12] Mounted ZFS storage volume for container “gateway-icts” on storage pool “default”
DBUG[12-01|04:28:12] Scheduler: container gateway-icts started: re-balancing
“type”: “sync”,
“status_code”: 200,
“operation”: “”,
“error_code”: 0,
“error”: “”,
“metadata”: {}
INFO[12-01|04:28:13] Started container name=gateway-icts action=start created=2018-08-31T11:43:17+0530 ephemeral=false used=2019-12-06T15:23:54+0530 stateful=false project=default
DBUG[12-01|04:28:13] Scheduler: network: vethffe8cba7 has been added: updating network priorities
DBUG[12-01|04:28:13] Scheduler: network: vethdf5c1167 has been added: updating network priorities
DBUG[12-01|04:28:13] Mounting ZFS storage volume for container “aiotm-backend” on storage pool “default”
DBUG[12-01|04:28:13] Mounted ZFS storage volume for container “aiotm-backend” on storage pool “default”
INFO[12-01|04:28:13] Starting container stateful=false project=default name=aiotm-backend action=start created=2018-04-06T11:12:33+0530 ephemeral=false used=2019-12-06T15:23:56+0530
DBUG[12-01|04:28:13] Handling method=GET url=/internal/containers/4/onstart ip=@ user=
DBUG[12-01|04:28:13] Scheduler: container aiotm-backend started: re-balancing
“type”: “sync”,
“status_code”: 200,
“operation”: “”,
“error_code”: 0,
“error”: “”,
“metadata”: {}
INFO[12-01|04:28:14] Started container project=default name=aiotm-backend action=start created=2018-04-06T11:12:33+0530 ephemeral=false used=2019-12-06T15:23:56+0530 stateful=false
DBUG[12-01|04:28:14] Scheduler: network: veth91696506 has been added: updating network priorities
DBUG[12-01|04:28:14] Mounting ZFS storage volume for container “aiotm-besafe” on storage pool “default”
DBUG[12-01|04:28:14] Scheduler: network: vetha04847e6 has been added: updating network priorities
DBUG[12-01|04:28:14] Mounted ZFS storage volume for container “aiotm-besafe” on storage pool “default”
INFO[12-01|04:28:14] Starting container used=2019-12-06T15:23:59+0530 stateful=false project=default name=aiotm-besafe action=start created=2018-04-04T14:05:17+0530 ephemeral=false
DBUG[12-01|04:28:14] Handling method=GET url=/internal/containers/12/onstart ip=@ user=
DBUG[12-01|04:28:15] Scheduler: container aiotm-besafe started: re-balancing
“type”: “sync”,
“status_code”: 200,
“operation”: “”,
“error_code”: 0,
“error”: “”,
“metadata”: {}
INFO[12-01|04:28:16] Started container action=start created=2018-04-04T14:05:17+0530 ephemeral=false used=2019-12-06T15:23:59+0530 stateful=false project=default name=aiotm-besafe
DBUG[12-01|04:28:16] Mounting ZFS storage volume for container “aiotm-devi” on storage pool “default”
DBUG[12-01|04:28:16] Scheduler: network: vethaa01fadd has been added: updating network priorities
DBUG[12-01|04:28:16] Scheduler: network: veth8548335d has been added: updating network priorities
DBUG[12-01|04:28:16] Mounted ZFS storage volume for container “aiotm-devi” on storage pool “default”
INFO[12-01|04:28:16] Starting container project=default name=aiotm-devi action=start created=2018-06-20T12:24:51+0530 ephemeral=false used=2019-12-06T15:24:01+0530 stateful=false
DBUG[12-01|04:28:17] Handling ip=@ user= method=GET url=/internal/containers/21/onstart
DBUG[12-01|04:28:17] Mounting ZFS storage volume for container “aiotm-devi” on storage pool “default”
DBUG[12-01|04:28:17] Mounted ZFS storage volume for container “aiotm-devi” on storage pool “default”
DBUG[12-01|04:28:17] Scheduler: container aiotm-devi started: re-balancing
“type”: “sync”,
“status_code”: 200,
“operation”: “”,
“error_code”: 0,
“error”: “”,
“metadata”: {}
INFO[12-01|04:28:17] Started container action=start created=2018-06-20T12:24:51+0530 ephemeral=false used=2019-12-06T15:24:01+0530 stateful=false project=default name=aiotm-devi
DBUG[12-01|04:28:17] Mounting ZFS storage volume for container “aiotm-frontend” on storage pool “default”
DBUG[12-01|04:28:17] Scheduler: network: veth63544f52 has been added: updating network priorities
DBUG[12-01|04:28:17] Scheduler: network: vethbb62451f has been added: updating network priorities
DBUG[12-01|04:28:18] Mounted ZFS storage volume for container “aiotm-frontend” on storage pool “default”
DBUG[12-01|04:28:18] Mounting ZFS storage volume for container “aiotm-frontend” on storage pool “default”
INFO[12-01|04:28:18] Starting container name=aiotm-frontend action=start created=2018-04-06T11:12:33+0530 ephemeral=false used=2019-12-06T15:24:07+0530 stateful=false project=default
DBUG[12-01|04:28:18] Handling method=GET url=/internal/containers/6/onstart ip=@ user=
DBUG[12-01|04:28:18] Scheduler: container aiotm-frontend started: re-balancing
“type”: “sync”,
“status_code”: 200,
“operation”: “”,
“error_code”: 0,
“error”: “”,
“metadata”: {}
WARN[12-01|04:28:19] Failed to update instance types: Get https://images.linuxcontainers.org/meta/instance-types/.yaml: lookup images.linuxcontainers.org: Temporary failure in name resolution
DBUG[12-01|04:28:19] Failure for task operation: 2e3f7d83-36e3-4faf-9cf3-813da3d8ef0b: Get https://images.linuxcontainers.org/meta/instance-types/.yaml: lookup images.linuxcontainers.org: Temporary failure in name resolution
INFO[12-01|04:28:20] Started container ephemeral=false used=2019-12-06T15:24:07+0530 stateful=false project=default name=aiotm-frontend action=start created=2018-04-06T11:12:33+0530
DBUG[12-01|04:28:20] Mounting ZFS storage volume for container “aiotm-gps” on storage pool “default”
DBUG[12-01|04:28:20] Scheduler: network: veth3f33b150 has been added: updating network priorities
DBUG[12-01|04:28:20] Scheduler: network: veth7bb39e16 has been added: updating network priorities
DBUG[12-01|04:28:20] Mounted ZFS storage volume for container “aiotm-gps” on storage pool “default”
DBUG[12-01|04:28:21] Mounting ZFS storage volume for container “aiotm-gps” on storage pool “default”
DBUG[12-01|04:28:21] Mounted ZFS storage volume for container “aiotm-gps” on storage pool “default”
INFO[12-01|04:28:21] Starting container ephemeral=false used=2019-12-06T15:25:15+0530 stateful=false project=default name=aiotm-gps action=start created=2018-04-05T11:34:32+0530
DBUG[12-01|04:28:21] Handling method=GET url=/internal/containers/11/onstart ip=@ user=
DBUG[12-01|04:28:21] Scheduler: container aiotm-gps started: re-balancing
“type”: “sync”,
“status_code”: 200,
“operation”: “”,
“error_code”: 0,
“error”: “”,
“metadata”: {}
INFO[12-01|04:28:24] Started container action=start created=2018-04-05T11:34:32+0530 ephemeral=false used=2019-12-06T15:25:15+0530 stateful=false project=default name=aiotm-gps
DBUG[12-01|04:28:24] Mounting BTRFS storage volume “mysql-log” on storage pool “data”
DBUG[12-01|04:28:24] Mounting BTRFS storage pool “data”
DBUG[12-01|04:28:24] Mounted BTRFS storage pool “data”
DBUG[12-01|04:28:24] Mounted BTRFS storage volume “mysql-log” on storage pool “data”
DBUG[12-01|04:28:24] Mounting ZFS storage volume for container “aiotm-mysql” on storage pool “default”
DBUG[12-01|04:28:24] Scheduler: network: veth55e454c6 has been added: updating network priorities
DBUG[12-01|04:28:24] Scheduler: network: veth868b2aab has been added: updating network priorities
DBUG[12-01|04:28:24] Mounted ZFS storage volume for container “aiotm-mysql” on storage pool “default”
DBUG[12-01|04:28:25] Mounting ZFS storage volume for container “aiotm-mysql” on storage pool “default”
DBUG[12-01|04:28:25] Mounted ZFS storage volume for container “aiotm-mysql” on storage pool “default”
INFO[12-01|04:28:25] Starting container project=default name=aiotm-mysql action=start created=2018-04-06T11:12:33+0530 ephemeral=false used=2019-12-06T15:26:28+0530 stateful=false
DBUG[12-01|04:28:25] Handling method=GET url=/internal/containers/5/onstart ip=@ user=
DBUG[12-01|04:28:25] Scheduler: container aiotm-mysql started: re-balancing
“type”: “sync”,
“status_code”: 200,
“operation”: “”,
“error_code”: 0,
“error”: “”,
“metadata”: {}
INFO[12-01|04:28:29] Started container ephemeral=false used=2019-12-06T15:26:28+0530 stateful=false project=default name=aiotm-mysql action=start created=2018-04-06T11:12:33+0530
DBUG[12-01|04:28:29] Scheduler: network: veth57a61238 has been added: updating network priorities
DBUG[12-01|04:28:29] Scheduler: network: veth4518f287 has been added: updating network priorities
DBUG[12-01|04:28:29] Mounting ZFS storage volume for container “maas-1285-rackd” on storage pool “default”
DBUG[12-01|04:28:29] Mounted ZFS storage volume for container “maas-1285-rackd” on storage pool “default”
DBUG[12-01|04:28:30] Mounting ZFS storage volume for container “maas-1285-rackd” on storage pool “default”
DBUG[12-01|04:28:30] Mounted ZFS storage volume for container “maas-1285-rackd” on storage pool “default”
INFO[12-01|04:28:30] Starting container project=default name=maas-1285-rackd action=start created=2018-09-25T15:24:52+0530 ephemeral=false used=2019-12-06T15:27:27+0530 stateful=false
DBUG[12-01|04:28:30] Handling user= method=GET url=/internal/containers/87/onstart ip=@
DBUG[12-01|04:28:31] Scheduler: container maas-1285-rackd started: re-balancing
“type”: “sync”,
“status_code”: 200,
“operation”: “”,
“error_code”: 0,
“error”: “”,
“metadata”: {}
INFO[12-01|04:28:33] Started container project=default name=maas-1285-rackd action=start created=2018-09-25T15:24:52+0530 ephemeral=false used=2019-12-06T15:27:27+0530 stateful=false
INFO[12-01|04:29:10] Connected to MAAS controller url=http://10.3.4.10:5240/MAAS
^CINFO[12-01|04:35:57] Received ‘interrupt signal’, exiting
INFO[12-01|04:35:57] Starting shutdown sequence
INFO[12-01|04:35:57] Stopping REST API handler:
INFO[12-01|04:35:57] - closing socket socket=[::]:8443
INFO[12-01|04:35:57] - closing socket socket=/var/snap/lxd/common/lxd/unix.socket
INFO[12-01|04:35:57] Stopping /dev/lxd handler:
INFO[12-01|04:35:57] - closing socket socket=/var/snap/lxd/common/lxd/devlxd/sock
INFO[12-01|04:35:57] Closing the database
DBUG[12-01|04:35:57] Stop database gateway
DBUG[12-01|04:35:57] Not unmounting temporary filesystems (containers are still running)
